Old 05-25-2014, 05:46 PM   #1
xITSxTHExPOPEx
xITSxTHExPOPEx's Avatar
Drives: 2013 FRS 6MT
Expanding foam in rear deck
I dropped a 10" JL sub and powered it with a 300w cheap amp in the trunk. Sub sounds fine and just about everything is nice and tight except for the rear deck, at high volume it constantly rattles, and on the lower notes it rattles even with the volume super low (5-15). Digging around I noticed the previous owner must have removed the rear deck like an idiot because 2 of the 4 white clips seem to be missing or broken.
Rather than pulling it apart and replacing clips, you guys think it'd be safe to just tape up all the holes and shoot some expanding foam in there to tighten everything up? I dont plan to ever remove the deck seeing as theres no speakers in it to replace, nor do i plan on getting tint, so having it be a bitch to remove isn't really an issue. The only thing I'm concerned about is any wiring that might need to be accessed in the future that would be in there.
TLDR Is it safe to shoot some expanding foam under the rear deck?
2013 FR-S 6MT
xITSxTHExPOPEx is offline   Reply With Quote
Old 05-25-2014, 06:13 PM   #2
gramicci101
Off Topic
I think I'd rather put some dense sponges under it, purely because you don't know if you'll ever need to remove it again. Expanding foam is a pretty permanent solution.
Old 05-25-2014, 10:02 PM   #3
xITSxTHExPOPEx
That's actually a pretty good idea and I have quite a few big sponges lying around. I may have to try that tomorrow. Thanks!
2013 FR-S 6MT
Old 05-26-2014, 08:45 AM   #4
rmjjensen
rmjjensen's Avatar
Drives: 2013 Subaru BRZ Limited in WRB
Have you checked your third brake light? I found that it most of my rattle stemmed from this plastic third brake light. All the plastic between the light itself and the clips made it sound horrible.
rmjjensen is offline   Reply With Quote
Old 05-27-2014, 02:04 PM   #5
SuperKazRacing
Drives: 2013 RED FR-S
me too ! I finally had to remove it as my ALPINE 12inch Crushes it !!! Tried many tricks.Some Worked ,some didn't. Removing it worked perfectly,and 75 ft of DYNAMAT ....
SuperKazRacing is offline   Reply With Quote
Old 06-15-2014, 01:54 PM   #6
xITSxTHExPOPEx
Sponge worked great check it out
http://www.ft86club.com/forums/showt...33#post1797433
2013 FR-S 6MT
The Following User Says Thank You to xITSxTHExPOPEx For This Useful Post:
gramicci101 (06-15-2014)
WTB: REAR window top Brake Light (just top half with leds) or full rear deck Kayzer Soze Exterior Parts (Aero, Lighting, Etc.) 1 08-31-2013 03:23 PM
Rear deck rattle - fix it in 30s nzer AUSTRALIA 0 07-25-2013 05:09 PM
eliminate rear deck popping with rear strut bar? chenshuo Issues | Warranty | Recalls / TSB 11 07-03-2013 07:44 PM
Wtb rear deck / headliner jshadeck Exterior Parts (Aero, Lighting, Etc.) 0 02-03-2013 09:31 PM
do you think the rear deck rattle... pr086 Issues | Warranty | Recalls / TSB 7 08-03-2012 05:35 PM
