#141 | |
Car Nut
Drives: BMW 335d, Toyota Echo RS, FRS
#142 | |
Drives: Monogram Firestorm
#143 | |
DrivinginDreams...Cloud86
Drives: Toyota GT86
![]() I still want to know if there is a way to have the doors auto lock for safety while driving and if there is a way to make the doors auto lock when you get out and close the door to walk away without having to touch the door handle sensor.
#144 |
Drives: 2014 BRZ Limited
Today I accidentally discovered that there's an easy way to override night mode (and day mode as well) on the BRZ's head unit. This might work on other head units as well, but since I don't have one to test, I don't know.
If you press and hold the "Audio" button, a hidden menu appears that, as far as I know, is not in the manual for the nav unit. If you're in day mode, a "Night" button appears at the top of the screen in that menu. If you're in night mode, that button says "Day" instead. Pressing that button toggles the night/day modes and causes it to ignore the headlights without having to adjust your display to full brightness. So if you're driving with your headlights on in the rain during the day and want your display at daylight brightness, just press and hold the Audio button and push the "Day" button on the screen. I wish those idiots had put that in the manual instead of having me curse them for months for not including an intuitive way to override the automatic brightness settings. Last edited by extrashaky; 06-12-2014 at 11:49 PM. |
#145 |
Drives: 2014 FRS
I've had my FRS for a while now and I just discovered this hidden feature
I believe it the BRZ also has this. Open the driver or passenger side door and lift up the latch under the seat, and pull the seat forward as much as it will go. Turn on the dome light and you'll notice that in the back, there's a couple of seats. |
#146 |
86
Drives: Monogram Whiteout
#147 | |
Drives: Neptune GR86
#148 |
Drives: 2014 SWP BRZ Limited 6SP
This is top three best things in this thread. How the hell is this not in some quick start guide? So much fail in the stock head unit.
1990 Laser RS - Lights go up, lights go down ||1992 MX-6 Coupe - Hah ... no || 2001 Integra GSR - Almost rice. Risotto || 2003 IS300 - A nice car but no fun. || 2011 Stage I GTI - Lots of fun. Would buy another
2014 BRZ - That BRZ. So hot right now. |
#149 | |
As Andrew025 mentioned above, there's also a button on that menu that turns the display off altogether, as well as some sliders for brightness and contrast. I didn't think to include those earlier because I was so happy to have found a way to brighten the display while driving in the rain with the headlights on. I found it quite by accident. I reached up to hit the audio button just as I went over a patch of rough road. I guess I held the button down longer than usual while being jostled around, and that menu popped up, and I said out loud, "WTF is that?" |
#150 | |
Noob
Drives: FR-S Mammogram
#151 |
This is for the BRZ head unit. It actually says 'DISP' above the audio button to denote the secondary function. I missed it for 5 months.
#152 | |
A Demon
Drives: Raven GT86
For the 2014 head unit just click display button on top right of screen when it's on. I can take picture of it when I'm off work. Sent from my iPhone using Tapatalk |
#153 | ||
Noob
![]() Quote:
#154 | |
Drives: 2014 BRZ Ltd - DGM
2014 BRZ Ltd. - DGM
E30 318is trackday funday car E46 323ci vert |
| Tags |
| scion brz hidden features |
| Ideas for a hidden magnetic phone-mount. | MmmDieselFumes | Cosmetic Modification (Interior/Exterior/Lighting) | 40 | 05-09-2016 01:14 PM |
| Bespoke A/V Hidden Option | UbSaMrC | Electronics | Audio | NAV | Infotainment | 58 | 12-13-2015 11:14 PM |
| FS: Custom Stainless Lightweight Hidden Hitch | that_guy | Canada Classifieds | 3 | 06-11-2014 07:13 PM |
| Hidden Rusting issue | FRSHunter | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 1 | 04-07-2014 05:02 PM |
| DIY: access hidden menus on BRZ head unit | robot | DIY (Do-It-Yourself) Guides | 0 | 10-22-2013 11:59 PM |
