Old 06-12-2014, 08:20 PM   #43
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
Originally Posted by Mikeez View Post
Many frs/brz owner find that the torque and whp is a low end on their car and modify their car with a forced induction system. Keeping in mind that the FA20 is an excellent motor ! How do you choose your turbo kit or super charger kit? Do you try to maximize power or add little power?
When you go for a turbo/supercharger what are the things you keep in mind?
Stock FRS, stock exhaust, stock everything! I want to go turbo with my car, can I just buy a turbo kit. Get it installed and tune the car's software or do I have to do more?
Should I change the axle, driveshaft and the differential?
Should I change anything in the exhaust?
Which turbo should I get? They are all good. How do you guys go by it?
Well for the question between supercharger and turbo, it comes down to a few things. Well from our experience with customers there is definitely a trend for certain aspects. Here are some questions to ask yourself.
Questions to help determine what you might want.
1. Do you daily drive the car and use to big V8 torque and response?
- Supercharger
2. Do you plan on going to the drag or track with your setup?
- Turbo
3. Are you worried about smog and being CARB legal?
- Supercharger
4. Do you want to continue building the power up in large steps, with basic mod upgrades?
- Turbo
5. Do you want to be able to resell your vehicle easily?
- Supercharger
6. You do not mind being loud, therefore having less back pressure to make power?
- Turbo
7. You have an automatic transmission?
- Supercharger
Well just my $0.02.
Cheers,
William Knose
Old 06-12-2014, 08:35 PM   #44
Mikeez
Engineering Student
Drives: Scion FR-S 2015
- Supercharger
- Turbo
- Supercharger
- Turbo
- Supercharger
- Turbo
- Supercharger
Well just my $0.02.
Cheers,
William Knose
I daily drive the car, I have manual transmission and I don't mind being loud. I actually enjoy driving loud! What do you mean by CARB and smog? Pollution, I don't care xD! However, catalyst converter help this unless when you install turbo it is taken off?
Is catalytic converter removed when installed turbo?
Mikeez is offline   Reply With Quote
Old 06-12-2014, 08:52 PM   #45
DeliciousTuning
If you are running the basic kits with minimal boost to about 7 PSI you can run a catalytic converter. But once you start going much above that to get the air to flow well out the exhaust with a turbo you will want to open that up. Either a high flow catalytic converter or if you go more power than nothing at all. Basically a full three inch exhaust to keep the back pressure low on a turbo setup.
Though having no catalytic converter can get stinking when sitting in traffic or at a light. Just an FYI.
Cheers,
William Knose
Old 06-12-2014, 08:53 PM   #46
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
to the OP, you can always @King Tut if you want to learn what the linear torque is all about
glamcem is offline   Reply With Quote
Old 06-12-2014, 09:03 PM   #47
Fear
Drives: Ft86
Honestly, i'd suggest speed by designs kit and tune... Very basic intro kit for decent power
Fear is offline   Reply With Quote
Old 06-12-2014, 09:29 PM   #48
DR 86
DR 86's Avatar
Why supercharger for auto tranny? Serious question, want to learn.
Perrin CAI|Perrin MCB|P&L header|Motiv OP/FP|MXP catback|Tein Type Flex coilovers|Eibach F/R sway bars|GS front strut brace|Street:PM HC+800/Track:Carbotech XP10|StopTech slotted rotors/SS lines|SBC RPF1s|Street:FK453/Winter:Pirelli SottoZero3/Track:Toyo R888s|Leg Sport rear spoiler|EcuTek Tuned|OEM oil cooler|4th/F1 brake lights
DR 86 is offline   Reply With Quote
Old 06-12-2014, 09:51 PM   #49
D K
Stig's dark passenger
Credit card?
D K is offline   Reply With Quote
The Following User Says Thank You to D K For This Useful Post:
raven1231 (06-13-2014)
Old 06-12-2014, 09:54 PM   #50
D K
Why mess with DSS axles when you can have a solid rear axle?
Pretty much that and a shark fin and you're there.
Old 06-12-2014, 10:30 PM   #51
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
Originally Posted by cdrazic93 View Post
There, helped ya out a bit, I think
Except the PTUNING kit eliminates the need for a costly over pipe and they have their own 3" turbo back exhaust designed for their kit
http://www.ptuning.com/subdir/itemde...delDesc=FR%2DS
No build thread. I don't want to be reminded of how much money I spent.
[insert profound quote here]
ecko04 is offline   Reply With Quote
Old 06-12-2014, 10:46 PM   #52
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
That too! Lol
Old 06-13-2014, 01:38 AM   #53
AJPG
Drives: 22RE, FA20, 4G63
Hi
MPGs are driver habits! My aren't so good, but this a drift/sport car.
19MPGs NA and 14MPGs FI.
A friend have one NA with intake and tune MPGs 29. He ones agree to be my passenger, but didn't like it.
If you go for 600hp, forget MPGs, and get some cash for good fuel, built engine and don't forget the tranny, axels...
Enjoy the ride!
AJPG is offline   Reply With Quote
Old 06-13-2014, 01:53 AM   #54
DR 86
DR 86's Avatar
- Supercharger
- Turbo
- Supercharger
- Turbo
- Supercharger
- Turbo
- Supercharger
Well just my $0.02.
Cheers,
William Knose
Why supercharger over turbo for for auto tranny?
Old 06-13-2014, 02:39 AM   #55
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
- Supercharger
why does the transmission matter?
Old 06-13-2014, 05:57 AM   #56
chiefshayan
chiefshayan's Avatar
Drives: 2013 AT Firestorm FRS
CVT's tend to have issues with heat when adding power, same goes for our cars in the AT form. A turbo is overall a much more heat-intense process to making power (turbine vs. pulley). A simple fix would be to opt for an upgraded auto transmission cooler.
I personally think boost is great for our AT cars, especially since we can utilize our tall gearing in 5th and 6th
chiefshayan is offline   Reply With Quote
Installing a Turbo Kit + other mods chiefshayan Forced Induction 21 01-22-2014 11:58 PM
Unnecessary Boost needed (Turbo or Supercharge) Nickse30 Forced Induction 32 05-27-2013 01:57 PM
turbo kit supporting mods lbroskee Forced Induction 13 03-30-2013 09:56 PM
NA engine mods for turbo money? subatoy Engine, Exhaust, Transmission 62 11-28-2012 05:32 PM
if going FI, would you turbocharge or supercharge? tibsy92 AUSTRALIA 35 08-18-2012 11:02 PM
