go_a_way1
Old 06-08-2014, 01:39 PM   #6035
shif7i7down
Erected Member
Drives: frs
Originally Posted by DAEMANO View Post
... and by the way... My post above is not to start an Phantom ESC war vs. other Stg 1 FI kits. It's to illustrate the value of the Phantom ESC and OFT tune. Party on.
LOL, like a BOSS
shif7i7down is offline   Reply With Quote
The Following User Says Thank You to shif7i7down For This Useful Post:
DAEMANO (06-08-2014)
Old 06-08-2014, 02:06 PM   #6036
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
[*]"Trackable" with $35 upgrade (thanks @Thatruth2001 @nlowell @Sojhinn @Target70)
Can you expand on this please? Are the batteries now lasting or able to recharge at a rate that would last a 20 minute session with lots of WOT on a road course? Without overheating the controller? Or is that why you put it in quotations since it would run out well before and would require a toggle modification to manage available boost voltage?
Old 06-08-2014, 02:12 PM   #6037
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
I think it was in reference to heat issues.
Old 06-08-2014, 02:14 PM   #6038
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Full throttle Electric Supercharger Build Thread
The issues with the batteries has not been running out of charge but rather the controller hitting thermal safeties. We have been testing an air duct to push cooler air across the controller and have had great success. @nlowell did multiple 20 minutes sessions yesterday and the the controller only hit the fail safe once during the last session of the day when the ambient temperature hit 105 degrees Fahrenheit.
Installed Mods:
The Following User Says Thank You to Sojhinn For This Useful Post:
ATL BRZ (06-08-2014)
Old 06-08-2014, 02:19 PM   #6039
ATL BRZ
ATL BRZ's Avatar
Originally Posted by nlowell View Post
At Buttonwillow - 97 degrees out - happy to report that the ESC just survived a full 20 minute (correction: 25 minute!) session! It was in 26.6 mode early on but kept feeding me power the whole session! And DAMN was it fun!! =)
Details on your controller cooling modifications? Any video footage of your laps to share?
Old 06-08-2014, 02:22 PM   #6040
Sojhinn
Sojhinn's Avatar
I can help answer this. The cooling mod is utilizing an air duct from the fog lamp location to the engine bay. The duct is just pointing at the air controller.
As for the lap footage I'm waiting for this too. He recorded it at button willow but is not going to be able to post it for a few days.
Installed Mods:
The Following 2 Users Say Thank You to Sojhinn For This Useful Post:
ATL BRZ (06-08-2014), DAEMANO (06-08-2014)
Old 06-08-2014, 02:28 PM   #6041
jflogerzi
jflogerzi's Avatar
Robs ESC is great. I was impressed with it from a strictly autocross street setup. But this setup will be no means be trackable at any decent road course. Battery technology is just not there. With other Stg 1 kits this is where the extra money you pay. IMO If was building a nice street canyon carver and auto-X twin, this is what I would build
ECS + 1.5 dump pack
OFT
drop in filter
nameless axleback
MPSS in stock rim size
RCE Yellows or other mild drop(1inch max)
spacers (10-20mm) squared
new brake pads
new brake fluid
Yes I know that this cost quite a bit of cash, but this would completely transform this car vs just most entry level FI kits done right.
Old 06-08-2014, 02:29 PM   #6042
DAEMANO
Time Traveller
HAHA a lot of answers prior to mine. Will post it anyhow.
Sure thing, as you know, even though the Phantom ESC is designed to be used on the street, many owners want to push that limit for track sessions/AutoX. So they've been working on addressing the couple of issues the ESC had a couple for track suitability. Keep in mind that track usage is not supported by @Robftss at this point.
1. Battery capacity
2. ESC Controller thermal management
Since the ESC is designed for the street, thermal management built into it's controller has the capacity to be used only for several consecutive WOT pulls. However, as you also know very well, the track is much more demanding than that. So, by first testing the ESCs thermal limits (@ThaTruth2001 @nlowell ), then designing a cooling solution for that @nlowell @Sojhinn @Target70) have designed a simple duct system to draw cool air to the controller (similar to a brake duct kit). Results from the past few weeks have been positive as @nlowell has reported no performance issues even with his 25 minute track sessions.
http://www.ft86club.com/forums/showp...postcount=6004
Please note that @nlowell also has a vented hood. I'm sure he can add details to this. Recently @nlowell or @Sojhinn and @Target70 produced a DIY for their versions of this mod post a page or so back.
Adding a second set of dump batteries both increases the amount of power that can be dumped into the compressor (adding roughly .5 lbs of boost) as well as increasing "time on boost" while at WOT.
There's a third issue, but not certain if I'd call that a limitation. It's the part-time nature of the the ESC activation (the "full throttle") aspect. IMO this is less of a limitation as it might seem because in most tight corners, drivers are rarely at WOT. Part throttle performance then defaults back to NA where throttle can be modulated and the cars dynamic attitude controlled as normal. Learning to work with the WOT switch might then be similar to working with a standard Turbo (and it's lag characteristics) on the track, but the ESC has more linear torque characteristics because we're only talking about up to ~210ish WTQ so its not going to cause a huge surge of torque mid corner even if you're not using finesse with the throttle mid-corner.
More track session should suss this out, but as of know this is all looking very promising.
The Following 2 Users Say Thank You to DAEMANO For This Useful Post:
ATL BRZ (06-08-2014), fuzzy cat (06-09-2014)
Old 06-08-2014, 02:31 PM   #6043
DAEMANO
Time Traveller
Originally Posted by jflogerzi View Post
Robs ESC is great. I was impressed with it from a strictly autocross street setup. But this setup will be no means be trackable at any decent road course. Battery technology is just not there. With other Stg 1 kits this is where the extra money you pay. IMO I was building a nice street canyon carver and auto-X, this is what I build
ECS + 1.5 dump pack
OFT
drop in filter
nameless axleback
new brake pads
new brake fluid
Great mods, @ATL BRZ just came from Yellows and is headed to RC Tarmac 2s:
As far as any decent road course goes, see here:
The Following User Says Thank You to DAEMANO For This Useful Post:
Old 06-08-2014, 02:36 PM   #6044
ATL BRZ
ATL BRZ's Avatar
This is my understanding as well.
Others here seem to think the controller can be cooled which would make it last on track with an extra dump pack. Interesting to hear there are no voltage or recharging rate issues for 20 minute sessions.
I really need to see some in cabin footage of the ESC on a road course to see what the voltage drop is like over a full session to ease my skepticism about a track application. Hearing that they aren't running out of juice early seems questionable and may be the driver's experience coming in to play (not as much time spent in WOT as seasoned track veteran would be). I'd love to see @CSG Mike drive one of your cars at Buttonwillow and see how it performs.
Old 06-08-2014, 02:42 PM   #6045
jflogerzi
jflogerzi's Avatar
I agree. If it can survive CSG_Mike then we know its legit. I have never driven Buttonwillow, but my guess its a smaller course similar to Streets of Willow? Now rob is testing the 4:1 aux charger vs what everyone else has which is 8:1. So that might help substantially at the track.
Old 06-08-2014, 02:44 PM   #6046
DAEMANO
Time Traveller
I really need to see some in cabin footage of the ESC on a road course to see what the voltage drop is like over a full session. Hearing that they aren't running out of juice early seems questionable and may be the driver's experience coming in to play (not as much time spent in WOT as seasoned track veteran would be). I'd love to see @CSG Mike drive one of your cars at Buttonwillow and see how it performs.
The gap is closing fast.
Speaking for myself as an early adopter, I've chose to be part of the development process rather than wait for a perfectly finished product. It's great to be able to contribute. No disrespect, but I wouldn't jump to judge the driving ability or experience of those who I don't know. There are owners at many levels in this thread (even Rob and Shiv have plenty of seat time themselves). I don't need it to be suitable for @CSG_Mike , I need it to work for me. Lastly, once again, this is a street kit that owners are begining to adapt for their own personal usage. Why not jump in and contribute too?
Old 06-08-2014, 02:46 PM   #6047
shif7i7down
Erected Member
Drives: frs
I had a conversion with the dyno operator on Friday because the low whp reading i got during the dyno session was bothering me, and this is what he said, tell me if it makes sense or if he's just bsing.
He said he didn't know what the frs 4th gear ratio was so he didn't want to guess and that the dyno session was done with the expectation that 4th gear is a 1:1 ratio, so if i really wanted to know the calculated 1;1 ratio whp. I have to take my 4th gear ratio(Which is 1.213 btw) and subtract the average 15~17% rwd drive train lost(Which is.15~.17) and multiply it to the dyno number.
That's 1.213-.17 = 1.043 then multiply by my 186whp and it gives me 193.998whp.
The number looks right, but would that be the best way to do it?
Old 06-08-2014, 02:50 PM   #6048
ATL BRZ
ATL BRZ's Avatar
Speaking for myself as an early adopter, I've chose to be part of the development process rather than wait for a perfectly finished product. It's great to be able to contribute. No disrespect, but I wouldn't jump to judge the driving ability or experience of those who I don't know. There are owners at many levels in this thread (even Rob and Shiv have plenty of seat time themselves). Lastly, once again, this is a street kit that owners are begging to adapt for their own personal usage. Why not jump in and contribute too?
Not judging anyone just speaking in general. I would love to contribute but without some empirical evidence and Rob fully supporting the product for track applications I can't buy in. I've been watching the development on this platform closely since the beginning and I want it to become truly "trackable" but right now I'm skeptical and will reserve judgement until some more loyal testers get out and prove us all wrong.
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 05:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 07:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 08:07 AM
