Old 05-31-2014, 12:20 PM   #29
shif7i7down
Erected Member
Drives: frs
Originally Posted by jwvand02 View Post
In the orignal ESC threads they have dynos for someone running OFT+E85... must be custom tuned
That's shiv , he's the one doing the e85 tune for his OFT, no eta yet though but i hope he'll finish fine tuning it soon.
Side note ; i pray to God every night before going to bed "Dear God please help @shiv@vishnu in every way you can so that he'll have time to complete the e85 tune for the phantom supercharger. AMEN"
Correction:that's Sojhinn
shif7i7down is offline   Reply With Quote
The Following 5 Users Say Thank You to shif7i7down For This Useful Post:
enwave (05-31-2014), nlowell (05-31-2014), Sojhinn (05-31-2014), WNDSRFR (05-31-2014), WRB5titch (05-31-2014)
Old 05-31-2014, 04:24 PM   #30
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
That was me, but I am not sure if the tune is safe with the 1.5 pack which is why I'm hesitant to run it on my car currently.
Installed Mods:
Old 05-31-2014, 06:00 PM   #31
nlowell
nlowell's Avatar
Drives: 2013 Scion FRS
For some reason I read your prayer quote in a Kenny (Southpark) voice and it made it even better
nlowell is offline   Reply With Quote
Old 05-31-2014, 06:18 PM   #32
Bu-Tang
Drives: 2013 Scion FR-S, Nissan Pathfinder
Originally Posted by nlowell View Post
You know...catching...cans..
I've read that catch cans are recommended for catching/separating oil on FI and tracked vehicles. Since I track an FI car, I was questioning whether or not this should be on my upgrade list...
I'm running the Crawford AOS, cant really tell you if its doing much lol
On a side note, Rob and I installed a boost gauge on my car, for fun, just shy of 5 with the 1.5 dump pack.... if only I could get past that 5...
Bu-Tang is offline   Reply With Quote
The Following User Says Thank You to Bu-Tang For This Useful Post:
raven1231 (05-31-2014)
Old 05-31-2014, 07:47 PM   #33
shif7i7down
Erected Member
Drives: frs
Max psi i see is 4.5
Old 05-31-2014, 07:59 PM   #34
shif7i7down
Erected Member
Drives: frs
Cartman voice is way better.
Old 05-31-2014, 09:54 PM   #35
Daesondei
Daesondei
Drives: Scion FRS
Hey guys,
Socal member here. I installed my setup with no problems, this is my second day running it and for reasons unknown to me the blower will not blow when switch is engaged. All the wiring is secure and the volt meter reads 28.X. When I press the switch, nothing happens, the volt meter even stays the same with no fluctuations. praying I didn't burn out the kit already... :-/ any suggestions? help a brother out!
Sent from my SAMSUNG-SGH-I577 using Tapatalk 2
"No greater love is this, than a man laying down his life for his friends... I call you friends."
Daesondei is offline   Reply With Quote
Old 05-31-2014, 09:57 PM   #36
Daesondei
Daesondei
Drives: Scion FRS
Add:
Dodge SRT
Full boltons to the list. A friend of a friend told me...
lol
The Following User Says Thank You to Daesondei For This Useful Post:
robwbright (05-31-2014)
Old 05-31-2014, 09:58 PM   #37
Gary in NJ
Gary in NJ's Avatar
Drives: WR Blue BRZ, 240Z
Originally Posted by Daesondei View Post
Hey guys,
Remove the Drag Reduction tube from the intake and suck on it. If the ESC engages you may have a problem with the throttle switch. If nothing happens, you have another issue.
Do you hear they system beeping 5 times when it powers up?
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
Gary in NJ is offline   Reply With Quote
Old 05-31-2014, 10:22 PM   #38
Daesondei
Daesondei
Drives: Scion FRS
thanks for the quick response. I just tried it, still nothing. unit does not beep.
Old 05-31-2014, 10:51 PM   #39
Sojhinn
Sojhinn's Avatar
Double check your wiring and make sure you covered all the steps.
When you are removing the drag reduction tube make sure you remove it off the intake. And then blow and suck on it.
Grab a friend and have them listen in the hood. Start the car and see if he/she hears the beeps.
Installed Mods:
Old 05-31-2014, 11:09 PM   #40
robwbright
Drives: '13 BRZ Limited WRB Phantom ESC 1.5
Originally Posted by WNDSRFR View Post
If anyone is in the Cocoa area, just PM me and we can make arrangements to get together.
My family and I will be in Orlando area in early October.
'13 BRZ Ltd MT WRB Phantom ESC 1.5
2012 Honda Accord Coupe
2006 Saab 9-3 2.0t
1997 Honda Accord Coupe
1995 Honda Prelude VTEC
robwbright is offline   Reply With Quote
Old 05-31-2014, 11:17 PM   #41
robwbright
My brother in law owns a '13 Genesis Coupe 6cyl. He had driven my car stock and I let him drive the ESC 1.5 today. He was very impressed. By my own admission, my modded car still does not accelerate as fast as his stock car (he is around 9.5 pounds per HP and ours are around 11.25 pounds per hp, I think)... but he was pretty amazed at the difference. I believe his comment was "this is exactly what the car needed... now you have a great handling car that gets up and goes. Now that I see how simple that is, I want to put it on my car."
He wonders if he could get up to or over 400 crank HP. Has anyone tried an ESC on the Genesis?
2006 Saab 9-3 2.0t
Old 06-01-2014, 07:26 AM   #42
Gary in NJ
Gary in NJ's Avatar
If there isn't any beeping at the blower, there is a disconnect between the controller and the blower. Check to make sure that the three wires are properly seated. If that doesn't cure it, call Rob so he can trouble-shoot your controller.
Jackson Racing Supercharger Owners Thread enivid Forced Induction 6049 06-25-2026 10:40 PM
Full throttle Electric Supercharger Build Thread fenton Forced Induction 11315 04-07-2025 06:42 PM
Kraftwerks Supercharger Owners Thread projek_01 Forced Induction 4310 04-07-2025 01:12 PM
phantom supercharger restrictions? Shinigunz Forced Induction 12 05-13-2014 03:28 AM
Drift-Office : Phantom Supercharger - Tuned! Drift-Office Forced Induction 67 10-25-2013 09:51 AM
