Old 05-25-2014, 09:36 PM   #15
SportInjected
SportInjected's Avatar
Drives: for the sake of driving
Originally Posted by mothespaceman View Post
While it was still in the air, do you think that might be the cause?
Typically you should tighten those bolts down with the car on the ground (suspension is loaded), so the bushing doesn't twist. Worth a shot, since it doesn't take a lot of time and it's free.
'13 Argento FR-S
SportInjected is offline   Reply With Quote
The Following User Says Thank You to SportInjected For This Useful Post:
mothespaceman (05-27-2014)
Old 05-25-2014, 10:05 PM   #16
JerryMichaels7
Drives: Whiteout FRS
I was a big dummy when I installed mine and was messing with them and took the preload out. I put it back in but not enough. Put a little more in and the noise stopped
life's greatest stories usually start with the words, "fuck it!".
JerryMichaels7 is offline   Reply With Quote
The Following User Says Thank You to JerryMichaels7 For This Useful Post:
Old 05-25-2014, 10:07 PM   #17
mothespaceman
mothespaceman's Avatar
Drives: 2014 BRZ SWP
@JerryMichaels7 did you have similar noises? I DO have preload, maybe not enough?
mothespaceman is offline   Reply With Quote
Old 05-26-2014, 12:25 AM   #18
FastWhite
Drives: Subaru BRZ Limited M/T
When I installed my Koni's I did by lowering the LCA. The car has to be on the ground to torque the bolts to 59 ft/lbs. OR use another floor jack and jack up just the assy and then torque it down. You would jack it enough to simulate on the gnd condition.
Haven't had any problems.
FastWhite is offline   Reply With Quote
The Following User Says Thank You to FastWhite For This Useful Post:
Old 05-27-2014, 08:12 PM   #19
mothespaceman
After going over preload, attempted re torques and pulling all of my hair out, I was able to call Fortune Auto and get some insight.
They told me that due to the car being lowered to the degree that it is, it's likely that all of the suspension bushings need to be re indexed to accommodate the new geometry. I'm bringing the car to All Pro Subaru tomorrow in hopes that they can just fix it!
Old 06-26-2014, 04:05 PM   #20
mweidner311
Drives: N/A
Did Allpro help you out? I'm actually located in ATL area and was looking to check those guys out for an alignment after my new suspension
I am also looking at purchasing these coilovers. How low did you go? How low can they go? Are you liking them?
Thanks dude
mweidner311 is offline   Reply With Quote
Old 06-27-2014, 02:00 PM   #21
mothespaceman
Thanks dude
Hey dude, while Allpro is great, that is definitely not the go-to place for suspension work. I highly recommend Gran Turismo East in Chamblee, they are performance suspension and alignment pros.
These coils are by far the best bang for the buck... aside from the noises that were occurring they have been great. They can go pretty low too, right now I'm probably at a 340-345mm ride height with room to go down if needed.
The Following User Says Thank You to mothespaceman For This Useful Post:
mweidner311 (06-27-2014)
Old 06-27-2014, 02:08 PM   #22
mweidner311
Drives: N/A
Nice! Thanks for the info on the FA's and also the huge tip on Gran Turismo. I'll take it there soon I installed camber bolts last night to use with the sportlines Im running now until I decide on a coilover set
I'm new to GA in general and have no experience with any performance shops down here so thanks for helping me out I always worry having anyone else work on my baby but a good recommendation always helps ease my anxiety
Have a good weekend dude and thanks again!
Old 06-27-2014, 02:09 PM   #23
mweidner311
Drives: N/A
Great just google them they're inside the perimeter too that's way way closer than allpro!
Old 06-27-2014, 05:10 PM   #24
mothespaceman
There's only THREE places to take this car in the metro Atlanta area that are worth your time.
Topspeed Motorsports
Allpro Subaru
Gran Turismo East
mweidner311 (06-30-2014)
Old 11-07-2014, 01:36 AM   #25
sittinSideways
sittinSideways's Avatar
Drives: '13 Firestorm FRS
Did you ever fix it?
@mothespaceman
sittinSideways is offline   Reply With Quote
Old 11-07-2014, 11:10 AM   #26
mwjcyber
mwjcyber's Avatar
Drives: 13' Subaru BRZ Limited SWP 6MT
I have Fortune Auto 500's, and they're awesome (had KW V3 on my VW Corrado, so know how good coilovers perform).
So as for topic, mine made same noise. Fix ended up being Swaybar link bolts on LCA needing to lose until torqued on the ground.
Build Thread: Breaking-Bad SWP Build
OFFICIAL NM.FT86CLUB Facebook Page
mwjcyber is offline   Reply With Quote
Old 11-15-2014, 05:59 PM   #27
mothespaceman
@mothespaceman
I did! Apologies for not updating this, it wasn't the coil at all... one of the control arm bushings was making the noise. Cusco LCA's + alignment fixed it!
sittinSideways (11-16-2014)
What Fortune Auto Is All About Jason@DSG Suspension | Chassis | Brakes -- Sponsored by 949 Racing 24 05-23-2014 10:23 AM
WTB: Fortune Auto 500 V5 Cjymiller Want-To-Buy Requests 0 02-26-2014 08:58 PM
ST VS Fortune Auto 500's damaster32 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 02-09-2014 08:08 PM
Fortune auto coilovers 256brz2013 Brakes, Suspension, Chassis 7 07-09-2013 12:08 PM
Fortune Auto vs BC Racing D1cker Suspension | Chassis | Brakes -- Sponsored by 949 Racing 14 09-11-2012 11:18 AM
