Old 05-18-2014, 02:28 AM   #29
Fly Guy
Fly Guy's Avatar
Drives: '91 MR2
Nice wheels! Can anyone confirm if the details are silver or white?
Tada-san: Oh so cooler than the concept.
Fly Guy is offline   Reply With Quote
Old 05-18-2014, 08:27 AM   #30
Anorexic 86
Trim the Fat & add Boost
Anorexic 86's Avatar
Drives: sometimes I fly
Looks white under bright lights, but is actually machined silver... no paint.
Anorexic 86 is offline   Reply With Quote
Old 05-18-2014, 08:28 AM   #31
Anorexic 86
Originally Posted by jdmblood View Post
pics of them on an 86??
No one else has them... yet.
If someone does... POST THEM HERE!!!
Old 05-20-2014, 09:15 PM   #32
puma
crew chief
puma's Avatar
Drives: Race car FR-S
well i said i would post pics so here they are, not on the car though and it will take a while before i do, race car build in progress, i am in a wiring nightmare right now.
For those wondering, the inside is silver, it is just machined in fact but under strong light it does kind of look like white. That would be a good place to paint though to give the same accent as your car's color... guess what we will do
anyway, we used to run Enkei RPF1 on our race car but the bolt pattern isn't the same so we can't reuse them, we needed new wheels and decided to try something else.
So here is a little comparo with the RPF1. First, they are both the same spec, just different bolt pattern, 17x9 Et +35
The RPF1 weight 15,6 lbs
the GPF1 weight 16,8 lbs so this is a 1,2lbs advantage for the Enkei.
Price, well the GPF1 is litterally half price.
The finish is good, they are made in China but they still look good.
They are a tiny bit wider. The lip on the outside is thicker and seems more solid. The RPF1 are weak and break easily with such a low weight, let's hope the GPF1 are more solid. GPF1 also have dual tire valves, this will help in the pit taking quick pressure. I wish they would offer them in different color though like silver at least.
puma is offline   Reply With Quote
The Following 11 Users Say Thank You to puma For This Useful Post:
Anorexic 86 (05-21-2014), chris x sway (05-22-2014), DAEMANO (05-20-2014), Fly Guy (05-21-2014), GaN-MaN (05-21-2014), hmong337 (05-21-2014), JonAvalon (05-20-2014), mit_peid (05-22-2014), paddleshifter (05-22-2014), Pekingduck (05-23-2014), SWPinATL (05-20-2014)
Old 05-21-2014, 02:53 AM   #33
Anorexic 86
Thanks puma!
Weight list updated...
Old 05-21-2014, 11:51 AM   #34
stockysnail
Just the tip
stockysnail's Avatar
Too bad the hub bore isn't correct. Hub center rings are needed from Amazon, which are cheap.
Old 05-22-2014, 10:38 AM   #35
chris x sway
chris x sway's Avatar
Drives: 2014 FR-S in Mayonnaise
I might get these, do you know the correct size rings needed?
Thanks in advance.
chris x sway is offline   Reply With Quote
Old 05-22-2014, 11:55 AM   #36
stockysnail
Just the tip
Thanks in advance.
Aluminum hubcentric rings 73.1mm OD to 56.1mm ID. You can put that right into Amazon and it will come right up.
Plastic ones will crack and break easier so I went with metal.
The Following User Says Thank You to stockysnail For This Useful Post:
RehabJeff86 (05-25-2014)
Old 05-22-2014, 01:00 PM   #37
steveoexige
Drives: UK GT86 in White with alcantara
Hello mate, I'm looking to run these alloys too and have been wondering on the hubcentric ring sizes. Can you post up a link to the Amazon product you use pls?
Cheers.
steveoexige is offline   Reply With Quote
Old 05-22-2014, 02:27 PM   #38
stockysnail
Just the tip
Cheers.
[ame="http://www.amazon.com/pieces-Hubcentric-73-1mm-Aluminum-Hubrings/dp/B00CH8MDNA/ref=sr_1_1?ie=UTF8&qid=1400779642&sr=8-1&keywords=Aluminum+hubcentric+rings+73.1mm+OD+to+ 56.1mm+ID"]Amazon.com: 4 pieces - Hubcentric Rings - 73.1mm OD to 56.1mm ID - Aluminum Hubrings: Automotive[/ame]
Old 05-22-2014, 03:34 PM   #39
johnnyfast11
Drives: none yet
where to order these rims?
johnnyfast11 is offline   Reply With Quote
The Following User Says Thank You to johnnyfast11 For This Useful Post:
Old 05-23-2014, 04:11 PM   #40
juanmedina
Drives: WRX
More pics please, I would like to see how concave they are...
Thanks.
juanmedina is offline   Reply With Quote
Old 05-23-2014, 06:05 PM   #41
steveoexige
Mine hit the tarmac at Gatwick airport, London next week. I went with 18x9 and I'll post some pics asap.
The Following User Says Thank You to steveoexige For This Useful Post:
DAEMANO (05-24-2014)
Old 05-25-2014, 03:35 AM   #42
RehabJeff86
RehabJeff86's Avatar
Drives: 2013 WhiteOut FR-S
No 5x100??
2013 Scion FR-S whiteout
2012 Porsche Panamera S carbon grey
2008 Range Rover Sport SS black - sold
2004 BMW M3 alpine wies - sold
RehabJeff86 is offline   Reply With Quote
BUDDY CLUB Lightweight Racing Wheels - JDM, lightweight, low pricetag | 18x8.5" GuerillaRacing Wheels and Tires 116 01-20-2015 07:32 PM
FT86 Canada HRE Flow+Form - SimplyTire 2014 Zook@SimplyTire Canada Classifieds 4 06-07-2014 12:05 PM
Your Top Three Form of Automotive Racing, From Two to Ten Wheels. LBC Por Siempre Other Vehicles & General Automotive Discussions 14 02-24-2014 12:09 PM
New SSR Flow Formed wheels available for FRS - Not bad on price! ModBargains.com Wheels and Tires 21 01-13-2014 12:27 PM
Lightweight wheels or wide wheels Moetivegt86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 28 11-06-2013 11:57 PM
