go_a_way1
Old 05-14-2014, 10:02 AM   #2353
Gt86_nick
Drives: Scion FRS asphalt
Originally Posted by Amir Ghadiri View Post
It should work with your stock suspension, but it will poke quite a bit. Once lowered you will need to make camber adjustments. What size tire do you plan to run?
That was going to be my next question. I'm looking for a little bit of a stretch not a whole lot what size tire would give me a decent stretch on a 8 inch rim? Also how much camber would I need?
Gt86_nick is offline   Reply With Quote
Old 05-14-2014, 11:08 AM   #2354
mkivalex
Drives: 13 Scion FRS, 93 JDM Toyota Supra
Im looking at doing a set up in
18x9.5 ET 35 with somewhere between a 245-265/35/18
I will be running coilovers and will accept some negative camber.
Looking for an "aggressive but functional set up" I've seen Jive Turkeys set up with 18x9.5 ET 40 265/35/18....is there room to get an extra 5mm of offset in there without too much issue.
Im open to fender rolling. but no pulling.
mkivalex is offline   Reply With Quote
Old 05-14-2014, 12:48 PM   #2355
Amir Ghadiri
Amir Ghadiri's Avatar
Originally Posted by subaruferrucci View Post
reason i am doing it isnt because i can fit them but because i am hard up on money and buddy is giving me a set for free
Give it a try. Worst case, it'll rub on suspension and you'll be forced to run a small spacer, perhaps 3-5mm. It will be close, but should work.
You won't be able to lower the car much though, you'll have to run your coilovers at close to stock height. It'll be functional
Amir Ghadiri is offline   Reply With Quote
Old 05-14-2014, 12:57 PM   #2356
Amir Ghadiri
Will this fit? (width, offset and tire size Qs)
Originally Posted by damaster32 View Post
anyone running falken ze-912 265/35/18, I'm trying to see if the falkens run bigger then other brands.
Any fender mods needed for 18x9.5 38mm? running 265/35/18 or should I go with 255/35/18
Thanks
I've run both Falken Azenis FK453 and Azenis RT615K in the 265/35-18 size. My wheels are also 18x9.5 +38. It is a very aggressive fit but will work.
At stock height, you won't rub. Lowered ~1.5", you will need a moderate fender roll in the rear and a small amount of negative camber adjustment in the front. Lowered ~2-2.5", the rear will need a very aggressive roll. The front won't need more camber but will have a very slight rub on hard cornering.
A 255/35-18 will make your life a bit easier, but I'd still go with the 265 if I were you
I recommend coilovers, but either setup (255/265) will clear stock suspension.
Old 05-14-2014, 01:21 PM   #2357
Amir Ghadiri
The stock 215/45/17 tire size should work great for what you're looking for. It'll give you a little stretch but nothing major.
Sorry, but I'm not too sure what you'll need as far as camber. I don't have much experience with your wheel specs. Based on what I do know, you will need minimal camber adjustment, but you will need it on all four corners. Camber adjustable front top hats and rear lower control arms should be enough.
Old 05-14-2014, 01:36 PM   #2358
Jyn
Noob
Jyn's Avatar
Drives: FR-S Mammogram
Got some 18x8.5 +27 and 18x9.5 +26. Plan on getting some KW v3 and lowering to close the wheel gap, but not slam. Will I need a lot of camber? LCA? Camber bolts? etc. Looking to get everything purchased before installing and getting an alignment. Thanks!
Jyn is offline   Reply With Quote
Old 05-14-2014, 01:44 PM   #2359
Amir Ghadiri
A 245/35-18 will fit no problem, but is not enough tire IMO.
A 255/35-18 will fit will minimal camber adjustments, front and rear. The fenders rear will need to be rolled, how much depends on how low you want to go.
A 265/35-18 will fit, but it'll need ~3-3.25 degrees of negative camber on all four corners and an aggressive roll in the rear.
You would achieve the best fitment with a 38-37 offset.
Old 05-14-2014, 01:45 PM   #2360
Amir Ghadiri
Tire specs?
Old 05-14-2014, 02:08 PM   #2361
Jyn
Noob
Jyn's Avatar
Tire specs?
Oh yeah, should've added I was looking for tire options too. They're on 205/40 and 215/40 right now, but I want to put as meaty as a tire as possible. I was thinking maybe 215 front and 235 rear, but test fitting it on a stock suspension last weekend, I'm not sure that would work without ridiculous camber...
Old 05-14-2014, 02:52 PM   #2362
ilpad
ilpad's Avatar
Drives: 2013 - Scion FR-S in White"red"out.
I run 18x9.5e38 with 255/35/18s dropped 1.5 inches with no camber in the fronts and negative 1.6 degrees in the rears with no fender roll and no rub. My fronts sit 3mm from the spring perch.
So the answer is they fit just fine.
ilpad is offline   Reply With Quote
Old 05-14-2014, 08:21 PM   #2363
gl2filmerguy
gl2filmerguy's Avatar
Drives: 2013 Ultramarine FR-S
I'm looking to get 18" Work Meister S1's. I am going to be lowering my car at LEAST 1-1/2". I would like to get it "Flush" more than having it poke out and look odd. Can someone please help me with what offsets I should get for front and rear? THANK YOU!!
gl2filmerguy is offline   Reply With Quote
Old 05-15-2014, 05:25 PM   #2364
Gt86_nick
Which offset to go with
So after looking around I had a change of heart from the bbs' don't really want to put that much into a lease. I'm currently looking at a pair of work xd9s 18x8. I had read here that +34 would make me flush but I was playing around on the auto fitment calculator here and the +35 option looks to be a little tucked still it looks like the +28 option would make it flush. Also I plan on lowering on h&r super sports -1.2f and -1.6r drop
Old 05-16-2014, 09:23 AM   #2365
cncnjn
Drives: Raven FRS Veilside Nissan 350z
I was looking at wheels, my car is lowered about 1in 1/2 all around, the wheels im looking at are 18x9.5 with either +30 or +38 offset, which one would give me a better flush fitment? Should i go +30 in front +38 in back? Vice versa? Let me know, thanks.
cncnjn is offline   Reply With Quote
Old 05-17-2014, 01:27 AM   #2366
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
Drives: '13 Whiteout FR-S A/T
Perhaps it's a camber and fitment question, but currently I have 17x8 +48's on stock Michelin 215 Primarcy's up front.
I want to go up to 235/40, but am concerned about rubbing with -1 or -1.5 camber on stock suspension. It appears that this is OK, but bumping my question anyhow.
drewbot is offline   Reply With Quote
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 10:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 03:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 03:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-13-2012 12:21 AM
