| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
#127 | |
Delights in pure handling
Drives: Zoom Zoom
#128 |
Drives: 2010 Evo X MR-T
yes, basically. i believe porsche/borg warner use proprietary materials and that's why they're the only ones who use variable vanes. and even then, there are stories of the vanes failing...
#129 | |
Drives: 04 BMW 330i & 03 Mazdaspeed Protege
I think most aftermarket turbo setups are affected by the narrow range problem as they are usually targeted at a specific purpose and are limited by what the factory setup on the car is. On a factory turbo charged car, if something isn't the way they want it they can just move it unlike in the aftermarkt. |
#130 | |
Kuruma Otaku
I heard "VNT" and offered him $50 for the old one, wanting to see what a Garrett variable geometry system was/how it worked. Didn't know the damned thing was attached to the manifold... My understanding is that Garrett's is only a single big vane and is the least efficient (lots of turbulence) of the variable geometry setups. Second best I've heard is the Mitsubishi which is similar but two vanes that open sequentially and 'backwards' compared to Garrett's VNT. Supposed to be very efficient and very reliable. Is this on USDM Evos? It is apparently on certain JDM models. Porsche's multi-vane is supposed to be the best performing. The twin-scroll thing puzzles me as to why it is even a buzz-word. My understanding is that it is just a twin-entry divided turbine, the same as Toyota was using with the CT26 ~25 years ago, or am I missing something?
Because titanium. |
#131 |
Drives: '06 AM V8V Coupe
Dimman you're correct, twin scroll means divided turbine housing nothing more.
There's a difference between "consistent power across the rev range" and "best power at high rpm". The reason BMW is able to achieve high boost at low rpm is that their turbo had low-midrange focus, since they don't use variable vanes (or do they?). At any rate, just looking at a dyno chart you can see that the torque is flat probably because the boost is being limited, and the dying high end power points to that conclusion as well. |
#132 | |
the honorable mention, in recent memory, goes to the Acura RDX K23 which used a variable turbine housing, but not variable vanes a la porsche. as for twin scroll, yeah thats nothing new as well. but companies like BMW try to sell it like it is. they went from twin turbo N54 to the "twin power" N55 single twin scroll turbo. |
#133 |
Kuruma Otaku
RDX system reminds me of the 'DIY variable geometry' of the Quickspool valves that a few Supra guys have been using for a while. Uses a twin scroll turbine but manifold is set up as single entry, but a butterfly valve is on one of the scroll entries...
Because titanium. |
#134 |
Drives: Toyota
Drive the M3 E92 and then drive the 335i E92. You'll see how much lag it has. And unlike what people say, the S65 has a very flat torque curve with redline at 8.400 RPM.
#135 | |
Drives: 1995 F150
#136 |
Drives: BRZ WRB
Tomorrow I will bee meeting & interviewing the President of STI
Hiroyuki Karamatsu -san ![]() I will try to get some details of the STI BRZ, which he would be able to unveil "Wheeers the terrrrrbo?" - is definetely on top of my questions ) |
| The Following 8 Users Say Thank You to MSTiFK8R For This Useful Post: | coyote (08-27-2012), DarthNads (08-28-2012), Guff (08-27-2012), houseofsuffering (08-28-2012), industrial (08-27-2012), tomato86 (08-30-2012), tomt5078 (08-27-2012), YW-Slayer (08-28-2012) |
#138 |
That sounds like it's just an easier way to get "variable geometry" than having movable vanes, but the divided housing is useless if the exhaust pipes all merge together before it.
#139 | |
Kuruma Otaku
It will have flow losses compared to either a fully open single or twin, but they do improve spool. Remember this is a 'DIY'-type solution, not from major turbo companies.
Because titanium. |
#140 |
Kuruma Otaku
Turbo ga, doko desu ka?
Because titanium. |
| The Following User Says Thank You to Dimman For This Useful Post: | MSTiFK8R (08-27-2012) |
| Report: 6000 BRZ coupes for 2013 model year! | ahausheer | BRZ First-Gen (2012+) — General Topics | 90 | 03-18-2012 07:43 PM |
| Hi-res pics & list of BRZ JDM model grades from stripped down base model to STI(?) | switchlanez | BRZ First-Gen (2012+) — General Topics | 68 | 02-14-2012 08:16 AM |
| Report: Subaru Coupe STI Model Possible, But Without Turbo | Hachiroku | BRZ First-Gen (2012+) — General Topics | 168 | 07-28-2011 11:03 PM |
| Report: Baby Toyota FT-86 also in the works | Hachiroku | Scion FR-S / Toyota 86 GT86 General Forum | 60 | 05-17-2010 08:41 PM |
