go_a_way1
Old 05-10-2014, 01:10 PM   #2339
FRStock
Drives: 13 FRS
17x7 +50 wrapped in 225/45 on stock suspension? I think it might be close. Probably going with g-Force rivals or Dunlop zii. Track/autox only.
FRStock is offline   Reply With Quote
Old 05-11-2014, 12:10 PM   #2340
FAER
Drives: Silver BRZ
18x9.5 +38
265/35
St coil overs 1-1.5" drop
I'm not a fan of camber so I'd like to keep that minimal
Looking for no rub
FAER is offline   Reply With Quote
Old 05-11-2014, 09:11 PM   #2341
jshadeck
jshadeck's Avatar
Originally Posted by FAER View Post
18x9.5 +38
265/35
Looking for no rub
Ull be good
jshadeck is offline   Reply With Quote
Old 05-12-2014, 12:56 PM   #2342
djdnz
1337
Drives: 2013 BRZ WRB S/C
18x9.5 +38
265/35
Looking for no rub
It will poke in the front without camber, but it will fit.
djdnz is offline   Reply With Quote
Old 05-12-2014, 02:02 PM   #2343
FAER
Drives: Silver BRZ
i wish i could have 0 camber, 0 poke and 0 rub...
sadly i can only have 2 of the three it seems
Old 05-12-2014, 02:26 PM   #2344
subaruferrucci
Drives: FR-s
will 275x40 R17 fit on my car with Coil overs on RPF1 17x9 +45?
subaruferrucci is offline   Reply With Quote
Old 05-12-2014, 08:52 PM   #2345
Gt86_nick
Drives: Scion FRS asphalt
I'm looking into a set of bbs rs' 17x8 +20 I understand 34 is flush. Would a+20 give me quite a drastic poke and would this even work with stock suspension? I plan on getting coils soon so not too much of a big deal if not
Gt86_nick is offline   Reply With Quote
Old 05-13-2014, 08:47 PM   #2346
b rawr z
b rawr z's Avatar
Drives: 2014 BRZ, 2008 Impreza
Hi everyone. Im looking at 18x9 +25 and was wondering if it will fit without camber but I am getting coilovers with them to lower a bit. Also whats a good tire size for them?
I appreciate any help. Thanks.
b rawr z is offline   Reply With Quote
Old 05-14-2014, 02:49 AM   #2347
Amir Ghadiri
Amir Ghadiri's Avatar
It'll depend on your tire size. With a stretch you might be able to pull it off without making camber adjustments. If you're going to run a 255 size tire, which would be proper for a 9" wheel, you will need to make camber adjustments. It won't be too major, but you will need front camber plates and rear lower control arms. How much camber you need will depend largely on how much you want to lower the car.
Amir Ghadiri is offline   Reply With Quote
The Following User Says Thank You to Amir Ghadiri For This Useful Post:
b rawr z (05-18-2014)
Old 05-14-2014, 02:52 AM   #2348
Amir Ghadiri
It should work with your stock suspension, but it will poke quite a bit. Once lowered you will need to make camber adjustments. What size tire do you plan to run?
Old 05-14-2014, 02:56 AM   #2349
Amir Ghadiri
275/40 is a lot of tire for a 9" wheel. My concern is that it may rub on your coilovers, but I don't know for sure. I like the fact that you're trying to fit as much tire as you can though
Old 05-14-2014, 02:57 AM   #2350
Amir Ghadiri
18x9.5 +38
265/35
Looking for no rub
It'll fit with stock rear lower control arms but you will need to roll your rear fenders. You will need a slight (minimal) amount of camber in the front.
Your wheel size/tire size/offset are pretty much perfect IMO, same as my own
Old 05-14-2014, 06:30 AM   #2351
subaruferrucci
Drives: FR-s
reason i am doing it isnt because i can fit them but because i am hard up on money and buddy is giving me a set for free
Old 05-14-2014, 08:41 AM   #2352
damaster32
Drives: 2014 BRZ Limited
anyone running falken ze-912 265/35/18, I'm trying to see if the falkens run bigger then other brands.
Any fender mods needed for 18x9.5 38mm? running 265/35/18 or should I go with 255/35/18
Thanks
damaster32 is offline   Reply With Quote
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 10:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 03:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 03:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-13-2012 12:21 AM
