#1093 | |
AutoX Nut
Drives: 2022 BRZ
He's running staggered BFG Rivals (Front: 225/45; Rear: 245/40). The 245/40 Rivals on the rear didn't seem to slow him down at the Wilmington Match Tour. Not sure how 245/40 Rivals would feel on the front, but it might be worth a shot! Especially for contingency purposes. Edit: Upon further review, it appears you were there with him in your RX-8, so you may already know all of this....ha, ha! |
#1094 | |
The MCS shocks I'm sure use more nitrogen pressure than stock so the effective spring rate is higher. I ran them around 115 PSI cold. |
#1095 | |
i'm sorry, what?
Drives: Canada
travel, which given my previous math would require roughly 700lb of weight transfer to use up (highly unlikely in a controlled environment) the question was how often they are engaged?.... also, what was the highest that the ziptie moved from the base of the damper after a day of driving?
#1096 | |
Drives: 13 SWP BRZ
I thought I heard some rub at lock when I first put them on, but didn't notice it again after ~250 street miles and 12 autox runs. /shrug |
#1097 |
Drives: Some kind of Subaru
My co-driver and I finally got to try our 245/40/17 RS3 Version 2 this weekend. It was 70-71 degrees, sunny, and VERY WINDY (the ground stayed cold). Tire temps reached about 105 degrees at most, but there was still a lot of grip. We found the tires pretty responsive, too. We still need to make more adjustments now that we have A LOT more lateral grip. Overall, we were happy we went this route
#1098 | |
DBC Racing
thanks!
#194 SM
#1099 |
If anyone is needing B6s or Koni Yellows, now is the time. Both are running really good sales. You can message me for more details.
I went with the konis because Im cheap, looking back, shouldve done the B6 probably. |
#1100 |
I've never driven on the old compound before since before this car I was a single driver and always has Star Specs/Z2's. My co-driver has driven on the old compound. Both of us felt there was good grip when cold. My co-driver said there's definitely more grip in the Version 2's cold and we'd have been sliding around on the old compound. It helped to daily the tires for a bit before the event to scrub the tires.
The Following User Says Thank You to G_Ride For This Useful Post: | itzmik3 (05-05-2014) |
#1101 |
Drives: 2013 Asphalt Scion FR-S
I have uploaded my full video of the Sunday morning runs at the Mineral Wells pro solo this past weekend. I think Drew does a good job in the background with the announcing to help tell the story of the come from behind win in CS.
[ame]http://youtu.be/t_s5WIAnVLo[/ame] |
The Following 4 Users Say Thank You to chucky12012 For This Useful Post: |
#1102 |
Drives: 2013 WRB BRZ
Congrats! Well deserved after the car trouble you had at Texas Championship Tour last March. Good job also considering that you were up against the 370Z that won C-Stock Nationals last year (driven by its new owner).
The Following User Says Thank You to autoXracer For This Useful Post: | chucky12012 (05-06-2014) |
#1103 |
Drives: Subaru
Here are my runs from the NJ Championship tour. I drove horribly on day 1 going too hot into some sections.
I was able to clean it up on day 2 but still could not get close to the Mark Andy. Still have a lot to learn to be able to drive faster. Day 1: [ame="https://www.youtube.com/watch?v=reOv9AmFHqM"]NJ Championship Tour - Day 1 #67 CS - YouTube[/ame] Day 2: [ame="https://www.youtube.com/watch?v=unu8gQwB0rg"]NJ Championship Tour - Day 2 #67 CS - YouTube[/ame] |
#1104 | |
Drives: SWP BRZ
I was also clearing with Rota 17x8 +48 and crash bolts and same tires.
SWP BRZ
#1105 |
Dodging cones
Drives: 2013 BRZ Limited, 93 Z28
Calling @Sccabrz192
Googling some shirts,I found this - http://www.redbubble.com/people/thej...rid&style=mens Interesting story behind this?
#1106 | |
Detroit Region, MI
Drives: 13 BRZ, 13 Volt, 02 WRX
http://www.redbubble.com/people/thej...rk_portfolio_1 And no, not really. Just an idea... taken to the next level about 15 different times over beers. Apparently this infinity shirt thing is a trend now?? ![]() You should definitely buy one and wear it to the Toledo Pro.
Detroit / NWOR SCCA Member
2005-06: #192 ES 91 MR2 N/A Hardtop 2007-08: #54 STX 05 WRX Sedan 2009-12: #92 BSP/ASP 07 Solstice GXP 2013-14 : #192 CS 13 Subaru BRZ |
Cinco De Mayo SCCA SOLO | Ryeong86 | NY / NJ / CT / PA | 0 | 04-23-2013 05:22 PM |
Koni Sports in SCCA SOLO | Ryeong86 | Tracking / Autocross / HPDE / Drifting | 4 | 04-22-2013 12:58 PM |
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule | Scooby South | Tracking / Autocross / HPDE / Drifting | 13 | 12-05-2012 08:08 AM |
Houston SCCA Solo #9 - 5 FRS, 1 BRZ | hankster | Tracking / Autocross / HPDE / Drifting | 0 | 10-09-2012 01:35 PM |
SCCA Solo Car Class for the FR-S/BRZ? | MrVito | Scion FR-S / Toyota 86 GT86 General Forum | 31 | 06-15-2012 10:03 AM |
