Old 05-07-2014, 03:39 AM   #15
jvargasj88
jvargasj88's Avatar
Drives: 2013 Toyota 86 TRD - Galaxy Blue
19" Rays 57Xtreme / Achilles ATR Sport 2 Tires
19" Rays 57Xtreme (8.5/9.5) / Achilles ATR Sport 2 Tires (245-35-19/275-30-19)
Purchased and Installed at: AutoPlus
When I installed these rims and tires, the height increased by about 2 inches which was too high for my liking. It definitely needs a drop. However, for some reason the ride comfort became smoother One thing to note as well is that the grip of the Achilles tires are amazing! The grip level would probably be close to the more expensive high-performance tires at an affordable price.
The Rays Center Caps were not included, so I needed to order them separately which took about a month to arrive.
jvargasj88 is offline   Reply With Quote
Old 05-07-2014, 04:10 AM   #16
jvargasj88
jvargasj88's Avatar
Tein H-Tech Lowering Springs
Since I was advised that if I go lower than 1.2 inch, my OEM shocks may have a tendency to break. Therefore, I decided to go with Tein High-Tech Lowering Springs since it was advertised to drop the car by an inch in the front and 0.6 inch in the rear with great ride comfort using OEM shocks. A few people have also recommended it to me as they haven't experienced any problems with it so far.
Purchased and Installed at: Autokozmetix
The ride height became better, however it was still a bit too high for me. In terms of ride comfort, it was pretty much close to stock but became a bit more bouncy.
Old 05-07-2014, 04:26 AM   #17
jvargasj88
jvargasj88's Avatar
Toyota GT86 Emblem / Center Console Armrest / 86-BRZ Club Philippines Sticker
Got an OEM GT86 Emblem, which are usually equipped on the European versions of the 86.
Toyota GT86 Emblem
Center Console Armreset
Purchased: Group Buy
86/BRZ Club Philippines Sticker
Purchased: 86/BRZ Club Philippines
Ray's Center Cap
Purchased: AutoPlus
The Following User Says Thank You to jvargasj88 For This Useful Post:
AG3NT_5CARFAC3 (07-22-2015)
Old 05-07-2014, 04:48 AM   #18
jvargasj88
jvargasj88's Avatar
Dynamics Performance Engineering Coilovers
So after 300-400km of driving with the H-Tech springs, my rear right shocks blew Since I wanted to drop the car even more but had a budget constraint, I purchased Dynamics Coilovers (which many say are comparable to the BC Coilovers).
With these coilovers, cornering improved greatly compared to the OEM or lowering springs. My only problem was the ride comfort. With the kind of roads we have in Manila, it feels like you are going through a war zone every time I take it out (even when the dampening setting was set to full soft for both the front and the rear), which bothered me a lot There are also some noise coming from the coilovers when passing through uneven roads, but its not that loud.
The stance looked great once installed though:
Old 05-07-2014, 07:41 AM   #19
jvargasj88
jvargasj88's Avatar
TRD Body Kit / TRD Rear Diffuser Set / TRD High Response Muffler (Ver.R)
It took a week to order and paint the TRD kit. They also had to keep my front tow hook cover in order to ensure that when they mix the paint it would exactly match the color of my car. Here are some pictures during the installation:
TRD Front Spoiler
Purchased and Installed at: Toyota Global City
TRD Side Skirt
In order for the rear skirt and exhaust to fit, they needed take apart the rear bumbler and cut a portion of it ouch!
TRD Rear Under Spoiler
Purchased: TRD Global City
Installed: Autokozmetix
As described by TRD, the Rear Diffuser is used to "effectively draw air from under the vehicle towards the rear to control the lift generated by high speeds, while improving straight line stability by using its four fins to control air flow."
The exhaust sounded great, it was just a bit louder than stock which was perfect since I was afraid that it would be too loud.
Old 05-07-2014, 08:19 AM   #20
jvargasj88
jvargasj88's Avatar
Before (Stock) and After Pictures
Here are some before and after pictures of the TRD body kit
Front View (Before)
Front View (After)
Side View (Before)
Side View (After)
Rear View (Before w/ TRD Trunk Spoiler)
Rear View (After)
Old 05-07-2014, 08:43 AM   #21
jvargasj88
jvargasj88's Avatar
ST Coilovers by KW
I decided to upgrade my suspension since I couldn't stand the ride of the Dynamics coilovers anymore, it was too harsh. I initially wanted the KW V3 Coilovers since they have a reputation of having the best ride comfort, however it was too expensive. ST Coilovers, on the other hand, are made by KW and has the same spring rate (of all 3 variants) with half the price. It is exactly the same as the KW V1 but just uses a different material (KW V1 is 100% rust free, hence it would be safe to use during winter- not like it would matter here since it never snows). Like the KW V1, it is height adjustable and dampening is preset to balance sportiness, comfort, and safety which is alright since I never had the need to change the dampening settings anyway as i don't track my car. Here are some pictures during the installation:
ST Coilovers
You would need to use your OEM top hat for the installation. The ride comfort is great, it is still a bit harsh on some roads but given the road condition here in Manila its significantly better than my old suspension setup. I wouldn't say its better than stock in terms of comfort, but I think it is pretty close. I've also got 19" rims on so that would also take into account. Regardless, it takes bumps really well and suited for daily driving. With my Dynamics coilovers, it was difficult to go fast on uneven roads, however with the ST the car became easier to control. I also haven't heard any noise so far. These are a great set of coilovers!
Old 05-07-2014, 08:47 AM   #22
Sargy
Long Distance Driver
Sargy's Avatar
Very nice!, you are gunna be rare car in your area.
Sargy is offline   Reply With Quote
The Following User Says Thank You to Sargy For This Useful Post:
jvargasj88 (05-07-2014)
Old 05-07-2014, 09:41 AM   #23
Eurasianman
Chief
Eurasianman's Avatar
Drives: 2013 DGM BRZ Premium 6MT
Nice upgrades man! The car, stock, looks good. Your car, with the tasteful mods, sex.
Eurasianman is offline   Reply With Quote
The Following User Says Thank You to Eurasianman For This Useful Post:
Old 05-07-2014, 10:59 PM   #24
jvargasj88
jvargasj88's Avatar
Hahaha! Thanks Eurasianman!
Eurasianman (05-08-2014)
Old 05-08-2014, 01:38 AM   #25
jvargasj88
jvargasj88's Avatar
4th Brake-Light Conversion
My current rear fog light was re-wired so that it would light up only when you hit the brakes.
Rear Fog-Light Conversion
Rewired at: Autokozmetix
[ame]http://youtu.be/JVTUeqGhsdk[/ame]
Sorry for the blurry video, will try to upload a better one soon
Old 05-10-2014, 03:35 PM   #26
deadfish00
Drives: FRS 2013 Asphalt
pretty dope! astig man! I'm diggin that quad tip muffler
deadfish00 is offline   Reply With Quote
The Following User Says Thank You to deadfish00 For This Useful Post:
jvargasj88 (05-11-2014)
Old 05-20-2014, 09:51 AM   #27
jvargasj88
jvargasj88's Avatar
TRD Front Strut Tower Bar
Purchased from: 86/BRZ Club Philippines Member
The TRD Strut Bar is made of carbon fiber so it was pretty light-weight. The instruction manual was faded so I just downloaded a copy online, which didn't really help since it was in japanese. The installation was quick, it just took less than 10 minutes to finish. The strut bar is supposed to increase body rigidity and corner performance by "controlling flex in the upper part of the suspension tower". However, I didn't really notice any difference. You would probably see the improvement more on the track.
Old 07-03-2014, 05:37 AM   #28
jvargasj88
jvargasj88's Avatar
Tom's LED Tail Light / AutoRev Reverse Light
Tom's LED Tail Light - Red
AutoRev Reverse / Third Brake / Park Light
Before:
After:
Park Light (which I eventually disabled since I find that there are too much light already):
Third Brake Light:
[ame="http://youtu.be/5Sm7f90rO6Y"]http://youtu.be/5Sm7f90rO6Y[/ame]
Teclis (07-03-2014)
blue, trd
Laika's Galaxy Blue BRZ OEM+ Laika Member's Car Journals 59 11-12-2013 03:04 AM
WTB BRZ galaxy blue fender vents or trade w my FRS UM blue side vents BlueLeader Exterior Parts (Aero, Lighting, Etc.) 0 03-18-2013 02:55 PM
Galaxy Blue - NZ diss7 AUSTRALIA 5 09-25-2012 06:51 AM
Sonic Blue 86, Galaxy Blue deleted? 450hp/tonne AUSTRALIA 14 09-01-2012 07:10 PM
Galaxy Blue VINs? dorkymork BRZ First-Gen (2012+) — General Topics 49 06-02-2012 09:55 PM
