Old 05-06-2014, 02:11 PM   #421
Deathalo
Drives: 2013 WR Blue Limited Manual BRZ
Originally Posted by milhouse View Post
I think I tapped into as 12V I have in my trunk for my amp.
Does this mean the Orange/White wire connects just to the HU, or to the HU and lead from the Rydeen Duo? Any idea?
I believe if you tap into that orange/white wire on pin #2 with the HU "Back" wire, it triggers the HU to go into reverse mode when you shift into reverse, then it will look for a signal on your reverse video composite input. My Rydeen Duo has a red power wire branching out from the video signal, it was attached to a wire going to a harness I got from @SVXdc, which supplied it power when shifting into reverse. I didn't really pay attention too much into how it all worked but I assume the OEM HU gave it 6v Power when in reverse. If I tap into the 6v ACC power on the 16-pin harness I'm assuming the camera will get constant power with the HU on, but I still don't know why people just don't use the 12v reverse gear trigger wire for both HU triggering and Camera Power, I must be missing something?
Deathalo is offline   Reply With Quote
Old 05-06-2014, 03:50 PM   #422
microbionic
microbionic's Avatar
Drives: 2013 Subaru BRZ
Does this support video in for an AUX source ... such as dashcam? ... or is the video in only for reverse cam...? ...
microbionic is offline   Reply With Quote
Old 05-06-2014, 03:51 PM   #423
ProTekk
ProTekk's Avatar
Drives: Whiteout FR-S
Anyone know if they have something that'll fit a '15 STI?
Sent from my SM-N900T using Tapatalk
ProTekk is offline   Reply With Quote
Old 05-06-2014, 04:23 PM   #424
Deathalo
There's more than one Video In
The Following User Says Thank You to Deathalo For This Useful Post:
microbionic (05-06-2014)
Old 05-06-2014, 05:41 PM   #425
milhouse
Because Racecar
milhouse's Avatar
Drives: 2013 Lightning Red Subaru BRZ
I saw that too - but I didn't see a native way to view anything. Maybe it just needs an app?
milhouse is offline   Reply With Quote
Old 05-06-2014, 06:30 PM   #426
Prog
Prog's Avatar
Drives: 2016 Cadillac CTS
http://www.ft86club.com/forums/showp...&postcount=381
Prog is offline   Reply With Quote
The Following User Says Thank You to Prog For This Useful Post:
ProTekk (05-06-2014)
Old 05-06-2014, 06:34 PM   #427
ProTekk
ProTekk's Avatar
Whoops!
Old 05-06-2014, 07:50 PM   #428
Deathalo
So I got it all working, I attached both the "Back" wire coming from Ca-Fi and the power wire coming from my Rear camera to one single pin and plugged that into the SWC harness with my AUX port wires. It hit's pin 2, the brown/silver wire and it every time I go into reverse, the image pops up nicely. The only other issue I encountered was that the stock brackets have 2 bumps that are supposed to line up with holes on the HU so you can line it up to the correct screw holes. It didn't seem to fit in any way where I could screw it in correctly, so I drilled out the top bump on each bracket and was able to secure all 4 screws easily. The face plate didn't go on as easy as I thought it did on stock HU, might be sticking out just a millimeter farther than it should? Oh well, it's all up and running and really nice. Oh, and my AUX port works great now after the pin swaps I made via the diagram I linked.
Old 05-06-2014, 08:05 PM   #429
Prog
Prog's Avatar
My center bezel also sticks up a tiny bit. Thought I had it mounted weird or something. Glad it's not just me.
Old 05-06-2014, 08:34 PM   #430
DC2R
Drives: 2014 Scion FR-S
Anyone know how to remove stock GPS module?
DC2R is offline   Reply With Quote
Old 05-06-2014, 10:08 PM   #431
SHIFTER
SHIFTER's Avatar
Drives: Scion FR-S
This unit SHOULD - but would need fully rewired.
I could do it for a fee.
Andrew
2013 Scion FR-S MT (Silver)
2011 Toyota Rav4 Sport V6 4wd (Silver)
SHIFTER is offline   Reply With Quote
Old 05-06-2014, 10:08 PM   #432
SHIFTER
SHIFTER's Avatar
Drives: Scion FR-S
mine fits flush.
you may have used the wrong bolt holes. The mounting bracket should be right up against the front of the unit.
Andrew
Old 05-06-2014, 10:14 PM   #433
SHIFTER
SHIFTER's Avatar
Drives: Scion FR-S
Ill throw this out there for any of you guys. If you want me to handle the wiring for you on the installation - for $20 bucks I'll wire the antenna, Aux jack, reverse camera, and have it be 100% plug and play for you without screwing around.
I'm NOT a business, but since a few of you are having issues - I just want to offer my help for anyone that needs it. All you would need to do is send me your aux adapter, antenna adapter and Ca-Fi harness. I'll turn it around in just a few days for you.
Andrew
Old 05-06-2014, 10:18 PM   #434
SHIFTER
SHIFTER's Avatar
Drives: Scion FR-S
More research done and found this: http://i.imgur.com/hKFSVgy.jpg
So not only telling us where the reverse trigger wire is, but if you look at the bottom left 3 pins, you have the AUX left, ground, and Right pins, I think my right or left is in the ground position, so that should fix my audio problem as well.
Another thing about the reverse trigger wire, it's 12v, so I'm thinking I can use that for not just the "Back" wire going into the Ca-Fi, but also the power wire going to the camera. I will try this and let you know how it goes!
Edit: I just remembered my Rydeen Duo only requires 6v, so I guess can tap into the CA+ pin to on the 16-pin harness in that picture. If anyone else has any suggestions feel free to chime in, I'm just wingin' it right now :P
Cool - sorry guys I haven't had an opportunity to yank mine to confirm all of this yet (busy at work). Looks like you got the answers here though!
Andrew
REVIEW: Ca-Fi Toyota Universal - Stock Fitment ANDROID Stereo SHIFTER Electronics | Audio | NAV | Infotainment 16 06-13-2017 07:23 PM
Android, bluetooth, Music, and the FR-S stock pioneer stereo JayNutter Electronics | Audio | NAV | Infotainment 27 12-18-2014 04:54 AM
How to: Torque on an android powered stereo with no hacking v. Ca-Fi Dashlinq4 SHIFTER Electronics | Audio | NAV | Infotainment 29 04-07-2014 05:58 AM
