Old 04-30-2014, 04:46 PM   #4901
fenton
Originally Posted by Jac View Post
I ran a little rich compared to stock:
Disclaimer: measured using Dynojet sniffer which seems to be directionally accurate when I've compared it to my OFT logs.
Made basically the same power as stock, with a little less low end torque:
Confused on what I'm seeing here? Is the green completely stock? If so the stock in lean and the ESC and SPM lines are a little richer but certainly not pig rich.
Sent from my HTC One using Tapatalk
fenton is offline   Reply With Quote
Old 04-30-2014, 04:46 PM   #4902
shif7i7down
Erected Member
Drives: frs
DR comes standard (thankfully).
I believe you need to ask Rob for SPM when you order and he'll wire it in.
Excuse me for my ignorance but what i SPM ? I thought it was the same thing as drag reduction.
shif7i7down is offline   Reply With Quote
Old 04-30-2014, 04:48 PM   #4903
fenton
SPM is a term the guys made up here. Super pursuit mode. It basically just disables the WOT activation of the charger and runs on DR pulses instead for "like stock" power and feel.
Old 04-30-2014, 04:51 PM   #4904
shif7i7down
Erected Member
Drives: frs
I'm guess it's some kind of toggle switch? And since its just a made up term, Would rob know what I'm talking about if i ask for spm?
Old 04-30-2014, 04:53 PM   #4905
TM
TM's Avatar
Drives: DGM BRZ 6MT
So from the dyno charts, it seems like if I turn on SPM (with only DR enabled and the WOT switch disabled), I should be able to run on the track with the ESC tune and have the same power/torque as stock.
Just using DR shouldn't overheat the controller (on the track), since it's not being used to produce boost, right?
TM is offline   Reply With Quote
Old 04-30-2014, 04:56 PM   #4906
Jac
Drives: Fiat Abarth
Stock is stock apart from a catted FP + drop-in filter.
ESC and SPM are running around 11.5 between 5-7k, ignore the fact dynojet thought it was 13.
Jac is offline   Reply With Quote
Old 04-30-2014, 04:56 PM   #4907
TM
TM's Avatar
Drives: DGM BRZ 6MT
He should. Just tell mention the custom switch he did for Jac.
Super Pursuit Mode via switch next to center console
Old 04-30-2014, 04:59 PM   #4908
Jac
Drives: Fiat Abarth
Yep, thats my takeaway. Keep it above 4K and power/torque is the same.
Old 04-30-2014, 05:00 PM   #4909
robwbright
Drives: '13 BRZ Limited WRB Phantom ESC 1.5
Originally Posted by DAEMANO View Post
Since our cars are tuned for 93 octane, I'm not sure if adding more to raise the octane further will improve anything, but I'll do a little more research and give it a shot if it seems safe.
I've got easy access to 93 Oct and even 94 Oct in some cases. I'll be curious to see if the Torco assists with those.
'13 BRZ Ltd MT WRB Phantom ESC 1.5
2012 Honda Accord Coupe
2006 Saab 9-3 2.0t
1997 Honda Accord Coupe
1995 Honda Prelude VTEC
robwbright is offline   Reply With Quote
Old 04-30-2014, 05:01 PM   #4910
Jac
Drives: Fiat Abarth
I actually decided to attach the switch to my voltmeter. Much easier to use now
Old 04-30-2014, 05:06 PM   #4911
fenton
It hasn't been tested on prolonged use but you will get more legs out of it than use full boost for sure.
Old 04-30-2014, 05:09 PM   #4912
fenton
I'll have to check with Rob but there is also a way to alter DR to be more or less aggressive. I noticed that yours doesn't turn on until a little later than mine.
I'll let you know what we come up with for a procedure.
The Following User Says Thank You to fenton For This Useful Post:
Jac (04-30-2014)
Old 04-30-2014, 05:10 PM   #4913
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Personally I'd rather see Rob's continued concentration on development of the aux charger, controller cooling, push-to-pass button (SPM), etc. To me, these are the features that will make the Phantom ESC even better suited to "performance" (e.g. track) usage.
+1
If the ESC, batteries, and controller can survive 20-30 minutes of frequent WOT on a road course without overheating the controller or running out of voltage before the end of a session, I'd be willing to try it.
The Following User Says Thank You to ATL BRZ For This Useful Post:
DAEMANO (04-30-2014)
Old 04-30-2014, 05:12 PM   #4914
Jac
Drives: Fiat Abarth
Thanks! If we're able to activate it at 2K RPM that'd be amazing Seems like its still a slight restriction down there.
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 04:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
