#85 | |
Drives: 2013 WhiteOut FR-S
Filled up the reservoir a week ago, so far its still at the Max line.... Checked the coolant level before filling up the bone dried reservoir, its full inside the radiator, asked my race shop mechanic, he said its normal due to evaporation of the reservoir.... Sent from my iPhone using TapatalkfQ
2013 Scion FR-S whiteout 2012 Porsche Panamera S carbon grey 2008 Range Rover Sport SS black - sold 2004 BMW M3 alpine wies - sold |
#86 | |
Drives: Moped
#87 | |
Ima guess its leaky reservoir (same as over flow tank?) coolant level in radiator is max when i checked with empty reservoir tank How do you ck leaky head gasket? I hv inspect all radiator hoses and no leak detected Sent from my iPhone using TapatalkfQ
#88 |
Thanks
Is there leak detector additive for coolant?
And why anyone trying to use other than OEM. If you don't want to wait hours at the dealer like me, it's only $20 for a gallon. The overflow tank holds surprisingly little.
#89 |
Drives: Toyota 86 TRD Version AT
It is from the reservoir. If you look closely, it has a small hole near the hose. Plus the hose is not really sealed correctly to the reservoir. It evaporates there over time. At least that's what I think. I lose coolant over time also and have been looking for leaks but never found one.
#90 | |
Drives: BRZ DGM Limited
Why the hole? I always thought it was supposed to be a closed system. |
#91 | |
| The Following User Says Thank You to Tye300 For This Useful Post: | CircuitJerk (04-27-2014) |
#92 |
Drives: 2014 Ultramarine 6MT FR-S Monogram
I think the hole is there for air pressure equalization. When the coolant is drawn into the radiator as the engine cools down it prevents suction from forming in the coolant storage reservoir. You shouldn't lose fluid from this hole unless you are overfilling your reservoir.
Borla axleback exhaust * mud guards * Michelin Pilot Super Sport tires * Opti-Coat * BRZ trunk lid liner * Rexpeed Wide Mirrors (heated)
| The Following 2 Users Say Thank You to CruiseZen For This Useful Post: | RehabJeff86 (04-27-2014), Tye300 (04-27-2014) |
#93 | |
Thanks
#94 | |
If you are losing fluid, you may have a slow leak somewhere. Just keep an eye on fluid levels and top off when necessary.
#95 | |
Reverse Burnouts
Drives: 2013 Argento FRS
![]() 2000 Carbon Blue Toyota Celica GTS 152000 miles (wont forget you) 2013 Argento Scion FR-S 2011 Infiniti G37x |
#96 |
Drives: Moped
White smoke out of the exhaust is sometimes an indicator of a leaky headgasket...other times just losing a ton of coolant from the radiator and reservoir without a noticeable leak is another sign...
| The Following User Says Thank You to Lonewolf For This Useful Post: | RehabJeff86 (04-27-2014) |
#97 |
Pull my finger...
Drives: Silver Scion Slushbox
Since this seems to be fairly common, with no sign of leakage, no sign of contamination of oil or exhaust (based on my visual, smell and taste test) I think this is attributed to evaporation from the reservoir.
The time I noticed my reservoir was empty, my radiator was still full to the top. I filled the reservoir to the full mark and have put about 300 miles on the car and lost about 3/8" from the full mark. I then extracted all of the coolant from the reservoir and drove approximately 300 miles yesterday and checked the level from the radiator cap both shortly after garaging the car and then this morning. Full to the brim. |
| The Following User Says Thank You to CircuitJerk For This Useful Post: | RehabJeff86 (04-27-2014) |
#98 |
FRS uses a lot of coolant?
I agreed with Tye300 and CircuitJerk, i noticed faster evaporation rate from the reservoir after i installed the Nameless header which the pipe runs next to it and accelerating the evaporation process, cuz the coolant level inside the radiator stays normal
| The Following 3 Users Say Thank You to RehabJeff86 For This Useful Post: |
| Checking and Changing BRZ/FR-S Engine Coolant | GrimmSpeed | DIY (Do-It-Yourself) Guides | 39 | 05-29-2023 08:15 AM |
| Blue Coolant | Boosted2.0 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 108 | 07-12-2016 05:13 PM |
| Coolant Levels | DriftEightSix | AUSTRALIA | 17 | 01-29-2013 09:19 AM |
| Low Coolant | Tt3Sheppard | Issues | Warranty | Recalls / TSB | 12 | 11-25-2012 12:03 PM |
| European fuel/coolant gauge face | arbnpx | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 05-31-2012 12:23 AM |
