Old 04-26-2014, 09:57 PM   #85
RehabJeff86
RehabJeff86's Avatar
Drives: 2013 WhiteOut FR-S
And this is why I think there is more to the coolant issues than the system burping itself after delivery or it all just evaporated/or spilled out the top of the overflow tank....
Please keep us updated with what happens...
Filled up the reservoir a week ago, so far its still at the Max line.... Checked the coolant level before filling up the bone dried reservoir, its full inside the radiator, asked my race shop mechanic, he said its normal due to evaporation of the reservoir....
Sent from my iPhone using TapatalkfQ
2013 Scion FR-S whiteout
2012 Porsche Panamera S carbon grey
2008 Range Rover Sport SS black - sold
2004 BMW M3 alpine wies - sold
RehabJeff86 is offline   Reply With Quote
Old 04-26-2014, 10:44 PM   #86
Lonewolf
Lonewolf's Avatar
Drives: Moped
I've owned or maintained at least 13 cars in my lifetime so far (all makes/models), and the only time any of them lost this amount of coolant was due to a leaky head gasket, leaking radiator/hose, or leaky overflow tank...
Old 04-26-2014, 10:53 PM   #87
RehabJeff86
Ima guess its leaky reservoir (same as over flow tank?) coolant level in radiator is max when i checked with empty reservoir tank
How do you ck leaky head gasket? I hv inspect all radiator hoses and no leak detected
Old 04-26-2014, 10:57 PM   #88
ZionsWrath
Thanks
ZionsWrath's Avatar
Is there leak detector additive for coolant?
And why anyone trying to use other than OEM. If you don't want to wait hours at the dealer like me, it's only $20 for a gallon. The overflow tank holds surprisingly little.
Old 04-27-2014, 04:21 AM   #89
Tye300
Tye300's Avatar
Drives: Toyota 86 TRD Version AT
It is from the reservoir. If you look closely, it has a small hole near the hose. Plus the hose is not really sealed correctly to the reservoir. It evaporates there over time. At least that's what I think. I lose coolant over time also and have been looking for leaks but never found one.
Tye300 is offline   Reply With Quote
Old 04-27-2014, 08:46 AM   #90
BRZnut
Drives: BRZ DGM Limited
Why the hole? I always thought it was supposed to be a closed system.
Old 04-27-2014, 09:06 AM   #91
Tye300
Tye300's Avatar
I have no idea. But look closely at the reservoir, it has a small hole near the cover. I know it supposed to be a closed system, but it's there. It sure seems to be a factor why we lose coolant.
The Following User Says Thank You to Tye300 For This Useful Post:
CircuitJerk (04-27-2014)
Old 04-27-2014, 09:30 AM   #92
CruiseZen
CruiseZen's Avatar
Drives: 2014 Ultramarine 6MT FR-S Monogram
I think the hole is there for air pressure equalization. When the coolant is drawn into the radiator as the engine cools down it prevents suction from forming in the coolant storage reservoir. You shouldn't lose fluid from this hole unless you are overfilling your reservoir.
Borla axleback exhaust * mud guards * Michelin Pilot Super Sport tires * Opti-Coat * BRZ trunk lid liner * Rexpeed Wide Mirrors (heated)
CruiseZen is offline   Reply With Quote
The Following 2 Users Say Thank You to CruiseZen For This Useful Post:
RehabJeff86 (04-27-2014), Tye300 (04-27-2014)
Old 04-27-2014, 09:54 AM   #93
ZionsWrath
Thanks
ZionsWrath's Avatar
If there is a hole in the tank how could you not lose coolant to evaporation if it is 50% water?
Old 04-27-2014, 11:50 AM   #94
CruiseZen
CruiseZen's Avatar
I'm sure you lose a little, especially if you are in an arid environment. However, the amount should be negligible. I'd be surprised if evaporation through that hole exceeded a gallon per year.
If you are losing fluid, you may have a slow leak somewhere. Just keep an eye on fluid levels and top off when necessary.
Old 04-27-2014, 12:03 PM   #95
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
Yeah but you also have to take into consideration that the coolant is at higher temperatures while the car is running. The higher temperature the higher the rate of evaporation.
2000 Carbon Blue Toyota Celica GTS 152000 miles
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
carbonBLUE is offline   Reply With Quote
Old 04-27-2014, 01:37 PM   #96
Lonewolf
Lonewolf's Avatar
Drives: Moped
White smoke out of the exhaust is sometimes an indicator of a leaky headgasket...other times just losing a ton of coolant from the radiator and reservoir without a noticeable leak is another sign...
The Following User Says Thank You to Lonewolf For This Useful Post:
Old 04-27-2014, 02:02 PM   #97
CircuitJerk
Pull my finger...
CircuitJerk's Avatar
Drives: Silver Scion Slushbox
Since this seems to be fairly common, with no sign of leakage, no sign of contamination of oil or exhaust (based on my visual, smell and taste test) I think this is attributed to evaporation from the reservoir.
The time I noticed my reservoir was empty, my radiator was still full to the top.
I filled the reservoir to the full mark and have put about 300 miles on the car and lost about 3/8" from the full mark.
I then extracted all of the coolant from the reservoir and drove approximately 300 miles yesterday and checked the level from the radiator cap both shortly after garaging the car and then this morning.
Full to the brim.
CircuitJerk is offline   Reply With Quote
The Following User Says Thank You to CircuitJerk For This Useful Post:
Old 04-27-2014, 02:23 PM   #98
RehabJeff86
FRS uses a lot of coolant?
I agreed with Tye300 and CircuitJerk, i noticed faster evaporation rate from the reservoir after i installed the Nameless header which the pipe runs next to it and accelerating the evaporation process, cuz the coolant level inside the radiator stays normal
The Following 3 Users Say Thank You to RehabJeff86 For This Useful Post:
CircuitJerk (04-27-2014), SkAsphalt (05-11-2014), Tye300 (04-27-2014)
Checking and Changing BRZ/FR-S Engine Coolant GrimmSpeed DIY (Do-It-Yourself) Guides 39 05-29-2023 09:15 AM
Blue Coolant Boosted2.0 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 108 07-12-2016 06:13 PM
Coolant Levels DriftEightSix AUSTRALIA 17 01-29-2013 10:19 AM
Low Coolant Tt3Sheppard Issues | Warranty | Recalls / TSB 12 11-25-2012 01:03 PM
European fuel/coolant gauge face arbnpx Cosmetic Modification (Interior/Exterior/Lighting) 0 05-31-2012 01:23 AM
