go_a_way1
Old 04-25-2014, 12:39 AM   #4537
robwbright
Drives: '13 BRZ Limited WRB Phantom ESC 1.5
Originally Posted by Robftss View Post
PM's sent to individuals regarding May TQ250 kits(w/1.5 upgrade option) and standalone 1.5 dump pack additions.
Due to the demand of the 1.5 dump pack upgrade my initial target of May 5th to 9th my get pushed by a week.
Thanks all
Received. Thanks. Will respond tomorrow - I've been gone all evening and just got home.
'13 BRZ Ltd MT WRB Phantom ESC 1.5
2012 Honda Accord Coupe
2006 Saab 9-3 2.0t
1997 Honda Accord Coupe
1995 Honda Prelude VTEC
robwbright is offline   Reply With Quote
Old 04-25-2014, 12:50 AM   #4538
robwbright
Originally Posted by Sojhinn View Post
Maybe I missed something... so for the 1.5 dump setup, I'll need 2 of those you linked above, these 2:
http://www.atbatt.com/power-sonic-2-...b-terminal.asp
and this one for the starter:
http://www.atbatt.com/power-sonic-ps...id-battery.asp
That's a total of 5 batteries. Is that correct?
2006 Saab 9-3 2.0t
Old 04-25-2014, 12:51 AM   #4539
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Yup.
Installed Mods:
Old 04-25-2014, 01:04 AM   #4540
Boofneenee
Go-Kart Enthusiast
Boofneenee's Avatar
Drives: Toyota Scion FRS
whats the car drive like towards the higher end of the rev range i.e. 4.5 - 7k? I understand the boost ends around then or slows down.
what it like to merge the end of boost to a high unboosted rev? I would imagine the car loses some of its character but in a good way?
FRS
Current mods: K&N air filter, OFT, OFH, berk high flow cat front pipe, Q300 exhaust, lighter wheels
Boofneenee is offline   Reply With Quote
Old 04-25-2014, 01:08 AM   #4541
fenton
It still pulls hard. With shiv's tune and some supporting mods the top end doesnt fall off at all anymore. You hit peak power at about 6000 rpm and hold to 7500....this is a very desirable power curve.
The centrifugal SC's(Vortech, Kraftwerks, jackson) make nice peak hp numbers but almost all of them drop 50 to 75 hp when you shift at 7500 rpm and drop to 5000....you really have to wring those out to get the most of them.
fenton is offline   Reply With Quote
The Following 2 Users Say Thank You to fenton For This Useful Post:
Boofneenee (04-25-2014), robwbright (04-25-2014)
Old 04-25-2014, 01:10 AM   #4542
fenton
This is how it compares to the stock power curve
Old 04-25-2014, 01:15 AM   #4543
Sojhinn
Sojhinn's Avatar
That's the reason I like the 1.5 pack. Feels more punchy up top.
Installed Mods:
Old 04-25-2014, 01:17 AM   #4544
jflogerzi
jflogerzi's Avatar
Yup.
Edit N/M. See The quote included the small batteries for the 1.5 setup, and the original set were in the other 2 links. How much does the stock battery weight?
Old 04-25-2014, 01:50 AM   #4545
jflogerzi
jflogerzi's Avatar
Gotta love that power curve.
Old 04-25-2014, 10:44 AM   #4546
Stormalong
Drives: Firestorm FR-S AT
Yup.
In the pictures posted yesterday of the 1.5 dump pack I only saw 4 batteries. Where is the 5th?
Stormalong is offline   Reply With Quote
Old 04-25-2014, 10:46 AM   #4547
Urmyson
To the guys running the 1.5 pack. Is it a noticeable difference like "oh wow" or "I think I feel it"?
Urmyson is offline   Reply With Quote
Old 04-25-2014, 11:11 AM   #4548
Jac
Drives: Fiat Abarth
As promised, here's my detailed dyno report. All on 93 octane, 4th gear pulls + catted front pipe and catback exhaust.
First things first, ESC vs. stock + stock map (both with front pipe/CBE/intake filter)
LOVE the 50% torque gain in the dip
Hate the drop off towards 7K rpm, really rewards you for keeping it between 3-5K
The Phantom ESC was hitting about 4.5psi peak boost, then dropping to 0.5-1psi higher in the rpm range.
Next up i tested SPM (Super Pursuit Mode turns off throttle switch) vs. stock to see if I'd actually gain/lose anything with drag reduction only. I did.
ESC Super Pursuit Mode (red) vs. stock + stock map (both with front pipe/CBE/intake filter)
Was surprised to see peak numbers were pretty much the exact same with SPM actually producing less low end torque until 4K.
Next i wanted to see how the ESC would perform with an aftermarket intake filter
ESC vs. ESC w/K&N Filter (both with front pipe/CBE)
Nice gains! almost 10hp and 10tq higher in the rpm range.
Although my AFRs started to get a bit scary with the filter. Although this was with the dynojet exhaust sniffer, not OFT data logging.
Summary, I'm very happy with the torque between 3-5K its what the car really needed. Would love to keep it going past 6K but here's hoping the 1.5 dump pack helps. Horsepower isn't all that impressive but who cares when you have all that torque on tap that low in the range. AFRs are still a bit scary but I'm thinking with more fuel i should be making more power.
Let me know if you have any questions. I'm planning to hit the dyno again once i get my 1.5 dump pack and will likely ask Shiv for an e-tune to clean-up my AFRs.
Jac is offline   Reply With Quote
The Following 7 Users Say Thank You to Jac For This Useful Post:
Boofneenee (04-25-2014), DAEMANO (04-25-2014), fenton (04-25-2014), Gums (04-28-2014), Luckrider (04-25-2014), nlowell (04-26-2014), robwbright (04-25-2014)
Old 04-25-2014, 11:13 AM   #4549
robwbright
A couple pages back, Rob stated, "The stock starter was 29.x lbs by itself."
2006 Saab 9-3 2.0t
Old 04-25-2014, 11:21 AM   #4550
robwbright
Maybe I misunderstood this, too.
In the pics fenton posted, there appear to be 4 batteries on the tray. Is there a different tray to fit the 5th battery?
2006 Saab 9-3 2.0t
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 05:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 07:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 08:07 AM
