Old 05-31-2013, 10:01 PM   #15
RT87
Originally Posted by Takuro View Post
It seems like a majority of FRS owners are first time manual transmission drivers.
I don't see why that matters. Everyone starts somewhere.
RT87 is offline   Reply With Quote
Old 05-31-2013, 10:33 PM   #16
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
I do this downshift a bunch of times a day. I don't like to pass on the highway in 6th. Silky smooth.
Old 05-31-2013, 10:46 PM   #17
Enraged21
#RememberTheBuster
Enraged21's Avatar
Drives: Firestorm FRS MT
But you did stay at a Holiday Inn last night.
I'm not sure I get what you're saying
Enraged21 is offline   Reply With Quote
Old 05-31-2013, 10:53 PM   #18
UMB FR-S
UMB FR-S's Avatar
Drives: Ultramarine Blue FR-S
it was joke .... a funny one unfortunately it was lost on you haha
-- Kenny
"I don't always use heel/toe, but when I do it's because racecar."
UMB FR-S is offline   Reply With Quote
The Following User Says Thank You to UMB FR-S For This Useful Post:
OrbitalEllipses (05-31-2013)
Old 05-31-2013, 11:47 PM   #19
Code:Red
Code:Red's Avatar
Drives: 2013 Firestorm 6MT
Originally Posted by cfusionpm View Post
I skip gears often. Unless I need a constant connection to the drive line or want to engine brake efficiently, I'll jump from 6 to 4 to 2. I'll also jump up from 3 to 5, 2 to 4 to 6, whatever. That's the nice thing about an H-shifter, you can just put it where you want it and not need to run through them like an auto or sequential. As long as I'm not bogging the car going up hill or something, this works well on flat ground and down hills for daily driving.
I do this sometimes...esp the 3rd to 5th part. It depends on how the revs sound and feel AND my speed in a gear. If I know my revs will be sufficient and I know I'll be cruising in 5th, i'll just go to 5th...still engaging the clutch in between.
Code:Red is offline   Reply With Quote
Old 05-31-2013, 11:48 PM   #20
Brzetto
Drives: 4 wheels
Don't rev match, you're not Jerry Reed.
Brzetto is offline   Reply With Quote
Old 04-24-2014, 01:11 AM   #21
monkeyslide17
monkeyslide17's Avatar
Drives: frs
Toke back to toyota, syncros was bad from 6 - 5. They replaced it I got a new transmission. End result I saved 6 thousand dollars. Wow this trans cost to made much.
monkeyslide17 is offline   Reply With Quote
Old 04-24-2014, 02:21 AM   #22
B3yondL
Drives: s2k
Definitely not normal. Should get it checked out. Does it grind only when you downshift? That's strange.
Yeah, I kinda got that too from some of the threads that pop up/responses I read.
I personally wouldn't buy a brand new car and learn manual on it but to each his own. I know when I first got my car and started learning manual I wouldn't wanna put my FRS through that.
B3yondL is offline   Reply With Quote
Old 04-24-2014, 02:48 AM   #23
Turbo95eg6
Turbo95eg6's Avatar
Drives: 2014 BRZ SWP LTD
The Following User Says Thank You to Turbo95eg6 For This Useful Post:
Chattanooga FR-S (04-24-2014)
Old 04-24-2014, 04:05 AM   #24
swpbrz
Drives: swp brz limited
I found going from 6th to neutral then to 5th helps the smoothness. For me personally I found the amount my arm has to reach causes to much of a stress to get a reliably smooth one movement shift.
swpbrz is offline   Reply With Quote
Old 04-24-2014, 02:10 PM   #25
J_kennington
Drives: 2013 asphalt scion FRS
I say the opposite. Learn on a new car, so when you do break something(which 9 out of 10 people will), it's under warranty and free to fix.
2013 raven frs(dd/grocery getter)
1990 mitsu eclipse gsx(street/strip car)
1995 gmc 1500 4x4(off road toy)
2005 Yamaha yz250f
J_kennington is offline   Reply With Quote
Old 04-24-2014, 03:20 PM   #26
phobos512
phobos512's Avatar
Drives: 2014 FR-S 6MT Whiteout
I'm one of those people. I couldn't learn any other way as I had no other access to a manual car, and I didn't feel comfortable doing it on a test drive with a salesman in the passenger seat "showing me how" as they offered many times.
Matt | '14 FR-S 6MT Whiteout | '13 Sonata Hybrid | '11 CBR1000RR
phobos512 is offline   Reply With Quote
Old 04-24-2014, 04:52 PM   #27
billwot
Drives: '11 Cayman , '14 Camry, '11 Tacoma
I taught 3 teenage daughters and a 40 y.o. wife to drive manual trannies...1 in a Midget, 2 in 914s, and my wife in a Fiat Strada. Never broke anything.
It would really be almost impossible to actually break or even seriously damage a modern synchro manual gearbox, or any other part of the drivetrain.
Over the years, I have BADLY abused some vehicles, and the worst I ever did was snap a U-joint.
billwot is offline   Reply With Quote
Old 04-24-2014, 05:20 PM   #28
Braces
Braces's Avatar
Drives: 17 Alfa Romeo 4C
Curious about the stress on the engine, tranny from the eventual engine stalls and slipping the clutch for all those learning the manual. I mean ... do you teach someone in a BRAND NEW CAR?
Braces is offline   Reply With Quote
