Old 04-14-2014, 01:46 AM   #1
jgonx213
Drives: Scion FRS (Whiteout)
Oil leak after my first oil change.. WTF?
So i got my first Oil change on my scion FR-S and now im leaking oil....
I know the cam plate oil leak is happening.. in the passenger side.
but this oil leak is happening right under the engine...
WTF? is the problem? well, going to dealer on friday to check it out..
Anyone had this problem yet?
jgonx213 is offline   Reply With Quote
Old 04-14-2014, 02:03 AM   #2
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
who changed your oil for you? Beware of someone double stacking crush washers:
http://www.ft86club.com/forums/showthread.php?t=54142
-alex
Old 04-14-2014, 02:31 AM   #3
Dezoris
Dezoris's Avatar
Check the pan/plug.
I think I had one of the worst leaks on the cam plate posted, it literally pooled on the skid plate and appeared as though it could have come from somewhere else looking at the drips on the ground.
Thats still possible in your case if you have a known leak.
Old 04-14-2014, 03:03 AM   #4
Tainen
Drives: First SWP BRZ-L
common. Same thing happened to me, but I knew immediately what it was from my WRX experience. The stock crush washer is painted on to the drain plug. I pried it off with a small screw driver and gave the service manager an ear full.
First white BRZ in the country
Limited SWP BRZ, 35% tint, clear bra, Nameless Performance downpipe, axelback, headers
Tainen is offline   Reply With Quote
The Following 2 Users Say Thank You to Tainen For This Useful Post:
Clipdat (04-14-2014), sshole (04-14-2014)
Old 04-14-2014, 09:38 AM   #5
sshole
Check to make sure you either a) have a SINGLE new crush washer installed on the drain plug and/or b) have not stacked the single new crush washer on your old crush washer.
sshole is offline   Reply With Quote
Old 04-14-2014, 09:42 AM   #6
USMC
USMC's Avatar
Drives: 2013 Scion FR-s
Buy and install a Fumoto Qwik valve.
USMC is offline   Reply With Quote
Old 04-14-2014, 10:10 AM   #7
FR-S Matt
I had an oil leak on my last oil change. Got my ratchet and socket on the drain plug and gave it a light tug tighter. No more oil coming from the pan.
Next oil change I'm out of my free ones. I have a Fumoto valve going on and putting in full synthetic.
Old 04-14-2014, 11:46 AM   #8
Myv
Myv's Avatar
Drives: SWP BRZ Limited MT
I second on Fumoto valve as well if you do your own oil change.
Myv is offline   Reply With Quote
Old 04-14-2014, 02:57 PM   #9
jgonx213
going to dealer tmr! ill let u guys know what the problem is
Old 04-15-2014, 09:23 PM   #10
jgonx213
After 4hours toyota mechanic working on my car.. he forgot to replace the crush washer... so after he replaced it, no leak...
Arent the dealer mechanic... certified mechanic...? how are they making rookie mistake?
Old 04-15-2014, 10:07 PM   #11
hinge
hinge's Avatar
Drives: 23 BRZ
They're certified by having a pulse and their own tools, that's it.
Better off doing your own oil changes, every Subaru since ever has the crush washer, so it's a good idea to buy a pack of them from the dealer.
hinge is offline   Reply With Quote
Old 04-16-2014, 01:19 AM   #12
Jolaessss
Jolaessss's Avatar
Drives: SWP FR-S
I recommend not bringing your car into the dealership to do any maintenance. Save yourself the trouble and do it yourself. When the time came for my 15k miles maintenance, I was very indecisive about taking my car into Toyota because of all the bad reviews. I gave them the benefit of the doubt and took my car in after putting a small mark on all the parts to make sure they did their job.
About an hour later, I pick up my car to find a ton on oil splatters in the engine bay and on the aluminum heat shield under the car, topped off my radiator coolant way above the "FULL" mark, AND I have a good feeling they used TWO crush washers on the oil drain plug.
Never again will I bring my car into the dealership...
Jolaessss is offline   Reply With Quote
The Following User Says Thank You to Jolaessss For This Useful Post:
Clipdat (04-18-2014)
Old 04-16-2014, 09:37 AM   #13
thill
For the guys doing your own maintenance and are under warranty still, just make sure you keep a detailed log of everything you have done and have itemized receipts for all the parts/purchases. When I used to change my own oil, and had engine issues with a Nissan, the dealer asked me for the itemized receipts and I was able to show them to him along with a detailed log that recorded dates, how much oil I added, and what mileage. He told me without that info they would have denied my warranty claim.
The Following User Says Thank You to thill For This Useful Post:
Jolaessss (04-18-2014)
Old 04-16-2014, 01:54 PM   #14
userjack6880
userjack6880's Avatar
Drives: Raven FR-S MT
My drain plug was overtorqued when I took it in for it's first "free" oil change (with my own supplies). Bent the bolt itself (lolwut). Dealer is gonna make it right and ordered a new plug, and the tech is talking to the service manager (who was out when I came by) about reimbursing me for the oil wasted from this issue.
That's what I get for being lazy.
2013 Scion FR-S - Build Thread
2015 Ford Mustang GT
1978 Triumph Spitfire 1500
userjack6880 is offline   Reply With Quote
OIL LEAK REPAIR | FRS BRZ JPxM0Dz Engine, Exhaust, Transmission 1 02-20-2014 11:12 AM
Please help identify this leak... G.I.Choe Issues | Warranty | Recalls / TSB 3 01-27-2014 08:16 AM
oil leak problem HELP! davebrus Issues | Warranty | Recalls / TSB 18 12-07-2013 06:47 PM
Exhaust leak. J8boston8j Engine, Exhaust, Transmission 17 10-15-2013 09:09 PM
A/T Pan leak goke186 Issues | Warranty | Recalls / TSB 0 04-15-2013 11:31 PM
