Old 12-04-2013, 08:15 PM   #1
davebrus
Drives: fr-s
oil leak problem HELP!
Hey guys im new here and i have a problem with my fr-s there is a oil leak i need help distinguishing what the problem is!
davebrus is offline   Reply With Quote
Old 12-04-2013, 08:43 PM   #2
humfrz
Well, here goes my simple solution (that doesn't usually work) .... torque those two bolds down and see if it stops leaking.
BTW, welcome to the forum.....
humfrz
Old 12-04-2013, 09:55 PM   #3
Nothing
Drives: FRS
Did you hit something? I forget what the tranny looks like with no marks on it.
Nothing is offline   Reply With Quote
Old 12-04-2013, 11:22 PM   #4
cnk
Drives: '13 DGM BRZ Limited
Take it to the dealer. That's what the warranty is for.
cnk is offline   Reply With Quote
The Following 3 Users Say Thank You to cnk For This Useful Post:
civicdrivr (12-06-2013), Evil Jesus (12-06-2013), suaveflooder (12-05-2013)
Old 12-04-2013, 11:29 PM   #5
sierra
Drives: Skoda Yeti DSG diesel 4x4
If that's the gearbox to the bellhousing, did you go over something sideways?????
Maybe it's cracked?
sierra is offline   Reply With Quote
Old 12-05-2013, 08:51 AM   #6
Suberman
Drives: Subaru BRZ Sport Tech Satin White
Maybe it's cracked?
Looks like the transmission casing to rear casing joint at the tail end of the tranny.
How much oil is leaking? Did you wipe it clean?
Frankly I don't see a leak. Where is the transmission breather on this gearbox? Sometimes a new transmission might blow a little oil out of the breather. This is more likely if the transmission got very hot after say a track day in summer?
Also, could it be engine oil blown back in the underbody slipstream?
Suberman is offline   Reply With Quote
The Following User Says Thank You to Suberman For This Useful Post:
humfrz (12-05-2013)
Old 12-05-2013, 10:50 AM   #7
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
The problem is a leak.
The solution is take it to the dealer and have them fix it.
Old 12-05-2013, 05:49 PM   #8
protpibe
protpibe's Avatar
It looks like you hit something..
Old 12-05-2013, 06:36 PM   #9
frs23
frs23's Avatar
Drives: FR-S H Lava
+1 on taking it to the dealer. They should handle it if there is warranty, even if the bolts are slightly loose. They need to investigate it and you may even get a new seal and tranny fluid from all this.
frs23 is offline   Reply With Quote
Old 12-05-2013, 07:34 PM   #10
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
We can diagnose it for you, but there is a $49.95 fee. This will go towards any labor work you have us perform.
Or stop speculating and have a dealer take a look. Or, have a certified mechanic take a look if you hit something.
-alex
Old 12-06-2013, 01:59 AM   #11
davebrus
Drives: fr-s
the thing is i got the car from auction so it doesn't have warranty im still trying to fix the car up just need to pull it and paint it
Old 12-06-2013, 05:47 AM   #12
Gaiseric
Gaiseric's Avatar
Drives: 2012 Scion TC
Warranty is for 3 years 36k miles and 5 years 60k for powertrain. That's factory warranty, what does the auction have to do with anything?
Gaiseric is offline   Reply With Quote
Old 12-06-2013, 06:35 AM   #13
protpibe
protpibe's Avatar
Rebuilt title maybe
Sent from my HTC One using Tapatalk
Old 12-06-2013, 03:37 PM   #14
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Then pull the transmission, pop off the tail section, reseal it with the proper Toyota/Subaru gasket maker, and put the transmission back in.
Exhaust leak. J8boston8j Engine, Exhaust, Transmission 17 10-15-2013 08:09 PM
A/T Pan leak goke186 Issues | Warranty | Recalls / TSB 0 04-15-2013 10:31 PM
Slow Leak, wha do you guys think could be the cause? peenut1086 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 12-25-2012 10:47 PM
Exhaust Leak? k33n3r Engine, Exhaust, Transmission 6 08-09-2012 12:59 PM
