#71 |
Love Boost!!!!!!!!
Drives: Whiteout Scion FR-S
Lj is the man
I love boost!!!!!!
#72 | |
Drives: red/black
#73 | ||||
Drives: Scion FR-S/Toyota Yaris
Bingo Bango Bongo, at least one person understands what I'm trying to communicate Quote:
I agree fully, anyone who grew up playing with cars can install a turbo kit, but the tuning is un obtainable for many people. Vendors best interest is not publicizing this (I'm not pointing at FB.) Quote:
And how far away is Full Blown from 99.999% of the population, that's the issue. You are very very lucky if you have a shop like that near you most of us don't Quote:
Not reading my full posts again, I have never said FI is bad on this platform. Hell I said Tada should be fired (moved is the better term) for not letting Subaru configure Subaru's FA20T for this car in the first place. Things do get complicated and beyond an average enthusiasts' budget and time commitment at high boost levels that require built short blocks, its too early. Only a small fraction have all the cards in place to build a high boost FA20. today. It will get easier in a few years but the recipe isn't finalized and its far from cookie cutter. I'll wager you managed 2 or 3 sentences out of this post, but some do read and hopefully my opinion has helped someone's hobby from turning into a nightmare.
2013 FRS Argento Silver 6MT
Mods: Clear fender side lights Tactrix ZA1JB01C 2014 Calib |
#74 | |
Mr. Cranky Pants
Drives: 2013 Argento FR-S
You keep saying this. What you're talking about doesn't ever happen if people don't push the limits, and pushing limits invariably ends up with blown motors, but that has absolutely NOTHING to do with what happened here. Dudes motor blew up while running either a conservative basemap or an incorrect map. Either way it's human error that resulted in a blown motor, and would have happened even if someone had a perfect house of cards stacked up for us to point at and say, "do it this way". |
| The Following User Says Thank You to Sellout For This Useful Post: | cdrazic93 (04-10-2014) |
#75 | |
I Love custom Turbo kits
Drives: Limited BRZ
I shake my damn head everytime I see this posts. Look, you are correct when you say Johny the corner kid who just turned 19, lives with mom and pop and works for pizza hut delivery, zero experience with cars should not even venture into FIing the car. But you keep throwing out there how it is almost unfathomable and impossible to boost this car to say, 12-16 psi (MAYBE I misunderstand you but that is how it comes up). I do agree with you 100000%, the essence of it all is THE TUNE. Fuel quality also plays a HUGE role. The formula to properly boost this motor (or any other in general aside from 20 year old studied to death motors) is to have money and have a good shop do it. I've been boosting 16 psi for 7K miles. No issues to date. My tuner, @jamesm has pushed his car to 24 psi. Good as new. Brandon has done a few dyno passes at 25 psi. Full blown more than all of us combined. Dynosty the same... Do I expect the motor to hold stock 25 psi long miles? Of course not. Do I expect a daily driven car, properly tuned and fueled at 12-16 psi to last? Yes. The fuel and tune will prevent your car from knocking itself to death. I agree good tuners are far and few in between. BUT there are good tuners out there. James (HRI Tuning) Delicious LJ/Full Blown Hall/Dynosty JuniorAWD Bob/Drift Office to name a few....
#76 |
Drives: 2013 Black FR-S
Doesn't this high tech sophisticated ecu have the ability to detect knock and if it is bad enough go into limp mode so you don't blow your engine? Genuinely asking here.
#77 |
Drives: Limited BRZ
It does pull back timing moreso than the average OEM ECU and can withstand really REALLY REEEEAALLLYYY bad tunes for a long while, but if the knock is not corrected, the water drop will eventually blow a hole in the rock /figuratively/literally.
#78 |
NASA SpecE30 Racer
It can only pull a maximum of 5 degrees of timing. EcuTek allows failsafes to be put in place but the OEM ECU code isn't going to stop this from happening if your fuel pump drops pressure and the car begins to lean out.
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
| The Following User Says Thank You to King Tut For This Useful Post: | Sportsguy83 (04-10-2014) |
#79 | |
Drives: 2008 Civic Si
He didn't mention what his afr was at wot, which is what is important. He needs to give more info, but from what i read about those melted pistons it was definitely lean. If it did that with one 4th gear pull i'd guess his afr's were in the 14's at wot. The leanest i could get my car to idle was at about 17-18:1 afr for reference. And leaning out past 15.5 afr at partial throttle results in torque loss. The crazy bit is ignition timing at partial throttle can destroy a boosted setup faster than anything even when it doesnt' feel like you're blowing it up. too much ignition when hitting between atmospheric and 3'ish psi is probably the number 1 cause of most n/a to turbo setups blowing up. Tuner is lazy and thinks your'e just going to wot all the time, fucks up your timing map greatly in certain spots. Last edited by w00t692; 04-10-2014 at 11:24 AM. |
| The Following User Says Thank You to w00t692 For This Useful Post: | Sportsguy83 (04-10-2014) |
#80 | |
Drives: FR-S 6MT
Great post Captn Obvious... The world is now a better place...
and there is a reason why people don't read your full posts... Anybody who is going to invest in FI would be aware of the risks and Challenges. There are plenty of DIYs that are safely running descent amounts Of boost. Tunes can be supported remotely as well.. This is the connected age and you are over simplifying things here.. You seem to always blow things Out of proportion with the sky is falling mentality.. Many of the engine mishaps have been caused by bad installs or an over anxious Owner who pushed beyond the limits. Not because it's so unknown or unsafe.. and Tada did just fine by me... Quote:
#81 |
Junior
Drives: a car
Whenever I see a FI my car has xxx issues blah blah blah, I feel like regal likes to comment to say why FI kits shouldn't be used on This NA motor because of the availability of tunes and/or some dumb kid not knowing what he's doing to his motor.
People want to build their cars. Turning an NA motor into a Turbo motor albeit with just bolt ons is half the fun, it presents more of a challenge than just simply upgrading a turbo motor. High PSI will blow up any engine setup improperly; this includes fuel lines, tune and everything in between. Reputable shops won't just weld some tubes together and put a turbo with it to call it a kit. There is research, and hard tangible data behind why they choose what they choose. The base map IMO is intended for getting you to a tuner ASAP. There is a reason why people make the 1,000+ mile trips to these tuners. You're right, my local mechanic wouldn't be able to tell me where my oil cooler is located on the car, but that's not going to deter me from getting my car tuned properly, whether it be 10 miles away or 1000. /rant
#82 | |
Drives: Limited BRZ
Ridiculously lazy.
#83 | |
No I am saying the absolute opposite. I'm saying buy the kit and stick with the tested to hell and back tune that comes with it. Avo is the perfect example I keep coming back to. It comes with a tune so good as I wouldn't even call it a basemap. Its when you push the limits above the standard kit 8-9 psi that disasters can happen. Or you buy the kit without Avo's tune ("tuner kit") and have joe blow tune it and wonder why it threw a rod ![]() @Sportsguy83, I believe we are saying the same thing. I just think people need things lined up and a tuner they trust their life with when going to higher boost levels. Thanks for the list, you do realize it is fairly small compared to other N/A performance cars? This car is still "rare" to a typical tuner and has some slightly complicated "gotchas."
#84 | |
NASA SpecE30 Racer
- King Tut
| Full Blown Turbo Kit! | Unleashed | Engine, Exhaust, Bolt-Ons | 70 | 10-09-2013 09:46 AM |
| 2013 FR-S Full Blown Motorsports Stage1 Turbo kit. Mustang Dyno results. | Infamous Performance | Forced Induction | 10 | 07-03-2013 08:52 PM |
| FINAL RESULTS: Taking Full Blown Stage 1 To The MAX! @Pure Automotive (Dyno Inside!) | Pure Automotive | Forced Induction | 57 | 03-27-2013 11:41 PM |
| The Results Are In!! Full Blown Stage 1 Kit @ Pure Automotive Performance! | Pure Automotive | Forced Induction | 181 | 03-12-2013 02:11 PM |
| The Results Are In!! Full Blown Stage 1 Kit @ Pure Automotive | Pure Automotive | Mid-Atlantic | 22 | 02-12-2013 10:13 AM |
