Old 01-27-2014, 02:28 PM   #15
Frs32907
Drives: Asphalt grey, manual Fr-S
Replaced sensor and tightened all the clamps to make sure no leaks im going to probably switch the vortech clamps out for T bolt clamps
Frs32907 is offline   Reply With Quote
Old 02-24-2014, 11:02 PM   #16
reyruiz191
reyruiz191's Avatar
Drives: 2013 FRS Vortech Supercharged
@Frs32907 did you replace the sensor with another 2.5bar? or did you switch it to a 3 bar? I recently got a new tune and have been having the same issue throwing code P0068. How's the car running since?
reyruiz191 is offline   Reply With Quote
Old 04-09-2014, 05:12 PM   #17
mit_peid
Boosted Noob
mit_peid's Avatar
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
Did P0068 shut down your cars? I received it last night and it shut down my car and wasn't able to restart afterwards. I have a Kraftwerks S/C installed and recently updated with new 4-bar MAP sensor and new tune which worked okay for ~2 weeks.
mit_peid is offline   Reply With Quote
Old 04-09-2014, 05:16 PM   #18
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
That code relates to your MAP sensor scaling I believe, but I can't see it shutting your car down unless the sensor actually failed. I know I installed a new MAP sensor without modifying my tune with the correct MAP sensor scaling and it wouldn't even start.
Old 04-09-2014, 05:22 PM   #19
mit_peid
Boosted Noob
mit_peid's Avatar
That code relates to your MAP sensor scaling. Are you running a Delicious Tune because it seems like his tunes have been seeing this issue quite a bit?
Well, I have a Delicious tune (the Kraftwerks (KW) factory tune) but the failure didn't occur on it. The Delicious tune was based on a Denso MAP sensor, but the tune itself was rather rough so I asked KW for a better tune. The failure actually happened on a KW/Skunk2 tune (later clarified it was indeed NOT a Delicious tune) with a new 4-bar MAP sensor.
After checking for loose hoses etc tonight or this weekend, I will be installing the previous Denso MAP sensor and the Delicious tune to see if it fixes the problem.
Old 04-09-2014, 05:26 PM   #20
reyruiz191
reyruiz191's Avatar
No issue with my car shutting off, it would just throw the cel and an occasional slip light. The issue I was having was the values for the maf voltage weren't set up correctly so that was causing my car to throw the cel. Since adjusting those I haven't had an issue.
Old 04-09-2014, 05:27 PM   #21
King Tut
NASA SpecE30 Racer
King Tut's Avatar
I could see that causing your car to shut off if your MAF voltages went out of range high, but I don't see that not allowing you to start your car afterwards.
Old 04-09-2014, 05:29 PM   #22
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Sounds like a good plan. As I mentioned I don't think loose hoses will prevent your car from starting either.
Old 04-09-2014, 05:32 PM   #23
mmsracing
Drives: 2013 FRS
check this post out, could be this http://www.ft86club.com/forums/showt...26#post1655426
mmsracing is offline   Reply With Quote
The Following User Says Thank You to mmsracing For This Useful Post:
mit_peid (04-09-2014)
Old 04-09-2014, 09:19 PM   #24
mit_peid
Boosted Noob
mit_peid's Avatar
Originally Posted by mmsracing View Post
Thanks. Yeah I've been following that thread... the symptoms that I experienced do not seem consistent with the experiences in that thread. I'm kind of hopeful that it is as simple as some tubes coming off that need to be secured. If not that, it might be the MAP sensor. If not that... I'm SOL. Thankfully the FRS isn't my only car or else this would really be annoying.
Vortech frs e85 Dynosty tuned charged86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 10 06-19-2015 01:52 AM
Vortech Visconti Tuned on BRZ Limited v1ru5 Member's Car Journals 85 01-08-2015 02:09 PM
Vortech Visconti tuned on ft86me ft86me Forced Induction 38 08-25-2013 10:00 PM
FA20Club tuned Vortech kit 93 octane draggin_az Forced Induction 58 05-29-2013 04:45 PM
Vortech charged BRZ, Perrin tuned. Wonderbar Forced Induction 20 05-28-2013 01:31 PM
