Old 04-07-2014, 08:08 PM   #29
Basket Case
Drives: 2013 Raven fr-s
Originally Posted by CSG David View Post
Most wheels are a downgrade in performance compared to the stock wheel. Just something to keep in mind...
Why do you say that? Weight?
Basket Case is offline   Reply With Quote
Old 04-07-2014, 08:08 PM   #30
CSG David
CSG David's Avatar
Originally Posted by Mikepage View Post
Ok this it that I do not know and why am asking. Thanks!
Not trying to scare you. The general population will not agree with my statement saying it's too heavy or too ugly. The real performance benefit comes with a properly designed and manufactured wheel. This means weight is optimized with proper rigidity. All wheels will bend if you do it justice. The way it fails is probably the interesting part of wheel design that takes some time to develop. Everything is always a balance. If you improve weight reduction, you will reduce rigidity/strength, etc. There is always a trade-off.
Old 04-07-2014, 08:09 PM   #31
ZionsWrath
Thanks
ZionsWrath's Avatar
I don't really think it makes sense to have 1 set of wheels that are DDing and tracking. Maybe if it is only autocross.
Old 04-07-2014, 08:10 PM   #32
Mikepage
Mikepage's Avatar
Drives: Scion FR-S 2013 Raven
Wheels and tires setup for 1000$
I will look at the Toyota dealer for the TRD I think, it's probably the best choice for me without shipping cost.
o= FR-S =o
Mikepage is offline   Reply With Quote
Old 04-07-2014, 08:11 PM   #33
CSG David
CSG David's Avatar
Heavy wheels don't necessarily mean bad performance; it means it probably won't fail as easily and it may actually improve overall performance. Also, the way it is cast and how tight the quality control is what determines how the wheel can fail and in what modes of failure. For this, I know OEM wheels are tested to ensure those proper failure modes.
Old 04-07-2014, 08:12 PM   #34
CSG David
CSG David's Avatar
Most TRD wheels are outsourced by some manufacturer like Enkei with a massive markup...
Old 04-07-2014, 08:12 PM   #35
ZionsWrath
Thanks
ZionsWrath's Avatar
Those TRD wheels link on the first page are 18". Tires for 18s are generally more expensive than for 17s. Just to keep in mind.
Old 04-07-2014, 08:13 PM   #36
Mikepage
Mikepage's Avatar
If I go to the autocross, I'am going to take my OEM...
o= FR-S =o
Old 04-07-2014, 08:17 PM   #37
CSG David
CSG David's Avatar
Suggestion: Run OEM with spacers on RE11A tires. Take off spacers for autocross. Use that extra savings for more autocross, HPDE, gas, and consumables!
Old 04-07-2014, 08:18 PM   #38
Mikepage
Mikepage's Avatar
Then the best choice is to keep the OEM until you have the budget to get better wheels...
Then, I will keep my oem and bought an good set of tires.
I will probably enjoyed more compare to a cheap set of tires/wheels...
Thanks for all the info David!
o= FR-S =o
Old 04-07-2014, 08:20 PM   #39
Mikepage
Mikepage's Avatar
Why did you suggest to use spacers? For the look?
Spacers are not safe during autocross?
o= FR-S =o
Old 04-07-2014, 08:30 PM   #40
CSG David
CSG David's Avatar
Yes. That is if you crave the flush look.
Spacers are not a good idea unless you have extended studs for track/autocross use. Low quality spacers may have snapping stud issues or possibly the spacer bonding to the rotor due to dissimilar metals. Obviously where we live, we don't have an issue with that.
If you intend to use spacers, coat the mating surfaces with anti-seize as a corrosion prevention compound to reduce galvanic corrosion rate.
Old 04-07-2014, 08:30 PM   #41
Mikepage
Mikepage's Avatar
What is the weight of the oem wheels again? 22 lbs I think?
I think they are made but Enkei right?
o= FR-S =o
Old 04-07-2014, 08:40 PM   #42
CSG David
CSG David's Avatar
Not completely sure about that. I need to check on that information. Enkei does make a lot of OEM wheels. ~40lbs per each tire+wheel
SOLD: OEM BRZ Wheels + tires - 1000 miles - super clean, no TPMS xman11 Wheels and Tires 6 11-19-2013 11:55 PM
Stock Wheels and Tires (Less than a 1000 Miles) Complete Cross Wheels and Tires 4 09-23-2013 01:43 AM
17 in TSW TRACK STAR RIMS WHEELS WITH TIRES LIKE NEW - $1000 Ucmd03 Wheels and Tires 0 08-26-2013 01:52 PM
FS in IL - OEM tires only 1000 miles Captain Insano Wheels and Tires 9 07-21-2013 06:39 PM
FR-S wheels and tires, less then 1000 miles Vonsamhain Wheels and Tires 3 10-29-2012 04:27 AM
