Old 04-06-2014, 07:35 PM   #967
DC2R
Drives: 2014 Scion FR-S
Originally Posted by mid_life_crisis View Post
This appears to be proof that if you have 93 readily available there is room to play.
Yep. Perhaps there can be a thread where people can post their tunes. I would like to see what parameters people switch for 93.
Sent from my GT-N5110 using Tapatalk
DC2R is offline   Reply With Quote
Old 04-06-2014, 10:58 PM   #968
FingR-S
I got sucked into boost..
FingR-S's Avatar
Drives: Whiteout FR-S & Supercharged BRZ
Originally Posted by grodenglaive View Post
That was my experience as well with stage 1 on a stock car. Just installed mine yesterday (v 1.58). I noticed the sound change too and more pull from 4-5 k. The only thing I didn't like is now it seems I have to press the gas pedal down a little further before releasing the clutch when starting out in 1st; I was hoping for less dead zone.
Correction - I'm running v 1.58 (not 1.55)
That's interesting - my "dead pedal zone" was minimized significantly after the OFT tune.
Are you running on stock intake/exhaust - Perhaps a more free flowing intake and exhaust would help that?
I'm running Perrin 2.5/Resonated with drop-in AFe air filter.
For sale: 2013 BRZ Vortech Supercharged with nice updates.
Vortech Supercharger - Perrin exhaust - 245 RS3 on RPF1's
FingR-S is offline   Reply With Quote
Old 04-06-2014, 11:10 PM   #969
steve99
Drives: FT86
Originally Posted by nelsmar View Post
I feel stupid for having to ask this but I have gone through rom raider multiple times looking for the rear o2 AF corrections, has anyone seen this? I cannot find the corrections for this anyway.
Only guessing here but seem to remember reading the second o2 sensor was only to monitor header CAT efficiency and pop up cel code. Don't Ecutek guys hijack that sensor input for wideband fail safe, think the OFT guys also setting up a wideband on this input as well that can be read by oft, but if I understand it correctly it just monitored by oft by reading ram address in ecu.
It would appear you may need and ecu code patch to actually do something with the input data.
Old 04-06-2014, 11:12 PM   #970
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
The dead zone will go after a few drives.
Took a couple days for mine to go away.
The Following User Says Thank You to Andrew025 For This Useful Post:
grodenglaive (04-07-2014)
Old 04-07-2014, 12:27 AM   #971
s2d4
s2d4's Avatar
Or just do what everyone else does.
Turn on ignition, press the pedal quite a few time from fully depressed to fully compressed, then turn on the car and done.
The OCD in me find this process rather soothing for some reason..
Old 04-07-2014, 12:33 AM   #972
Andrew025
Andrew025's Avatar
That has never worked in my car for some reason. I've tried it multiple times but no success.
Old 04-07-2014, 12:37 AM   #973
s2d4
s2d4's Avatar
Maybe you had it in ACC instead of IGN?
Old 04-07-2014, 12:41 AM   #974
akyp
Drives: 2012 86
Same here. Usually takes a few drives to sort itself out.
akyp is offline   Reply With Quote
Old 04-07-2014, 03:21 AM   #975
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Quick update: New single channel data viewing option is coming soon. Attached is a design we mocked up. The purpose is to give the user an easy-to-see read gauge with both numerical and color-coded bar graph display. The user will be able to pick from any of the channels displayed in the realtime data screen (which is configurable). Simply touch any single channel in the realtime display and it will zoom in We are working on this update now but it shouldn't be too long until it is released. Should save some people the expect of having to buy separate a boost, wideband AFR or temp gauges!
Shiv@Openflash is offline   Reply With Quote
The Following 3 Users Say Thank You to Shiv@Openflash For This Useful Post:
gonzo (04-07-2014), s2d4 (04-07-2014), troek (04-07-2014)
Old 04-07-2014, 07:03 AM   #976
grodenglaive
Drives: asphalt FR-S
lol that's also how to calibrate my racing sim. Will try it.
grodenglaive is offline   Reply With Quote
Old 04-07-2014, 07:39 AM   #977
troek
troek's Avatar
Drives: 2012 Toyota 86
yesterday in my car my friend said" they should make it so if you just view 1 or 2 channels its bigger and easier to read". now im gona have to find a mounting location, lol. i tuck it in my seat and check it on the straits now. any chance anyone makes a longer obdII cable for this thing?
troek is offline   Reply With Quote
Old 04-07-2014, 07:52 AM   #978
Kodename47
Kodename47's Avatar
Drives: UK GT86
OBD extension cables all over eBay for peanuts
.: Stealth 86 :.
Kodename 47 DJ:
troek (04-07-2014)
Old 04-07-2014, 07:59 AM   #979
troek
troek's Avatar
ahh thanks, i guess i figured the OFT side of the cable was OFT specific. but i didnt even realize you could extend it on the obd side. i was just thinking of a single longer cable.
Old 04-07-2014, 09:21 AM   #980
AdrianG
Generally Well Liked
Drives: '08 STi Hatch, '11 Outback 3.6R
I use an extension that I got from scantool.net, no issues. I leave the extension plugged in since the obd2 ports on our cars can be easily damaged.
- AdrianG
AdrianG is offline   Reply With Quote
#lolwut, divinecomedy, dopeandcashcabinet, free shiv now, goddamitimissedit, golden cage, i missed the show, looks good, missed the fun, omgbbq, shiv 2016, thefatandthefurriest
Tablet on the dash ! TRD_86 Electronics | Audio | NAV | Infotainment 23 05-16-2015 04:48 AM
Tablet Install ThugNasty Electronics | Audio | NAV | Infotainment 4 04-13-2013 04:15 PM
Blutooth OBD II and a 9.7 tablet.. Scooby South Electronics | Audio | NAV | Infotainment 10 12-16-2012 09:11 PM
7.0 Tablet w/ Torque App Thatruth2001 Northwest 26 11-21-2012 12:53 PM
