| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#2227 |
Drives: 2013 FRS
Hey everyone currently on 18x10 +44 on 245 40 18 and have no issues but I'm wondering what kind of camber adjustment would it take to run 255 35 18
Currently = Camber -1.8 f -1.3 rear Kw coilovers Drop is the same amount that come out of the box. Haven't touched height adjustment. I liked the height out of the box. Thanks! Sent from my iPhone using Tapatalk |
#2228 |
VehicleDynamicsSpecialist
Drives: iG FR-S
Measure where you are at now with clearance.
Keep in mind that tire manufacturers (brand a vs brand b) may measure actual width differently . 245 isn't always a 245. Research the actual width of the tire on there now and compare to your new tire choice
"The best track modification you can ever make is between the steering wheel and seat." - CSH |
#2229 |
Captain Stabbin
Drives: 2013 FRS Asphault
Hey guys quick question on fitment,
Enkei raijins Front 18x8.5 +45 w/ 245/35 Rear 18x9.5 +45 w/ 265/35 I have seen those setup ran but guy was on sportlines, I'm currently on stock suspension and undecided on what route I will be going as far as suspension in the future. Thanks. |
#2230 |
Drives: 2003 FR-S
Yesterday, I was saying that I may want to get the XXR wheels but my plan just changed. I am going to get either Enkei Raijin or T6S with 18x8.5 ET45 (225/40/18) front and 18x9.5 ET45 (255/35/18) rear. Tires are most likely Hankook V12.
Can some tell me whether this setup will be okay on stock suspension? Will they flush with the front and rear fenders? Regarding the wheel lugs, what is the size and length that I should get? Thanks. Last edited by Gps360; 03-20-2014 at 11:32 AM. |
#2231 | ||
Drives: FR-S Firestorm 6MT
http://www.ft86club.com/forums/showthread.php?t=21697 @Asphalt TG, I'd go with the smaller tire sizes like @Gps360 is considering, that's alot of tire for the FRS unless your FI. @Gps360, no need for spacers, you should be good with stock suspension. It's close, but should fit and won't rub the fenders. Check inner clearance to see first if you need to add spacers, but don't think so. |
| The Following User Says Thank You to Slick For This Useful Post: | Asphalt TG (03-21-2014) |
#2232 |
Drives: 2003 FR-S
How about the wheel lugs? The guy from the tire shop said the OEM lugs could not be used for the new wheels.
Regarding those racing lugs, what length and size should I buy? The are so many for sale in the stores but I have no idea which to pick. |
#2233 | |
| The Following User Says Thank You to Slick For This Useful Post: | Gps360 (03-21-2014) |
#2234 |
Drives: 2003 FR-S
I see, so they are 12x1.25 cone seat.
Thanks. |
#2235 |
Captain Stabbin
Good looks @Slick, ya I think I read every post on that thread lol here's the set up I went with..
H/S Enkei Raijin 18x8.5/9.5 +45 Hankook Venus V12 235/40 255/35. |
#2236 |
Drives: 2003 FR-S
I went to the wheel shop this morning, the sales guy told me I should pick 18x8 et45 with 225 front and 18x9.5 et45 with 255 rear.
Any problems? Wheel are enkei Rijan. Reason is 18x8.5 front will make the front wheels stick out a bit of the fender???? Last edited by Gps360; 03-22-2014 at 09:27 PM. |
#2237 |
Drives: 1995 Supra TT & 2013 FRS
Anyone have 17x10 or 18x10 +38? Or at least those sizes with offsets around +35-44? I have 17x9.75 +25 and looking to go wider in the rear!
#2238 | |
Unless he has an FR-S, I wouldn't worry what he thinks. That's why you're on the forum, for FR-S specific advice right? |
#2239 | |
Check the wheel directory for that size and click on the link which will bring you to the thread for that setup. |
| The Following User Says Thank You to Slick For This Useful Post: | xia (03-23-2014) |
#2240 |
This is all overwhelming/confusing to me. There are so many different routes to take. I'm new to owning a FR-S, and modding in general. From what I've gathered a 9" wide wheel is an underpowered car? I want "flush" wheels but not the cost of performance. I hate how the OEM's are tucked inside of the wheel wells? I see so many people running so many different H/W/O's, to the point that I don't know which route to go. I want an 18, Pretty flush with the fender, I don't want to make fender mods, and want a wheel wider that the 7" factory. Also, I plan on adding Eibach Sportline within the next week until funds are sufficient for coilovers. Has anyone done a similar setup? Or can anyone help me?
Thanks JoCruz |
| Tags |
| fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width |
| Determining the proper width size of the tire | CyberFormula | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 49 | 05-23-2014 09:11 AM |
| Correct tire width for each wheel width | DarrenDriven | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 08-16-2012 02:03 PM |
| TIRE SIZE CALCULATOR | White64Goat | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 08-15-2012 02:31 AM |
| Tire Width vs Wheel Width | Synack | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 40 | 08-12-2012 11:21 PM |
