Old 03-21-2014, 06:08 PM   #71
chas3wba0
chas3wba0's Avatar
Drives: Yes
Originally Posted by Tainen View Post
Another example of what not to do.
You should never "punch" the gas while the wheel is turned, in a sweeper, on wet. Roll on if you want power. Smooth, progressive. Then if you overpower the tires, it's also smooth and progressive, and easy to correct.
RWD driving is hard. go to a car control clinic.
Yup, learned the hard way lol but in my defense, I had developed some pretty bad habits from 2 years of driving a heavy, grippy, and underpowered BMW 325i that never lost traction no matter how hard I tried. But I agree, I definitely will be signing up for one of these clinics within the next couple months
"If thy pleaſure be in Underſteere, thou art Weird." - Distraxi
Old 03-21-2014, 06:10 PM   #72
illest86
Originally Posted by Dezoris View Post
This type of thing happens to everyone eventually. All suspension is stamped steel on the front. Looking at swapping in new control arms bolts, end links, strut, wheel bearing maybe steering rack. Only about 1k right there. Sheet metal is sheet metal no biggy.
Take it in stride, learn from it fix the pile and get back on the road.
Well said. It's all part of the experience. Sometimes they are just scars, really expensive scars.
Ask the Hoonigan boys if their cars are in good condition
illest86 is offline   Reply With Quote
Old 03-21-2014, 06:34 PM   #73
chrisl
Drives: 2006 Cayman S, 2007 Outback 2.5i
3) Go to a car control clinic hosted by your friendly local BMW, Porsche, or other enthusiast driving club. They will teach you how to counter understeer, oversteer, extreme braking maneuvers, and many other scenarios. I personally consider this mandatory driver training for anyone that is on the road. Costs $100, and literally saves every driver that takes it many thousands of dollars in repair costs, insurance rate increases, etc.
This. 100% this.
As an added bonus, it's fun too. It lets you play around with the limits of your car, and figure out how to control the car at (and beyond) those limits in a safe environment, so if you start to lose control unexpectedly on the street, you will have a much better idea what to do. I think everyone should take one of these courses.
chrisl is offline   Reply With Quote
The Following User Says Thank You to chrisl For This Useful Post:
dad&sonFRS (03-21-2014)
Old 03-21-2014, 06:52 PM   #74
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
Typical. Blame the car.
You guys remind me of musicians i use to play with. Oh man, it's the guitar...not me!
The Following 2 Users Say Thank You to dem00n For This Useful Post:
bedabi (03-22-2014), Luis_GT (03-21-2014)
Old 03-21-2014, 07:01 PM   #75
mad_sb
Drives: 2013 Asphalt FR-S
Originally Posted by dad&sonFRS View Post
So i took a picture of where it happened , and if you look closely you can see where my tires went. It was a combination of that puddle and the dirt the followed, which explains the understeer and why the car didn't react. well, i guess it was just really bad luck and timing.
Wrong line into the corner my friend, your were off camber and hitting a dip (will unsettle the front end on the rebound = reduced front grip) filled with water and probably mud (lowers coefficient of friction further reducing grip).
However, please understand the puddle is not at fault, you are. No offense intended.
Good luck getting it all sorted out.
The Following User Says Thank You to mad_sb For This Useful Post:
Old 03-21-2014, 07:16 PM   #76
Dezoris
Dezoris's Avatar
Its my double bass pedals bro spring tension all wrong.
The Following 2 Users Say Thank You to Dezoris For This Useful Post:
dem00n (03-21-2014), ZionsWrath (03-21-2014)
Old 03-21-2014, 07:52 PM   #77
Tromatic
Thanks that actually helps a bit .. but its amazing to see how that small puddle of water, could lead me to coasting on dirt and then hitting that rail
Stomping the brakes and then deciding to try breaking the ass end lose probably didn't help either. ETA: What was the posted speed limit on the ramp? OP, you should probably realize that YOU were responsible for what happened if you want to learn anything. ETA again: Why StopTech pads? Any post-install bedding recommendations in the install instructions?
Old 03-21-2014, 07:57 PM   #78
dnieves
Drives: FR-S 10 Series
Originally Posted by Jdogg88 View Post
I went through Toyota to get it fixed with insurance. They took a month to fix her but were easy to deal with and she drives just as good as day 1. After the incident my insurance only went up about 50 dollars more a month
That comes out to only $600 a year.
dnieves is offline   Reply With Quote
Old 03-21-2014, 08:12 PM   #79
stugray
Drives: 2013 GBS BRZ Limited
There had to be just a little of that pesky "velocity" involved with a side of momentum.
How about driving too fast?
Old 03-21-2014, 08:59 PM   #80
Jdogg88
Drives: Sapphire Blue ‘23
50 more a month dude
Jdogg88 is offline   Reply With Quote
Old 03-21-2014, 09:00 PM   #81
chrisl
Which is $600/yr.
Old 03-21-2014, 09:05 PM   #82
Jdogg88
Originally Posted by chrisl View Post
Which is $600/yr.
Yeah, I know simple math. I never said I only pay 600 a year for insurance. I said I only had to pay an extra 50 on top of my initial insurance payment.
Old 03-21-2014, 10:30 PM   #83
ZionsWrath
Thanks
ZionsWrath's Avatar
Originally Posted by Tromatic View Post
I'd be willing to bet that there are several crimes here in the nannny states of NY and CT.
Don't forget to add your uncle was with you, since you are under 18.
http://dmv.ny.gov/younger-driver/gen...tion-about-gdl
ETA: Wait. You are under 18 and driving with no paperwork, your dad is paying, and it's insured by your uncle who is out of state. Rest of the story, please...
I'm in NY and because I took drivers education course I was legally allowed to drive on my own with full license at 17
The Following User Says Thank You to ZionsWrath For This Useful Post:
Old 03-21-2014, 10:32 PM   #84
ZionsWrath
Thanks
ZionsWrath's Avatar
Damn musician excuses tsk tsk
DIY: Rhino Ramp extenders Laika DIY (Do-It-Yourself) Guides 15 06-22-2014 11:29 AM
$25 Rebate on Race Ramp Purchases + FREE Shipping @ JWM! JWMotoring Mechanical Maintenance and Tools 0 10-15-2012 04:41 PM
CP Rail on strike. Where is my BRZ/FRS? percyng CANADA 15 05-28-2012 10:17 PM
Is your BRZ shipment going to be on rail in Canada? dorkymork BRZ First-Gen (2012+) — General Topics 1 05-23-2012 05:44 PM
Scion FR-S pushed off a ramp!!!! SUB-FT86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 22 05-17-2011 12:54 AM
