Old 03-18-2014, 09:13 PM   #435
transition
Originally Posted by JDLAutoDesign View Post
Did you try to the bracket on the mount with the front and rear loosen. Everything needs to be loose then tightened. Our brackets are not the same dimensions/size OEM just use the mounting point.
Yes i did. There is absolutely no way the front pipe will fit like this. I had the over-pipe loose as i mentioned before and of course the cat-back is simply floating. The bracket is about an inch off of where it should be.
transition is offline   Reply With Quote
Old 03-18-2014, 09:17 PM   #436
transition
Another factor here is you guys designed the bracket so small i have to literally push the front pipe through it. Once it's on there there is no wiggle room or adjustability at all.
Old 03-18-2014, 09:18 PM   #437
JDLAutoDesign
JDLAutoDesign's Avatar
Drives: 13 FRS
Put in on as per the sequence below with all the connections loose and snap a pic. You may need to also have the over pipe loose to get it aligned
1 Hang it on the bracket and start the mounting bolt
2 Start the bolts in the front of the FP
3 Start the bolts in the rear FP
JDLAutoDesign is offline   Reply With Quote
Old 03-18-2014, 09:24 PM   #438
transition
I've tried every which way to hang this thing. The problem is the BRACKET IS TOO SMALL.
Thank you for posting that picture it shows exactly the problem! You changed the size of the bracket design. Case in point - look how much smaller my bracket is then what is shown in your own photo:
Old 03-18-2014, 09:27 PM   #439
JDLAutoDesign
Drives: 13 FRS
The mounting point on the fixture hasn't changed regardless of the length of the bracket. Send it back and we can inspect it and get it corrected. What as your order so I can note it and send you a return label
Old 03-18-2014, 09:30 PM   #440
transition
Arg.. Man you're not getting it. Why is it so hard to realize you've made a simple mistake in making the bracket smaller? Look how much smaller my bracket is compared to your photo. It has to be force fit onto the car versus your photo clearly shows there is some adjustability. How long will a replacement take i only have 3 weeks MAX before the car needs to leave for an event?
Old 03-18-2014, 09:33 PM   #441
JDLAutoDesign
Drives: 13 FRS
If we made a mistake we will fix it not saying we didnt. Its standard procedure to get photos and get it sent back.
Old 03-18-2014, 09:34 PM   #442
M3BimmerBilly
Drives: Nothing Cool
Wow. drop at least $1K with these guys and they treat you like crap. Clearly they made a mistake and this guy has shown it repeatedly. I can't believe any respectable tuner would make a customer wait weeks for a product and then when its wrong deny all responsibility.
JDL = another tuner that will be extinct in 2 years if they can figure out customer service.
M3BimmerBilly is offline   Reply With Quote
Old 03-18-2014, 09:36 PM   #443
JDLAutoDesign
Drives: 13 FRS
Not treating anybody like crap. Its our procedure to get photos of the issue as sometimes there can be some things that are overlooked. Either way we will get it taken care of
Old 03-18-2014, 09:38 PM   #444
Bonks86
Drives: Gt-86
They aren't denying responsibility.... They are trying to help in real time... How is giving the guy some suggestions on how to install poor customer service? I think it can be said that not everyone on here that buys parts knows how to install them correctly. That being said it definately could be a mistake and JDL will get it fixed. Ronnie helped me when i had some leak issues and we got it squared away.
Bonks86 is offline   Reply With Quote
The Following User Says Thank You to Bonks86 For This Useful Post:
DAN_BRZ (03-19-2014)
Old 03-18-2014, 09:40 PM   #445
transition
How many more photos do you want?
Old 03-18-2014, 09:40 PM   #446
xDanger_208x
xDanger_208x's Avatar
Drives:
After drilling out the bracket hole on my JDL front pipe it still wouldn't line up properly.. especially with a catback utilizing a flat gasket instead of the doughnut.
I ended up cutting off the bracket and making a new one.
xDanger_208x is offline   Reply With Quote
The Following User Says Thank You to xDanger_208x For This Useful Post:
transition (03-18-2014)
Old 03-18-2014, 09:40 PM   #447
JDLAutoDesign
Drives: 13 FRS
Just your order # so I can send you a return label
Old 03-18-2014, 09:42 PM   #448
transition
I asked a question about how long it will take. I have an event in 3 weeks and need to be sure i can get it back ahead of that.
JDL Auto Design ft_sjo User/Vendor/Sponsor Reviews, Feedback, Comments 58 04-28-2017 11:13 AM
JDL Auto Design alexand3r User/Vendor/Sponsor Reviews, Feedback, Comments 4 12-11-2013 01:05 PM
New Scion FR-S products by Coverking are now at TAP Auto parts TAP Auto Parts Interior Parts (Incl. Lighting) 9 06-06-2013 08:43 AM
Check out some of the new products from Auto Finesse DetailersDomain Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 2 05-08-2013 09:42 AM
JDL Auto Design...What We Do JDLAutoDesign Announcements, Contests, Giveaways 21 10-30-2012 10:05 PM
