Old 03-16-2014, 05:27 PM   #3963
stockysnail
Just the tip
stockysnail's Avatar
I'm guessing just use the same coolant in the intercooler as what's in the radiator?
Old 03-16-2014, 06:34 PM   #3964
Calum
That Guy
Drives: 2013 asphalt FRS MT
I have ZERO information on what sprintex suggests, but distilled water with water wetter would give better cooling efficiency than any coolant I know of.
The Following User Says Thank You to Calum For This Useful Post:
mad_sb (03-17-2014)
Old 03-16-2014, 06:42 PM   #3965
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
I'm not impressed by how each laminova core is sealed. My understanding is that each core gets an o-ring on each end. No screwing in. Nothing else. It doesn't seem to be the best design since a small tolerance screwup or mistake in installation leads to the crap multiple people have faced.
The Following User Says Thank You to EAGLE5 For This Useful Post:
swift996 (03-16-2014)
Old 03-16-2014, 10:15 PM   #3966
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
These numbers are quite good for 92 octane and the more sedate AFR we have it running. With the 70mm pulley, it'll really start to shine on e85 where we can push more timing. H2O/meth will do similar as well. For reference, this was posted with the FB Turbo: http://www.ft86club.com/forums/showp...&postcount=124
So you're not too far off at all. Especially considering that below 4500 the SC wins
But add some ethanol or h2o/meth, the intake temps become less relevant (weakness of the SC) and you'll see HP get closer to 300 and tq to 250...totally different car at those levels!
The numbers aren't impressive but not horrible. I've hit the wall on this kit and the only thing I can do running 92oct gas is to get a different kit, run meth injection, or run e85 (or both). I'd prefer to stay on the normal gas for convenience.
The kit can only run on the stock MAP sensor as any other sensor like the 3bar with freak out the ECU at the top end for an unknown reason. There's no post blower temp reading.
I'd say this kit is great for someone that wants about what you see in HP/TQ and doesn't want to bother getting supporting mods like exhaust, intake, a clutch, injectors, or fuel pump, and an OEM look, or just that nice supercharger whine.
The two lines are 75mm stock pulley, not intercooled, 92oct gas on BRZedit tune @Drift-Office Bob correct me if I'm wrong). The second is 70mm pulley, intercooled, 92oct gas on EcuTek.
Big props to Bob at Drift Office @Drift-Office and Mike at Moto East @moto-mike for figuring out the difficulties with this kit and making my car shine with what it has. You've earned a loyal customer with your superb customer service and quality work.
Attachment 70788
Xero-Limit is offline   Reply With Quote
Old 03-16-2014, 10:44 PM   #3967
CK_Bladesmith
CK_Bladesmith's Avatar
Drives: Raven FR-S
Anyone get the 8.5 delicious tune yet?
Raven FR-S mods: Unichip, Ground Control street coilovers with camber plates and strut tower brace, SPC Lca's, Drag DR-38 wheels with Dunlop Direzza DZ101s, Perrin CAI and silicone inlet tube, Perrin 3" resonated catback, Perrin high flow catted front pipe, Rev Works UEL header.
CK_Bladesmith is offline   Reply With Quote
Old 03-17-2014, 12:42 AM   #3968
Area86
Area86's Avatar
Drives: 2013 BRZ limited SWP
Not yet. Put in my support ticket requesting for it though.
Sent from Samsung Galaxy Note 3
Area86 is offline   Reply With Quote
Old 03-17-2014, 12:44 AM   #3969
CK_Bladesmith
Drives: Raven FR-S
I'm unable to create a ticket. I get an error that says the site admin needs to create and enable a client before I can make a ticket....dunno what that's all about.
Old 03-17-2014, 12:47 AM   #3970
Area86
Area86's Avatar
Send Bill a PM or email and ask him the enable in it for you. I had the same thing happen awhile back and he fixed it for me.
Old 03-17-2014, 12:48 AM   #3971
CK_Bladesmith
Drives: Raven FR-S
I sent him an email about it earlier. Was really hoping to try out this new tune before I go back to work for 2 weeks
Old 03-17-2014, 02:17 AM   #3972
Drift-Office
Drift-Office's Avatar
Drives: AE86 / FRS / FC3S / GC8 / S14 / R32
Both of them were with 92 Octane, ECUTek. The first one was our calibration pre-intercooler install. The second was a custom calibration from @moto-mike, which I strongly recommend all who have the Innovate setup to at least get a calibration from.
I couldn't figure out why the setup was wigging out after the IC was installed and only after conferring with Mike @ Moto-East was it then I was told that it was an issue everyone was seeing (it's in the Innovate owner's thread) and that the stock MAP sensor was needed to fix this.
I had previously spent over 2 weeks trying to figure it out up to that point, so I have no wish to address this setup, ever again.
Cheers!
Bob @ Drift-Office, LLC
Drift-Office is offline   Reply With Quote
The Following User Says Thank You to Drift-Office For This Useful Post:
sw20kosh (03-17-2014)
Old 03-17-2014, 09:52 AM   #3973
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Nice selection for comparison, haha. A properly running FBM kit will start making more power and torque than the Innovate in the 3500 to 4000 RPM range, but the Innovate does dominate that 2000 to 3500 RPM range.
The Following 2 Users Say Thank You to King Tut For This Useful Post:
DeliciousTuning (03-17-2014), Xero-Limit (03-17-2014)
Old 03-17-2014, 12:16 PM   #3974
poorsche
poorsche's Avatar
Drives: 13 BRZ Limited, 2000 Impreza Sport
Non intercooled in the mail, having it tuned locally hopefully by the end of the week! This thread helped steer me towards innovate. So thanks to all you beta testers!
poorsche is offline   Reply With Quote
Old 03-17-2014, 01:32 PM   #3975
xxscaxx
Drives: 2013 SWP BRZ
It would have been nice if people came out about the issue with the map sensor, or the simple issue of the intercooler wigging out at high rpm. It would have saved me a ton of money.
Still waiting to go get retuned, but can't wait to be over and done with tuning for a while. I'm sick of it lol
xxscaxx is offline   Reply With Quote
The Following 2 Users Say Thank You to xxscaxx For This Useful Post:
NickFRS (03-18-2014), xjohnx (03-17-2014)
Old 03-17-2014, 01:45 PM   #3976
calispec
calispec's Avatar
Drives: Subaru BRZ with Delicious Innovate
I have been through a few tuners and tunes. I would seriously suggest @DeliciousTuning. He has a LOT of time on the tune and will continue to develop it. It is the best tune I have used this far. Save yourself money and time. He was the one who told me about the MAP issue back in September and is why I didn't waste $300 on a new one. Just my honest opinion.
2013 BR-Zed, Innovate Powered, Delicious Tuned, Zeltus Cooled. Build Thread
www.GT86Mounts.com
calispec is offline   Reply With Quote
The Following 2 Users Say Thank You to calispec For This Useful Post:
DeliciousTuning (03-17-2014), Lawnik (03-17-2014)
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
