#3865 |
Drives: '13 BRZ Limited WRB Phantom ESC 1.5
I read the first 30 pages of posts again tonight. A lot of the pics seem to no longer be there.
Would someone be kind enough to post the pics or send me the link to pics of what the batteries look like and where they're being installed? Would also like to know the exact batteries that are recommended for this kit... Thanks a lot! |
#3866 |
Drives: Subaru BRZ
You will need a different harness from Rob for the dual battery pack. You will also need a different wood support and battery tray. Here's a photo of my installation. All the ground connections are made to the new terminal that you can see. No need to run a ground wire to the starter battery - just find a different ground in the back. I used a 4 gauge wire for the power lead to the back and seems to be working fine. Rob does recommend a 2 gauge.
| The Following 5 Users Say Thank You to jpit For This Useful Post: | Boofneenee (03-09-2014), DAEMANO (03-09-2014), Gums (03-10-2014), nlowell (03-10-2014), robwbright (03-09-2014) |
#3867 | |
"Wood support"? Not sure what that is. Where are people getting the different battery tray? Or perhaps I could just manufacture one. Also, when you say "in the back" in reference to a different ground, do you mean in the back of the engine compartment? |
#3868 |
Drives: Sterling Silver BRZ
Sorry if this has been asked before but searching this topic didn't give me the answer I was looking for...
To get an idea how much of a bump in performance this gives, I'd like to know how much the acceleration times improve with the esc ? Thanks in advance ! |
#3869 | |
Drives: 2013 Scion FRS
For the base install you just need the ESC kit and the three batteries listed. It re-uses the stock battery tray and location. If you want to upgrade to the dual-battery pack you will need two of the $90 battery kits (2 dump batteries in each kit), a modified ESC harness, a modified battery tray, and you'll need to relocate the starter batter to the trunk with a recommended 2 gauge power line. I understand you don't need to run a ground line because the battery and accessories can be grounded in the trunk and engine compartment respectively. That's what I've gathered anyways...
Complete Part Out: http://www.ft86club.com/forums/showthread.php?t=125688
| The Following User Says Thank You to nlowell For This Useful Post: | robwbright (03-09-2014) |
#3870 | |
Drives: 2013 Asphalt 6spd
Not sure about the battery tray, maybe just a universal at the parts store. "in the back", means that when you relocate the starter battery to the trunk for example, you will just run the ground wire to the body. If you look at the pic above, you will see the black factory ground wire hooked up to a post installed in a spare hole in the fender (Jpit did you have to drill the hole larger to get it to fit?) and the following image also courtesy of jpit, shows the negative battery terminal being grounded to what looks like the spare tire tie-down. |
| The Following 3 Users Say Thank You to Target70 For This Useful Post: |
#3871 | |
#3872 | |
| The Following User Says Thank You to raven1231 For This Useful Post: | robwbright (03-09-2014) |
#3873 | |
#3874 | |
Months ago Fenton got 6.5 secs 0-60 at altitude - 3500 feet, I think he said (and he says he's not very good at shifting... LOL). I believe that's significantly faster than the time he had gotten before. Someone asked for a side by side 0-60 test against a stocker, but it was noted that 0-60 is a very inaccurate measure car to car and driver to driver because of different skills in shifting. He also ran a 60-120 and I think it knocked the time down by like 5 or 6 seconds. I seem to recall that in one of the videos someone at lower altitude was in the mid to high 5s 0-60. If you look back through pages 20-30, I think it would be around there. Last edited by robwbright; 03-09-2014 at 02:21 PM. Reason: additional info |
| The Following User Says Thank You to robwbright For This Useful Post: | projectXTR (03-09-2014) |
#3875 | |
I realize that if you add 2 more on top of that you're going to have to move something to the trunk. Which is not ideal since my sub box is already taking up 1/4 to 1/3 of the trunk. LOL. |
#3876 | |
#3877 | |
Lightning McQueen Driver
Drives: Limited Red 6MT BRZ
I was the one that was running the mid 5s but I was also on e85.
Installed Mods: Phantom Electric Super Charger | Open Flash Tune | Perrin OP/ HFC Front pipe | Invidia Q300 catback | ST Suspension | JDL Header | Flex Fuel |
| The Following User Says Thank You to Sojhinn For This Useful Post: | robwbright (03-09-2014) |
#3878 |
| Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras | Circuit Motorsports | Member's Car Journals | 4 | 03-21-2013 05:45 PM |
| Subaru BRZ : Full Throttle, powerslide, hard revving & ride | ESBjiujitsu | BRZ Photos, Videos, Wallpapers, Gallery Forum | 20 | 05-30-2012 07:43 PM |
| 86 Full Throttle Video + another. | Aus86 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 2 | 04-02-2012 08:07 AM |
