Old 03-04-2014, 05:12 PM   #71
gramicci101
Off Topic
Originally Posted by Turn in Concepts View Post
RaceComp Engineering Tarmac Springs have been installed on our Koni Yellows now for quite a while. I am so glad they sent us a set of these. Not much of a ride quality change from the RCE Yellows however the higher spring rate does make the car quite a bit more fun to drive!
What are the blue top hats in the picture with the RCE Tarmacs?
Old 03-04-2014, 05:25 PM   #72
Turn in Concepts
Turn in Concepts's Avatar
These are the prototype HVT non raising front camber plates, designed to work with stock struts/konis, or coilovers.
-Greg
Turn in Concepts is offline   Reply With Quote
The Following 2 Users Say Thank You to Turn in Concepts For This Useful Post:
gramicci101 (03-04-2014), SkAsphalt (03-04-2014)
Old 03-04-2014, 05:26 PM   #73
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
how do you like the whiteline sways, which ones did you go with. sways are really the only thing i think i'm missing here.
those top hats look great, i'm already on my third set of whiteline com-c and its getting to be the last straw. wanna ship a set to "test" to AZP so we can put it to the test on my v3's
Jive Turkey is offline   Reply With Quote
Old 03-04-2014, 08:09 PM   #74
gramicci101
Off Topic
-Greg
That's what I thought they looked like, but they were black in your store. Is blue an option?
Old 03-04-2014, 08:36 PM   #75
TouchMyHonda
Vtec Jesus
TouchMyHonda's Avatar
Can I get your opinions on the White Lin X-Heavy Duty rear sway bar kit? I have the kit sitting in the garage uninstalled because I live in Chicago and have been skull fucked by snow and the cold.
OFT Remote, OFH, Motiv OP & FP, Perrin 3' CB & 3' IT, Setrab/MoCal cooler, STI motor mounts, Wilwood 6/4 plot F&R 12.8 kits, Brake ducts, complete Whiteline catalog, complete bushing replacement, OSGiken clutch & Diff, 4.556 FD, Stance W/Spec valving 8/9 Swift.
TouchMyHonda is offline   Reply With Quote
Old 03-05-2014, 11:17 AM   #76
Turn in Concepts
I am running 22mm Front adjustable bar and 18mm rear adjustable bar.
PM sent!
Black is the only option for HVT camber plates, the blue was just for prototype.
Whiteline makes great products, we have ran them on our Subarus for about 10 years now. This specific kit like all whiteline products fits correctly, made of quality materials, most importantly it flat out makes the car handle better and more fun to drive!
As far as what rear bar to go with, that would depend on the rest of your setup and what you are doing with the car.
Old 03-05-2014, 03:33 PM   #77
Jive Turkey
the tuna, no crust.
don't have a pm
i was thinking WL 22m front and stock 2011 WRX rear....thoughts?
Old 03-05-2014, 04:05 PM   #78
2point0
2point0's Avatar
Drives: '13 BRZ Ltd WRB
don't have a pm
How big are those? I tried an STi stocker (19mm) and it was kinda scary. That was also on otherwise stock suspension and worn tires. Traction control was going batshit crazy! It might be better with your fat tires and KWs, though. I'll make you a good deal...
2013 BRZ Limited - SOLD
2008 Forester XT Sports
1967 Mustang Coupe - 289 V8
2point0 is offline   Reply With Quote
Old 03-05-2014, 04:13 PM   #79
Jive Turkey
the tuna, no crust.
iirc its 17 or 18mm.
why was it bad? extra tail happy?
Old 03-05-2014, 04:38 PM   #80
OrbitalEllipses
Drives: Attitude
17mm I believe. I imagine a 19mm bar would make the ass-end super dancy.
Old 03-05-2014, 04:39 PM   #81
2point0
2point0's Avatar
Yeah, it was slide-city. Or it would have been had I turned off the TC.
Old 03-06-2014, 11:06 AM   #82
Turn in Concepts
don't have a pm
My original setup was with STOCK front bar and a 2012 wrx rear, it worked out fairly well.
I do not think that the car is by any means scary but then again I do have a few suspension mods and a fairly sticky wide tire....
The most tail happy this car has been was when we were running ZERO toe all the way around.
-Greg
Old 03-06-2014, 01:03 PM   #83
2point0
2point0's Avatar
Yeah, some better grip would have helped tons. I should mention that when I installed that bar was during rainy season. Any little bit of wetness on the ground made me take corners very carefully. Now, with just RCE Yellows and MPSS, this car feels almost as confidence-inspiring as my WRX in the rain.
What toe settings do you guys like for this car?
Old 03-06-2014, 01:12 PM   #84
Jive Turkey
the tuna, no crust.
TIC BRZ
I'm tow in. Like .08. Makes it a bit more stable from my recent experience.
