#841 |
Thanks
Going to go to first track day ever this year, planning on more. Going to run my stock tire until they burn up.
What think of everything else stock and OEM camber bolts Carbotech XP10 RBF 600 |
| The Following User Says Thank You to ZionsWrath For This Useful Post: | CSG Mike (03-04-2014) |
#842 |
#843 |
#844 |
i'm sorry, what?
Drives: Canada
what's the magic behind WRC suspensions, seeming how the roads they travel on are actual roads, the level of grip these cars get is beyond my comprehension.
and why don't people immitate their setups and instead focus on touring style cars that wouldn't last a minute on country road.
#845 | |
Drives: '13 BRZ Ltd
The GD Impreza's had something like 8.5" of damper stroke on the rear struts. I seem to remember reading that for the GR chassis rally cars (same rear suspension as the BRZ - multilink), Subaru actually retrofitted struts in the rear. I wonder if I can find that source again. |
#846 |
Tons of travel, awesome dampers with lots of compression and not too much rebound. Lots of fluid capacity to reduce shock fade (and gas pressure helps).
- andy |
#847 | |
(Dirt) Rally suspension is made for compliance and are actually surprisingly soft. Tarmac Rally suspension is much closer to what you'd see on a track car. Everything is adjusted to specifically meet the needs of a given stage. |
#848 |
Drives: '23 BRZ
You'd probably be fine on XP8 pads and off-the-shelf DOT4 fluid. That's what I ran in the S2000, never any problems with pads or fluid over many track events.
#849 |
i'm sorry, what?
Drives: Canada
so tarmac rally is really the thing everyone should be immitating
but no one is what's up with that.
#851 | |
i'm sorry, what?
Drives: Canada
i'm just thinking outloud as to why this isn't common knowledge and why do i feel like i'm a minority in thinking all drivers shoudl strive to improve grip and compliance above looks and stiffness
| The Following User Says Thank You to 7thgear For This Useful Post: | solidONE (03-05-2014) |
#852 | |
Drives: '13 BRZ Ltd
$$$$.The higher level dampers seem to have more travel and obviously much better damping. And since most people are concerned with slamming the car (don't care about stroke) or optimizing the car for track/autocross (relatively smooth), it might not be as important. |
#853 |
Also, RCE Yellows sell quite well so maybe there is a lot of people with the same mindset. They're just not as vocal as those that want the car real low. And the Bilsteins only just came out.
Also, real rally coilovers are expensive. - Andy Last edited by Racecomp Engineering; 03-11-2014 at 11:21 AM. |
| The Following User Says Thank You to Racecomp Engineering For This Useful Post: | CSG Mike (03-04-2014) |
#854 |
Drives: 04 Toyota Tacoma Prerunner Reg Cab
B14 or B8+TarmacSprings...that is the question, hehe.
Which has more aggressive dampening (b14 or b8) and which has more aggressive springs (a large dynamic range 2.5-7kg progressive vs 5kg linear (which falls in between the B14's prog spring rates))? I know both aren't crazy, aggressive, full blown, race-only suspension setups (far from it, I know) ...BUT, I prefer to get the more aggressive setup (even though if it's only marginal). |
| Air Suspension Discussion Thread - Let's Get Nerdy | Andrew@ORT | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 174 | 02-13-2016 04:17 PM |
| RallySport Directs Everything Suspension thread!! | RallySport Direct | Brakes, Suspension, Chassis | 21 | 07-02-2014 06:31 PM |
| The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension | ModBargains.com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 63 | 05-22-2013 09:15 AM |
| 2012 Team USA vs the 1992 Dream Team | ERZperformance | Off-Topic Lounge [WARNING: NO POLITICS] | 1 | 09-14-2012 07:19 PM |
| Team build thread; PROJECT.STH | trueno86power | Other Vehicles & General Automotive Discussions | 0 | 03-02-2010 11:13 AM |
