Old 03-04-2014, 12:59 AM   #1
unlimited86
Drives: s2000
Drop something in the engine bay
Was installing HID and accidentally drop the stupid plastic bulb cover down into the bottom of the shield, does anyone know how I can take it out, or would it just roll out from driving?
unlimited86 is offline   Reply With Quote
Old 03-04-2014, 01:03 AM   #2
Carlitoz3
Carlitoz3's Avatar
Drives: 2013 MT Asphalt FRS
You need to take it to the dealership ASAP...
Carlitoz3 is offline   Reply With Quote
The Following 3 Users Say Thank You to Carlitoz3 For This Useful Post:
MaXimus (03-04-2014), supramkivtt2jz (03-04-2014), zlegend (03-04-2014)
Old 03-04-2014, 01:11 AM   #3
husker741
Drives: 2013 Whiteout Scion FR-S 6MT
When you say shield, you mean the splash guard under the header? It just is a few bolts and clips to take that off.
husker741 is offline   Reply With Quote
Old 03-04-2014, 01:11 AM   #4
D88
D88's Avatar
Drives: 2014 Scion FRS
Haha I did the same thing with a hose clamp once. Luckily it was close enough to one of the openings in the skid plate underneath that I could get a hook tool through the gap and pull it ahead. Then from the top I was able to use the same tool to hook it again and pull it up and out. What a bitch that was.
Anyways, definitely get it out of there before you drive or it will likely melt from the heat from the headers. Best case is that it just smells like burnt plastic. Worse case is that it starts a fire.
D88 is offline   Reply With Quote
Old 03-04-2014, 04:42 AM   #5
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
raise the front end from the middle jack point, as high as the floor jack can go. Then start tapping the shield and pray the bulb cover rolls off. It works for me when i accidentally dropped a bolt and it landed on the under tray.
Otherwise, just remove the tray.....i think it's only held by six bolts and a handfull of clips.
Fizz is offline   Reply With Quote
Old 03-04-2014, 09:19 AM   #6
frslee
Just drive it
Drives: 13' FR-S
Is this question really necessary to ask...? If you drop something, get down to the car, raise or whatnot, remove the bottom cover, find the plastic..
frslee is offline   Reply With Quote
**Vicious LED -PRICE DROP: Password:JDM Engine Bay Dress Kits Various Color Choices** Vicious LED Engine, Exhaust, Bolt-Ons 18 09-28-2013 04:06 AM
FINALLY engine is broken in...engine/tranny smell? denverizzles Engine, Exhaust, Transmission 18 09-15-2013 09:12 PM
Drop it Like its Hot! *Lets See Your Drop* VIXEN Suspension | Chassis | Brakes -- Sponsored by 949 Racing 92 09-07-2013 03:53 AM
Who is going to buy the FRS DROP DROP Shop? Tanuki Scion FR-S / Toyota 86 GT86 General Forum 1 10-18-2012 06:45 PM
Engine sputtering while idling with check engine light flashing, WTF speedy racer Scion FR-S / Toyota 86 GT86 General Forum 15 08-27-2012 07:50 AM
