#337 |
More fun to just go for a ride in their car and do some pull comparison with your car and theirs.
#338 | |
Drives: Asphalt FR-S MT
Very true! 98 runs great probably. However it's still on a stock tune. You should definitely try to find a car that's already running the OFT e85 tune. It almost feels like a different engine in the car. Instead of a torque dip. There's constant power up to 4k. Then at 4k it kicks in even harder and from there on it just keeps pulling harder and harder. Daily drivability has been improved so so much. It's very nice Sent from my iPhone using Tapatalk |
#339 | |
Drives: FT86
Unfortunately i am in the "sunshine state" I think @Burn is in Melbourne.I am currently running OFT tune on 98 (or united 100) and it works well. Don't expect huge HP gains there is only about 10 on a stock car on 98 fuel. The main benefit is its just smoother all round and better torque, less torque dip. Economy is pretty much the same or perhaps slightly better due better torque down low. You get a bit more kick on E85 another 10-15 or so HP through rev range on a stock car over 98 tune. If you want big HP you need Forced induction. Last edited by steve99; 02-23-2014 at 06:18 PM. |
#340 | |
Codename: Stitch
TL;DR - it's not that easy to just lend you a flash to try with OFT. Maybe someone is really nice and would let you try it but it's a lot of hassle for them. So yeah catch a ride with someone, that is asking a lot less of them.
#341 | |
Drives: Toyota GT86 Manual
Hi Yes, it is the torque dip that I would like smoothed out. I didn't realise that the OFT and ECU were 'married' so yes it is completely unreasonable for me to expect someone to put that effort in just to prove benefit. I guess for $500 the OFT is the best performance/dollar improvement for the stock car (even 10hp) and as I live about 2km from an E85 fuel station then that would be good before Phillip Island track days. Does the tune also change how aggressive the rev limiter is? I accidentally hit it in third coming onto the Phillip Island straight and it sucks big time. Thanks |
#342 | |
Slack Bum
Drives: FT86
#343 | |
Drives: FT86
You won't eliminate the torque dip with just OFT tune on petrol but it will be much better, add headers or E85 and it pretty well gone. both even better. Stock intake is pretty good not much gains in intakes. You also get Flat foot shift Launch Control DI seal fix mod (if you have earlier ROM's) Bumped up idle (100rpm) Last edited by steve99; 02-23-2014 at 07:01 PM. |
#344 |
Drives: 2013 Toyota 86 GTS
I am also in QLD.
e85 is brilliant! Ill be doing some dyno's and what not once my headers arrive as well. |
#345 | |
My Other Ride's a Jeep
Drives: 2013 BRZ Limited
#346 |
Drives: frs
I'm on e85 that's a little mixed with gas I would guess around e70 (first time I filled with e85 i had 3 gallons of 91 in my tank, second time I filled with e85 once I got to half empty on that first tank)
My AFR is too high. Should I rereflash now that I'm running a higher ethanol content? I think my first tank was about e60. With that tank, my afr was in the low 12s. Now that my tank has a higher ethanol mixture the AFR is in the mid 13s. http://datazap.me/u/gonzo/gonzo-0302 I haven't taken it past 6000 rpm because I was worried how lean it is I have the stock airbox with a drop in filter, nameless catted front pipe, and nameless axle back Last edited by gonzo; 03-02-2014 at 05:03 PM. |
#347 | |
Drives: 2013 FRS
#348 | |
Drives: frs
![]() I'm going to take it easy, no WOT, for a bit longer till I get all of the 91 out of my tank and the ethanol level stabilizes. Once I go WOT I'll log it and check AFR again. My thoughts on OFT and the tune: OFT is very easy use! I wish the cable was a little longer, maybe 6-8 inches, but it's manageable. When I first flashed the stage 1 91 tune, I didn't notice much of a difference from stock. The car was coming out of the torque dip sooner, but if I had bought OFT just for the 91 tune I may have been a little disappointed with paying ~$560 (with tax & shipping). Once I flashed to e85 I could instantly tell a difference. There isn't a torque dip anymore. Paying $560 for the e85 tune is a steal. ![]() Thanks for providing this at such a great price. The e85 tune is truly worth more than what I paid and that's why I'm going to have no problem paying Vishnu whatever it costs to custom tune when I get FI. ![]() Excellent customer service, response time, and pricing is how to make loyal, lifelong customers. Everyone else take note. |
#349 |
OpenFlash Tablet E85 (and gasoline) Maps now available
My second datalog on e85. Probably 150 miles on the tune
I've got no idea what I'm looking at so any help would be appreciated! http://www.datazap.me/u/kronos/e85-data-log-2 Edit: its a third gear pull |
#350 | |
Drives: frs
Your lt fuel trim, AFR, and IAM look good, but I just started learning about tuning a few weeks ago so I'll let someone else chime in. ![]() Is you tank filled with just e85 or do you have some regular gas mixed in too? |
| OpenFlash Tablet | Rombinhood@OpenFlash | Software Tuning | 1838 | 07-29-2023 06:35 PM |
| Openflash Tablet v1.31 beta maps (including Stage 2!) now available for download | Shiv@Openflash | Software Tuning | 354 | 02-08-2015 05:23 PM |
| Is Openflash tablet detectable? | Boofneenee | Software Tuning | 25 | 05-02-2014 10:03 PM |
| OpenFlash Tablet Stage 1 v1.2 maps available for download | Shiv@Openflash | Software Tuning | 31 | 10-31-2013 08:45 PM |
| WTB Openflash Tablet | Vlady | Want-To-Buy Requests | 0 | 10-25-2013 12:10 AM |
