Old 02-26-2014, 12:31 AM   #3655
evan
Drives: fr-s
Originally Posted by NickFRS View Post
My car will be in Tuesday for my tune to be re-done by Erich. Where are you getting the 3bar from? Might order it so I can pop it in then. Looking forwards to you input once your car is done this week.
This one?
http://www.rallysportdirect.com/Omni...Bar-MAP-Sensor
PRE ordered it for me for about $100. Just give Jason or Chris a ring.
..and yes that is it.
evan is offline   Reply With Quote
Old 02-26-2014, 11:32 AM   #3656
xxscaxx
Drives: 2013 SWP BRZ
This one?
I have posted this before but I have an extra 3 bar map sensor if you want. I used it for like 2 weeks, no joke lol.
PM me.
xxscaxx is offline   Reply With Quote
Old 02-26-2014, 12:44 PM   #3657
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by olorin View Post
Is there any trick to removing the pulley?
Edit: Never mind. Red Loctite made it a real bitch to get off.
Applying direct heat to the head of the bolt is the best way to remove red loctited bolts.
olorin (02-26-2014)
Old 02-26-2014, 01:26 PM   #3658
xxscaxx
My bolts weren't that hard to remove. I think you guys need to work out
The Following User Says Thank You to xxscaxx For This Useful Post:
ntaphse (02-26-2014)
Old 02-26-2014, 01:27 PM   #3659
olorin
olorin's Avatar
Drives: GBS Premium
Thanks, I was worried I would rip the heads off the bolts. It ended up just taking a lot of time. Think it would be ok to just use blue loctite?
olorin is offline   Reply With Quote
Old 02-26-2014, 01:28 PM   #3660
xxscaxx
I honestly didn't use any, I just put the bolts back in. Probably should have but I haven't had any issues with those bolts moving.
Old 02-26-2014, 01:28 PM   #3661
olorin
olorin's Avatar
Drives: GBS Premium
so funny
The Following User Says Thank You to olorin For This Useful Post:
xxscaxx (02-26-2014)
Old 02-26-2014, 03:04 PM   #3662
King Tut
NASA SpecE30 Racer
King Tut's Avatar
I think blue would be fine.
Old 02-26-2014, 04:29 PM   #3663
ntaphse
Drives: beater
Hey guys, I'm running a beta of the Delicious 8.4 tune as of last night, and wow is it ever smooth! I was feeling some surging during light throttle, especially while cold, and it is 100% cured and super smooth now.
As I posted before, I'm also running the Airaid cold air box. The tune is for a stock air box but Bill has thoroughly tested both configurations and said they are interchangeable.
Can't wait for all of you to get the new update and post your impressions. I think we're going to have a lot of happy Innovate owners!
ntaphse is offline   Reply With Quote
The Following User Says Thank You to ntaphse For This Useful Post:
evan (02-26-2014)
Old 02-26-2014, 05:47 PM   #3664
Calum
That Guy
Drives: 2013 asphalt FRS MT
Originally Posted by xjohnx View Post
False alarm, still looking. Definitely not the PVC after removing and zip tiring that into place.
damn.
Old 02-26-2014, 08:51 PM   #3665
xjohnx
Grip>Slip
xjohnx's Avatar
Ready to test for leaks.
The Following 4 Users Say Thank You to xjohnx For This Useful Post:
Calum (02-26-2014), mikalem (02-26-2014), OrbitalEllipses (02-27-2014), Xero-Limit (02-26-2014)
Old 02-26-2014, 09:50 PM   #3666
CK_Bladesmith
CK_Bladesmith's Avatar
Drives: Raven FR-S
Innovate (Sprintex) Supercharger Owners Topic
Are you using the stock snorkel with your airaid intake box? Does it make any difference to use it or not?
Raven FR-S mods: Unichip, Ground Control street coilovers with camber plates and strut tower brace, SPC Lca's, Drag DR-38 wheels with Dunlop Direzza DZ101s, Perrin CAI and silicone inlet tube, Perrin 3" resonated catback, Perrin high flow catted front pipe, Rev Works UEL header.
CK_Bladesmith is offline   Reply With Quote
Old 02-27-2014, 02:08 AM   #3667
ntaphse
Drives: beater
No I removed it. I think it's a 20% increase in flow iirc. You don't have to remove the whole bumper btw. Just the top bolts and have a friend pull back the bumper while you unbolt it and sneak it out.
Old 02-27-2014, 04:58 AM   #3668
NickFRS
Drives: 2013 Asphalt FRS
Eh i'll ask Jason......
2013 Sion FRS
2014 Subaru WRX
2014 Subaru XV
NickFRS is offline   Reply With Quote
The Following User Says Thank You to NickFRS For This Useful Post:
evan (02-27-2014)
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 11:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 07:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 01:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-18-2012 12:38 AM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 06:14 PM
