#505 |
PROUD OF BOXER
Drives: Raven FR-S
also wanted to add
IF YOURE STILL HAVING RATTLING BUZZING ISSUES, CHECK YOUR TRUNK LID The inner structural member touches up against the outside shell. This can cause buzzing with anything other than a stock exhaust. My fix was using thick double sided 3M foam tape pieces every 2-3 inches.
#506 |
Drives: BRZ WR Blue, E85, Fully modified.
This post just save a day of my time.
I almost got myself re-working on the lowered springs that I just put on my BRZ, because when the noise occurs almost at that time when I put the lowered springs on. Really appreciated. |
#507 | |
Drives: JAWS
#508 |
Drives: cop car
#509 |
Drives: 2013 MT FR-S Asphalt
Spent several hours disassembling the car this weekend, put grease all over that back deck, and viola! The problem seems to be fixed! Thank you so much for this write up - my mornings will be much less stressful now.
#510 |
Drives: Scion FR-S
Diassemble? You realize you can do the fix from inside the trunk without removing anything, right? Unless you tried that and it didn't work.
#511 |
I ended up taking out pretty much everything from the front seats back. There are a number of welds that are out of reach if you don't remove the deck itself, and I didn't want to deal with the noise anymore. In the end, it was worth it though.
#512 |
Basically, this: http://www.ft86club.com/forums/showthread.php?t=44636
| The Following User Says Thank You to dawnst3ar For This Useful Post: | Mikepage (03-04-2014) |
#513 |
Drives: Scion FR-S
I know how you feel. Mine stopped from just spraying from the trunk, so I'll consider myself lucky. That being said, I took off the door panel this weekend to silence the vibration from the door switches/subwoofer.
#514 |
Noise gone
So, took FRS in for 15K service... asked them to check out the "rattle" noise from trunk area -- especially bad when rear seat back is down... going over speed bumps or bumpy roads. Thought this was somehow related to all the posts about the rear deck metal.
They found the noise to be in the rear hatch latch. They made some adjustments... and voila... the noise is gone.
2013 Asphalt / MT
Olympia, Washington |
#515 |
Drives: 2013 frs
Thought my frs was making this noise to but it was just my rear seats thay were not properly locked into place lol
Sent from my SM-N900W8 using Tapatalk |
#516 |
Drives: 2013 Subaru BRZ Limited (CBS)
I guess i am not fully understanding how wd-40 or grease can provide cushioning to the panels to keep them from rattling against one another....
#517 | |
Drives: Scion FR-S
Think of it like oiling a squeaky hinge on a door. |
#518 |
Drives: 2014 BRZ Limited
This JUST STARTED in my car yesterday, and I hadn't even thought to look for a thread on it before I just happened to see it here today. I love this board.
| The Following User Says Thank You to extrashaky For This Useful Post: | Mikepage (03-15-2014) |
| Odometer Functions - "S" & "G" What are they? | kablammo | BRZ First-Gen (2012+) — General Topics | 59 | 12-01-2013 01:28 AM |
| NEW Volk Racing TE37SL "Black Edition" Different finish, same low price! | Speed Element | Wheels and Tires | 19 | 07-19-2012 03:27 PM |
| Subaru BRZ Prototype First Drive Review: "Off the Chart" (Motor Trend) | Hachiroku | BRZ First-Gen (2012+) — General Topics | 67 | 11-09-2011 06:58 PM |
| May 2010 Car&Driver issue FT-86 article - "25 Cars Worth Waiting For" | JDMinc | Scion FR-S / Toyota 86 GT86 General Forum | 76 | 04-17-2010 04:58 AM |
