Old 02-17-2014, 12:52 PM   #1
Thekaylakrunkk
XE Autosport
Thekaylakrunkk's Avatar
Drives: 2013 Scion FRS Whiteout
Needing coilover opinions
If you could buy fortune 500 coilovers for just a little more than BC coilovers, which would you buy? I'm faced with this dilemma at the moment. I can get fortunes for not even $200 more than the bcs. I'vE also heard that I need to set back around $150 for a part on the fortunes that doesn't just come with them like they do bcs so I may be paying too much more that way. My needs are to be lowered around 3". It's my daily driver so I want a really smooth ride. There's a slight possibility that I may pick up a cheap daily driver then track the frs so I am just trying to make the smartest decision here. Trying not to go over $1400 for coilovers and control arms. Any advice?
Sent from my SAMSUNG-SGH-I317 using Tapatalk
Thekaylakrunkk is offline   Reply With Quote
Old 02-17-2014, 12:53 PM   #2
Thekaylakrunkk
XE Autosport
And I am aware of dampening, spring rates, and all that stuff. I'm just needing a general opinion of which you find superior
Old 02-17-2014, 12:56 PM   #3
Diode Dynamics
Diode Dynamics's Avatar
If you are daily driving your car, why not put some Tein coilovers on it?
I have Teins on my S14 and Tein's on our FR-S, and the ride / stance etc. is perfect for a daily driven car. I suggest PM'ing @CSGMike or one of the other helpful vendors on this forum for more information about which coilovers fit your needs
Nick C.
John C.
Diode Dynamics
Old 02-17-2014, 12:59 PM   #4
Thekaylakrunkk
XE Autosport
How low is your frs? I'm trying to be around 3". I know that bcs ride good for lowered/ stanced so I'm unsure about the tein. I have tein springs right now that it's lowered on. I live in Alabama and the roads are TERRIBLE so the ride is very important. And also back to the fact that I may change dailys and Track the frs so I would like to have good coilovers and not have to keep changing
Old 02-17-2014, 01:01 PM   #5
Thekaylakrunkk
XE Autosport
I don't think street basics have camber plates either. I need at least 2 degrees of camber front and back so I have to have camber plates
Old 02-17-2014, 01:11 PM   #6
Diode Dynamics
One of my co-workers is lowered on BC coils and the ride is pretty harsh compared to our FR-S. You can always buy different mounts for the camber adjustment IIRC.
I'm not sure how low we have ours set, but I always recommend Tein's for daily driven cars
Nick C.
John C.
Diode Dynamics
Old 02-17-2014, 01:29 PM   #7
Anomie
Anomie's Avatar
Drives: 2014 BRZ Limited
I doubt you're going to get a "really smooth ride" with a 3" drop on coilovers under $1400 minus whatever you spend on LCA's.
That being said, I've heard good things about RSR Black-i coils for extreme lowering + street comfort. Above your price point, but not by much.
Anomie is offline   Reply With Quote
The Following User Says Thank You to Anomie For This Useful Post:
Thekaylakrunkk (02-17-2014)
Old 02-17-2014, 01:41 PM   #8
Thekaylakrunkk
XE Autosport
From what I'm seeing on their website those don't even lower two inches
Old 02-17-2014, 02:23 PM   #9
Anomie
Anomie's Avatar
Not sure where you're reading but they're designed for 55 mm drops and can go up to 80mm (with supporting mods), as discussed here: http://www.ft86club.com/forums/showthread.php?t=49980
Old 02-17-2014, 02:26 PM   #10
Thekaylakrunkk
XE Autosport
This is on their website for these coil overs for frs. Maybe I'm looking at this wrong I have no idea to be honest
Old 02-17-2014, 02:29 PM   #11
Anomie
Anomie's Avatar
Those are for the sports-i, not the black-i.
Black-i is:
  • Monotube & Hand Assembled
  • Made & Designed in Japan
  • Spring Rate (Front) : 7k
  • Spring Rate (Rear) : 7k
  • Height Drop Max (Front) : -80mm (-3")
  • Height Drop Max (Rear) : -105mm (-4")
Old 02-17-2014, 02:52 PM   #12
Thekaylakrunkk
XE Autosport
Oh cool well thank u
Old 02-17-2014, 03:22 PM   #13
damaster32
I'm getting ST's. I was gonna cant Fortune but I just daily drive my car so I don't need it to be real stiff.
damaster32 is offline   Reply With Quote
Old 02-17-2014, 09:37 PM   #14
deliroast
Drives: 2014 SSM BRZ
id go with the fortune autos. they were my first choice but want to see how the sbd coilovers are. set up right they rode damn well on my last car.
M3 > BRZ
deliroast is offline   Reply With Quote
Coilover Review: FEAL SUSPENSION 441 coilover kit mr. slim Suspension | Chassis | Brakes -- Sponsored by 949 Racing 39 11-28-2019 07:30 AM
Need opinions! TakeNoL Electronics | Audio | NAV | Infotainment 13 01-26-2014 02:14 PM
Pro opinions before coilover install Thongpocket Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 01-07-2014 01:35 PM
Need Some Opinions Before I Buy Mr Kirmudget Cosmetic Modification (Interior/Exterior/Lighting) 0 09-27-2013 12:21 AM
So what horsepower level are people needing to upgrade the injectors/pump? seven Forced Induction 24 01-02-2013 12:28 AM
