Old 02-10-2014, 01:24 PM   #1
Basket Case
Drives: 2013 Raven fr-s
question about gauges
So I have seen in some youtube videos, people starting their car and the tachometer moving all the way to the right, and then falling back to where it should be at idle. my car doesn't do that then I start it. I don't really care if it does or does not do this, I'm just curious why mine is different.
Basket Case is offline   Reply With Quote
Old 02-10-2014, 01:27 PM   #2
z3ro
BRZ does it, FRS only sweeps to your set RPM.
For FRS put it in the ON position, not start. Toggle through display until you get to a bunch of zeros. Hold down to set the first number (1000's), then hit once to go to hundreds and set that. Then hit one more time to confirm, leave the buzzer off (its effin annoying). Turn car all the way off, then back to "ON" and it should sweep
z3ro is offline   Reply With Quote
Old 02-10-2014, 01:48 PM   #3
Basket Case
is that set rpm the same as the shift light? It just seems like a silly thing to go out of the way to do, but I am curious if there are things the dash can do that I don't know about.
Old 02-10-2014, 02:39 PM   #4
z3ro
If i understand your question right, the answer's yes. If you have the FRS it will only sweep the RPM's you have set for your shift light. Example; i set my shift light to 7200, it only sweeps to 7200.
The Following User Says Thank You to z3ro For This Useful Post:
humfrz (02-10-2014)
Old 02-10-2014, 03:30 PM   #5
Basket Case
Cool, that makes sense.
Old 02-12-2014, 10:53 PM   #6
soundman98
ProCrastinationConsultant
soundman98's Avatar
i kinda like the tach beep.. it means i don't need to look at the gauge cluster to know when i've hit my shift point.. but currently my shift point is set at 3700. once i move it up to 6000, i should have less of that issue..
Old 02-13-2014, 08:01 AM   #7
z3ro
Why so low, fuel savings?
Old 02-13-2014, 02:22 PM   #8
Vmax911
Drives: WRB BRZ
I'm guessing break-in?
Vmax911 is offline   Reply With Quote
Old 02-13-2014, 09:41 PM   #9
soundman98
soundman98's Avatar
yep 500 miles on the car now.. i was told it is recommended to keep it below 3700 for break-in until 1,000 miles.. i figure it's mostly a lawyer/cya thing on part of toyabaru, but i figure it can't hurt to at least try to comply with it-- nothing bad can happen by following their rules, except for a lack of fun.
Cyberstork gauges ANREX Cosmetic Modification (Interior/Exterior/Lighting) 53 08-11-2016 07:07 PM
Gauges Positioning BadLuckZN6 Cosmetic Modification (Interior/Exterior/Lighting) 12 12-10-2013 08:24 PM
WTB: Gauges AtlasMick Engine, Exhaust, Bolt-Ons 2 03-29-2013 01:04 AM
gauges where the radio is? J-Money Cosmetic Modification (Interior/Exterior/Lighting) 7 02-05-2013 11:11 PM
Gauges CyberFormula Scion FR-S / Toyota 86 GT86 General Forum 45 07-24-2010 07:26 PM
