Old 02-04-2014, 12:37 PM   #3179
choi0706
Drives: t
anyone log IATs? pulley size?
choi0706 is offline   Reply With Quote
Old 02-04-2014, 12:59 PM   #3180
xxscaxx
Drives: 2013 SWP BRZ
Originally Posted by CK_Bladesmith View Post
My tune is through delicious as well
Edit: I also found that I've got a minor leak where the lines are crimped going into the coolant bottle.
I mentioned this earlier. Contact Innovate - they will send you replacement clamps. I cut the old ones off (slide the new ones on first so you can tighten it fast and not lose a lot of coolant).
Anyone else see this on Innovate/Abby Motorsports FB page? Haven't heard much about IAT readings in a while, just figured i'd share it.
Abbey IAT(air intake temperature)upgrade on the Abbey Motorsport Sprintex Supercharger kit for the GT86/BRZ.
we move the stock air intake temperature sensor from the Mass air flow sensor on a stock car to after the Sprintex Supercharger to read charged air temperature for better calibration with the EcuTek International Ltd software.
xxscaxx is offline   Reply With Quote
Old 02-04-2014, 01:04 PM   #3181
xjohnx
Grip>Slip
xjohnx's Avatar
Originally Posted by DeliciousTuning View Post
Make sure you have no vacuum leaks after the MAF sensor. If you do this can cause the lean condition you are seeing. Otherwise send me some logs and I will review them.
Cheers,
William Knose
Thought I had this sorted out but it doesn't appear so. AFR's still getting leaner towards the top of the rev range. It seems to be worse in higher gears.
I tried locating any vacuum leaks by spraying starter fluid everywhere I could think of on the intake pipes/couplings/throttle body/elbow fittings. Where do you guys most commonly see these leaks? Could it possibly be anything else?
Old 02-04-2014, 01:06 PM   #3182
choi0706
Drives: t
you should probably look at the port injectors.. seen those leak if you weren't careful with the gasket on bottom..
Old 02-04-2014, 01:19 PM   #3183
xxscaxx
or it could just be the tune...send him some data logs.
The Following User Says Thank You to xxscaxx For This Useful Post:
Ryan86 (02-04-2014)
Old 02-04-2014, 02:21 PM   #3184
calispec
calispec's Avatar
Drives: Subaru BRZ with Delicious Innovate
I am pretty sure IAT's in the manifold do not read correctly. The sensor doesn't stick far enough down into the air flow. The manifold gets heat soaked and the IAT reads some of that heat.. Long story short we need a better solution. I saw a log somewhere of a WOT run with a post charger IAT.. I think the temps continued to decrease for the first 5 seconds into the run... then kept increasing after the run was over.. temps should fluctuate with boost.. not lag behind it.. reason to believe it was reading the temp of the manifold more than the air..
2013 BR-Zed, Innovate Powered, Delicious Tuned, Zeltus Cooled. Build Thread
www.GT86Mounts.com
calispec is offline   Reply With Quote
The Following User Says Thank You to calispec For This Useful Post:
xxscaxx (02-04-2014)
Old 02-04-2014, 02:27 PM   #3185
xxscaxx
I thought I read something like this, but couldn't recall. Good post.
Old 02-04-2014, 02:44 PM   #3186
swift996
swift996's Avatar
My scientific solution was touching the lines after 6 WOT pulls to gather data logs. The line going to the front mount felt about 150 degrees (water temp) and the return line going into the supercharger felt a few degrees over ambient of 60 degrees. It's enough for me to know it's doing it's job, just wondering how effective it cools the charge.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 02-04-2014, 02:52 PM   #3187
xxscaxx
you should have touched the top of the supercharger instead
no joke. non-ic, it would stay hot for like an hour or more after the car was off, and be SCORCHING hot when I touched it. Now I can throw my hand on it. When its real cold out (like today), it feels like a hand warmer, lol.
Old 02-04-2014, 02:55 PM   #3188
stockysnail
Just the tip
stockysnail's Avatar
Here a question/thoughts for those of you that jumped from the 75mm pulley to the 70mm pulley.
If I make the jump to the 70mm, sounds like I will need:
-Stronger clutch installed (like act streetlight flywheel and street clutch)
-Intercooler
-70mm pully
-I may also do a meth injection
-I don't want to bother with e85 yet
This means I'll be spending around $2.5k without meth (parts and labor [intercooler 1200, clutch/flywheel $566, clutch install $600, retune $200]) and over $3.5k with meth.
With all that, is the supercharger or engine expected to have a shorter lifespan? I don't want to have the car fail on me in a few years because I overstressed the charger or engine. I want this car to last. I do a few track days a year. I have most all of the less expensive supporting mods like oil cooler as you'll see in my build thread.
Would I need to change the supercharger oil more frequently that recommended by innovate?
Depending on my tax return I may get some or all of this stuff. My guess without looking at taxes is probably I'll only be able to get the intercooler.
Old 02-04-2014, 03:01 PM   #3189
xxscaxx
-Intercooler
-70mm pully
Not necessarily. I went to the 70mm pulley and didn't change anything. It depends on the gas you can run. Do you have 93 or 91? I have 93 so it may be different, i've heard 91 with the smaller pulley and no intercooler isn't the way to go (can't remember who said it).
I don't have a clutch either. I plan on going to get tuned on e85/flex fuel with the stock clutch, hopefully it holds. I DO plan on upgrading however. But if I was to stay on 93, I wouldn't be touching the clutch. It holds just fine.
As far as frequency of changing the oil, I don't see why that would effect anything. I mean the service is suppose to be every 30k, and I checked mine with like 10k on it and it was so low it didn't even hit the dipstick. So that should be something checked frequently anyways, regardless of the setup.
I do recommend the intercooler though, either way and no matter what gas you are going to run. Just makes for a way more efficient setup. Consistent power as well.
Can't comment on meth injection, no plans to be running that.
Old 02-04-2014, 03:12 PM   #3190
stockysnail
Just the tip
I buy Costco 92 octane gas as it's next door to my house and cheap, yet good gas. Someone told me at the mechanic shop that running a 70mm pulley without any of the other stuff like intercooler wouldn't work very well. I can't remember exactly what he said as to why.
I need to remind myself to check the charger's oil level since I haven't done that yet.
Old 02-04-2014, 03:14 PM   #3191
xxscaxx
man, 92...now your throwing me for a loop
maybe bill @DeliciousTuning could come answer this, since he has experience with 91 gas and a lot of different setups.
Don't want to throw guesses out there on ya.
Old 02-04-2014, 03:15 PM   #3192
swift996
swift996's Avatar
What's the process for changing the oil on the charger? I know where the fill plug is, where's the drain?
The Following User Says Thank You to swift996 For This Useful Post:
stockysnail (02-04-2014)
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 11:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 07:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 01:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-18-2012 12:38 AM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 06:14 PM
