#43 | |
How ya gonna keep 'em down on the farm once they've seen Karl Hungus? |
#44 | |
Drives: FRS
![]() ![]() CERBERUS |
| The Following User Says Thank You to RFB For This Useful Post: | Blackrsx (04-08-2014) |
#45 | |
Drives: frs
http://www.ft86club.com/forums/showthread.php?t=41027 this guy has his led marker and switch back turn signal but he had to make a new circuit for the side marker. |
| The Following User Says Thank You to vincent201089 For This Useful Post: | Papi (09-15-2015) |
#46 |
i dont use LED bulbs or switchbacks for my blinkers, so i cannot say.
#47 | |
Drives: 2013 WR Blue Limited Manual BRZ
This is for the Limited BRZ mind you and while I don't really care about the side markers being on (I much prefer them as blinkers), I wonder why it turned out this way. Would keeping the original black wire to side markers connected allow them to stay on? I'm guessing it has to be something to do with a broken circuit and the fact that the BRZ front blinkers only blink and are not on with parking lights? |
#48 |
Drives: 2013 Limited BRZ
Sounds like I'll encounter the same issue with my limited. Too many drinks into the evening to figure it out at the moment but perhaps we need a setup with some diodes for BRZs.
Sent from my HTCONE using Tapatalk |
#49 | |
The BRZ limited version of this mod would be similar to the OP's guide. Basically Identify your parking light constant power wire & your blinker "blink" power wire, and connect them to your 2 wires coming from the sidemarkers. I'd recommend using a multimeter or a test light, to verify the wires if you have a BRZ or BRZ Limited. The same would hold true if you have a 10 or monogram, the standard FR-S wiring is what the OP's Guide and my revision are based on. Also i should note -and will amend my original post - I haven't tested this with LED bulbs, only incandescent.
How ya gonna keep 'em down on the farm once they've seen Karl Hungus? Last edited by Danklvr; 01-27-2014 at 10:54 PM. |
#50 | |
#51 | |
#52 | |
#53 |
Ok, so I made the modification. I cut the other wire on the side markers (red on drivers white on the other) and ran a wire from there to the green wire going my Boomerang LED lights (which on the BRZ, act as the front parking lights). I also have the Boomerangs setup as Daytime Running Lights, so I have a wire running from the lower LEDs and a Diode hooked into the green wire. All I had to do was make the connection to the side markers BEFORE the diode, on the harness side, not the headlight side. At first, it didn't work and I was puzzled, but then I flipped my LEDs in the side markers around and the markers came on with the headlights and alternated, BUT there was still a problem, the blinkers wouldn't come on at all when the parking lights were off, meaning they wouldn't come on with the stock set to 'off' or 'auto' during daylight. So, I tried putting the regular bulbs back in and, sure enough, everything worked properly. So, it seems the amber LEDs I have an issue, I'm guessing it's some sort of polarity issue, can someone shed some light on this and are there any LEDs that may work like the standard bulbs, I'm sure LEDs that work flipped in either way will do nicely, does anyone know of any that will fit in our 168 socket?
Just for reference for any other BRZ owners: You need a wire going from the red blinker wire to the black wire on your markers, and a wire going from the green wire hooked to your headlights (powering the boomerang) to the white/red power wire on your side markers. If you do or have done the DRL mod for your boomerangs make sure the diode is in between the splice to the marker and your headlight. |
| The Following User Says Thank You to Deathalo For This Useful Post: | codesplice (01-18-2015) |
#54 |
Did you try flipping the LEDs?
#55 |
Disregard last comment.
#56 |
Lol, I did find these: http://www.superbrightleds.com/morei...edge-base/199/
It says they are not polarity sensitive, so I suppose they would work like incandescents, but I'm just worried that they aren't bright enough, they say they only output 30 lumens, which seems fairly lower than your typical 5 LED marker, thoughts? |
| clear side marker part number | NOBROWS | Cosmetic Modification (Interior/Exterior/Lighting) | 34 | 09-11-2017 10:12 PM |
| **Toyota 86 Fog Light Bezels $34.9, 86 Arm Rest, GT86 Badge, Fog Light Set for $112.9 | nigel-jdmparts | Exterior Parts - The Rest | 524 | 02-28-2016 11:24 AM |
| Converting side marker to turn signals | ayau | Cosmetic Modification (Interior/Exterior/Lighting) | 30 | 12-13-2015 04:41 PM |
| does your car come with side door marker light? | excited86 | CANADA | 12 | 08-02-2012 07:07 PM |
| Raven blacked out side marker before and after | Roadstercycle | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 17 | 06-24-2012 11:52 PM |
