Old 11-14-2013, 02:22 PM   #57
Mikem53
Drives: FR-S 6MT
Originally Posted by husker741 View Post
If I could dislike or thumb down this post I would. Do you see how they market this car? Plus, I haven't tracked or raced my car once and I have these issues. For a car with this little power, I can't believe the axles are an issue.
When you alter it from its original design by lowering it, putting added stress on the axles, adding power, etc.. Something's going to give..
All the ones with issues seems to be the ones that have lowered theirs. I don't see that as an OEM issue.. Except that the stock axles aren't designed for more than stock loads, apparently.
Mikem53 is offline   Reply With Quote
Old 11-19-2013, 01:47 AM   #58
wrxgoose
WUB WUB
Drives: 2013 Firestorm
Originally Posted by kurbkilla View Post
I'm I correct in assuming the problem with the axles is because of lowering the car and not adding sticky tires or about 100hp?
i'm up 115 whp over stock, and while i haven't broken an axle yet, once i've got the clutch in, axles are going to be my next big purchase. want to prevent anything going boom
wrxgoose is offline   Reply With Quote
Old 01-28-2014, 06:34 PM   #59
markmatley
Shipping to Hawaii?...
markmatley's Avatar
Drives: '13 Asphalt FR-S
Originally Posted by trueno86power View Post
If someone could take a picture under the car to check the angle of axle when at stock height would be great.
Envoyι de mon ST18a en utilisant Tapatalk
Not to dredge up an old topic, but my drivers side axle just broke at the collar in the diff. Dealer has not explained fully but they are blaming it on my coilovers set at stock height.
The angle at which the axle should be at from horizontal should be near horizontal. Also, they measured the height change from the wheel hub to diff and it should be no more than 1-2" (25.4 mm to 50.8 mm). These two lines are from the dealer over the phone.
Gotto pay to play I guess. Diff risers and subframe risers along with new axles will just have to do for me.
~Matt
Efimia (asphalt FRS)
markmatley is offline   Reply With Quote
Old 01-28-2014, 06:57 PM   #60
nelsmar
I don't think anyone has broken a passenger side one yet either.
My flickr - Canibeat
Local magazine scout
Old 01-28-2014, 07:45 PM   #61
CSG Mike
CSG Mike's Avatar
I've only seen the Driver's side break, unless in extreme use (e.g. drag racing with DR's, boost, etc)
Old 01-30-2014, 11:14 AM   #62
IronSean
Drives: 2006 Toyota Camry
@sierra In your opinion could this also cause issues on stock suspension at stock height over time that is just sped up by the additional stresses of lowering keeping the axles pulled to their limit? Or should stock have enough length to stay safe even over bumps/etc?
IronSean is offline   Reply With Quote
Old 01-30-2014, 04:17 PM   #63
PoWn3d_0704
PoWn3d_0704's Avatar
Drives: 1990 BNR32 GTR
Totally stock setup? What were you doing when it broke?
Picked up my BRZ on 6/11/13.
Build Album:
PoWn3d's BRZ Pictures
Build Thread: PoWn3d's BRZ
PoWn3d_0704 is offline   Reply With Quote
Old 01-30-2014, 06:17 PM   #64
markmatley
markmatley's Avatar
Had Fortune Auto coilovers on at slightly higher than stock rear height levels. Camber was corrected to stock camber by PSM LCA's. Matched the bolt holes of the PSM LCA to the bolt holes of the stock LCA. Same length for no fuss install.
Essentially I took a very nice right hander off the freeway at about 40 mph, as soon as I straightened out and let off the throttle, I heard a snapping sound and immediately fast clunking noises. Pulled off the road, checked engine sound and it was fine. Shifted through all my gears fine. But when I tried to take off again, the clunking continued. Jacked my car up and found the drivers side axle at the diff was sagging and easily moveable. Knew it from there that my axle popped out and/or broke at the diff. Turns out it broke because I couldn't pop it back in.
Basically ordered a new axle and diff risers to help. Hopefully...
~Matt
Old 01-31-2014, 07:35 AM   #65
trueno86power
[||•]=(86)=[•||]
trueno86power's Avatar
Drives: 2017 Toyota 86
Ive broke my left and right ride axle. Check the first post...
trueno86power
GR | TOM'S | TRD
2017 Toyota 86
trueno86power is offline   Reply With Quote
Old 01-31-2014, 11:20 AM   #66
CSG Mike
CSG Mike's Avatar
Did you have wheel hop when you were launching?
Old 01-31-2014, 10:57 PM   #67
trueno86power
[||•]=(86)=[•||]
Nop... Ive dropped the clutch too hard at 4500 rpm with glue on the track. Ive feel the high grip feeling and right after the axle was gone.
trueno86power
GR | TOM'S | TRD
2017 Toyota 86
Old 02-02-2014, 09:35 PM   #68
chris x sway
chris x sway's Avatar
Drives: 2014 FR-S in Mayonnaise
So has anybody found a solution for this? I'm looking at getting some BC Racing coils and slamming the whip soon. TIA.
chris x sway is offline   Reply With Quote
Old 02-03-2014, 12:05 AM   #69
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
Powered by Max differ and subframe risers. Welding requires.
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline   Reply With Quote
Old 02-03-2014, 04:33 PM   #70
markmatley
markmatley's Avatar
Dammit. I wish I didn't have to weld anything. Too bad there are no solid metal inserts for the mounts parallel to the driveshaft that pops into the rear subframe. Could I use a subframe bracing bar in conjunction to the risers?
~Matt
more money than brains, stance bro
"My Dealer told me {insert dumb idea}" (was "Toyota/Subary Partnership Cancelled?") levifig BRZ First-Gen (2012+) — General Topics 48 08-09-2013 06:34 PM
WORK KIWAMI 18" x 9.5" + 18" x 8.5" +38 Offset GC GTS Aero Kit Australia Classifieds 16 03-22-2013 05:49 AM
Which Markets have "GT86" and "Toyota" badges on trunk? Tanuki Scion FR-S / Toyota 86 GT86 General Forum 20 02-10-2013 05:23 PM
Anyone else try running "square" tires on "staggered" wheels? hamlet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 12-19-2012 12:59 PM
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
