#15 |
Drives: 2013 AT Firestorm FRS
I do agree with that. But we aren't out of our minds, not all of us are car gods like you. But if OP can get that package for 5k shipped then that's a deal!
| The Following User Says Thank You to chiefshayan For This Useful Post: | Nasty Sausage (01-26-2014) |
#16 | |
Drives: 4-Runner Sport - 13' BRZ SportTech
http://www.ft86club.com/forums/showthread.php?t=55705 and here's a question/answer thread started by Vortech http://www.ft86club.com/forums/showthread.php?t=27374 Hope that helps! |
| The Following User Says Thank You to protpibe For This Useful Post: | Brian@Vortech (01-27-2014) |
#17 |
blowhard
Drives: frs, project forester
#18 |
Regional Moderator
Drives: 00-AP1 20-A90 06-Z33 07-FA5 93-NA1
I may have to ask you for that coupon code if I ever decide to pull the trigger on this kit? You know it requires any cutting or anything to install this kit?
#19 | |
And to OP, I made 360WHP with a bad tune on E85. 300WHP is no problem on a vortech. I did this with a stock exhaust & header.
When I grow up, I wanna be God. My flickr - Canibeat Local magazine scout Old Setup: Vortech Supercharged 360WHP/262WTQ @ 11.5psi My build thread - WTF happened to nelsmar's car thread |
| The Following 2 Users Say Thank You to nelsmar For This Useful Post: | Brian@Vortech (01-27-2014), OmarGC (01-26-2014) |
#21 |
Regional Moderator
#22 | |
blowhard
But it's incredibly easy to create an account on and is worth making one just to follow businesses for coupons, discounts etc, even my Amex provides cash back for a few keystrokes. No harder than signing up for a forum account. If you can't be bothered to spend 2 minutes to help yourself then why should I? Everyone is looking for a deal but nobody is actually willing to do the legwork to find one. |
#23 | |
Regional Moderator
#24 |
Back on topic... the Vortech kit does not require you to decimate your front crash beam, no. It does require you to grind down an aluminum nub on the stock alternator bracket.
It also requires you to remove your OEM washer fluid reservoir and piece together a replacement. A number of people have struggled during installation to keep the replacement from leaking. If a simple installation is a top priority for you, check out Jackson. Their kit is ugly as sin, but that's because they require zero drilling, tapping, grinding, or replacing of OEM parts. |
| The Following User Says Thank You to tendogy For This Useful Post: | Brian@Vortech (01-27-2014) |
#25 |
Drives: Vortech Supercharged M6 FR-S UM
Most people will tell you the most difficult part of the install is drilling the bumper beam for the intercooler mounting. It does require a decently high powered drill and good drill bits, as the bumper beam is strong, solid steel. Other than that, it should be as easy or easier than every other system out there. We list 6 hours on the install. Some people have done it in less, some people have taken longer. If you would like, you can preview the entire installation manual HERE.
If you have any other questions, I would be happy to answer them. In addition, many of the enthusiasts on here running Vortech systems are extremely knowledgeable as well, and quick to help out when needed. (Thanks guys!) |
#26 | |
Drives: GMC
At times I wish I went with the Innovate kit which looks like a painless afternoon install with no . But I think the performance and proper intercooled setup you get with the Vortech is worth the difference in price and time required to install. I have been doing the install 100% by myself and taking my time to make sure it is all perfect, as a result I probably have about 8-10 hrs invested with about 2-4 hrs left to put the whole thing back together (doesnt help that the garage I'm working in is freezing!). An extra hand will go a long way with this install. |
#27 |
Drives: 2014 Subaru BRZ WRB
After swapping to the 3.12 pulley, I got 346 whp and 246trq on the Phastek dyno. Still on the stock clutch, the supercharger is more forgiving on the drivetrain than the turbo!
| The Following 2 Users Say Thank You to WKM Houston For This Useful Post: | Brian@Vortech (01-27-2014), nelsmar (01-27-2014) |
#28 |
Thupercharged
Got any numbers on 91/93 octane? I'm curious to see what I may be pushing (3.125" pulley)
2013 FRS
Vortech V3 11psi Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300 2019 Series.Grey STI - Stage1+ SF |
| That NEW guy. Vortech Supercharger | Baddon86 | Forced Induction | 14 | 12-16-2013 06:14 PM |
| Vortech Supercharger | denverizzles | Forced Induction | 176 | 10-19-2013 06:48 PM |
| FS: Vortech supercharger kit BRZ | Sniper2606 | Engine, Exhaust, Bolt-Ons | 11 | 06-23-2013 05:20 PM |
| Vortech supercharger | skatery1989 | Forced Induction | 293 | 04-19-2013 04:58 PM |
| Vortech Supercharger FRS/BRZ | vividracing | Forced Induction | 5 | 01-29-2013 07:03 PM |
