#99 | |
I added some enrichment to 5.0v as it didn't seem to differ much from 4.727 but the 5.0v landed at 279.47 vs 279.227(stock ROM OEM MAF calibration). Though I tried to keep pulls under 4.9v when possible. I actually setup a custom rom that I continually adjusted to whatever 4.8-4.9v g/s was and flickered the CEL to warn me that I was nearing maf capacity during tuning. I wanted to see how far the MAF was actually going to be usable. And the owner needed a short notice, short time frame tune so I didn't have time to setup a clean SD map. Although I am happy it happened that way because I was really quite curious how much that MAF could support.
When I grow up, I wanna be God. My flickr - Canibeat Local magazine scout Old Setup: Vortech Supercharged 360WHP/262WTQ @ 11.5psi My build thread - WTF happened to nelsmar's car thread |
| The Following User Says Thank You to nelsmar For This Useful Post: | jamesm (01-27-2014) |
#100 |
The scaling doesn't matter in terms of when it's maxed. 5v is 5v regardless of how much air the ecu thinks that correlates to. If you were hitting 4.8v at those boost/power levels, it has to be stock or smaller or maybe that particular car's sensor was an oddball. I ran 14psi and moved a lot more air before I saw that voltage.
The fact that targets were hit with the scaling near stock would suggest its around the same size as stock, but that's assuming the other fueling related calibrations are dead on true. |
#101 | |
| The Following User Says Thank You to nelsmar For This Useful Post: | jamesm (01-26-2014) |
#102 | |
| The Following User Says Thank You to jamesm For This Useful Post: | Sportsguy83 (01-26-2014) |
#103 |
LOL
#104 | |
PhoneFlash by EcuTeK
Speed Density works very well once tuned in, but yes it needs to be tuned in and that does take time. Once you have nailed it, there is never a need to rescale the MAF sensor for different size pipes, just drop in the tune and and go. Makes tuning a little easier at the end of the day if you put the leg work in up front. So on systems that come with blow-through MAF systems, I prefer to run a 100% Speed Density setup, as it will make for a much more consistent tune versus running a blow-through MAF. The idle will be rock steady, open/closed loop conditions will be consistent and cruising can be dialed in nearly perfect and then reused on many applications. At the end of the day us tuners all have our own opinion, so choose your tuner and go with what they recommend to make sure you get the type of tune you are looking for. Personally I would only recommend Speed Density on vehicles running forced induction setups that do not offer a draw-through MAF system. In these applications Speed Density will be ideal for a much smoother and more desirable tune in my opinion. Cheers, William Knose |
#105 | |
Drives: 2013 FRS
#106 | |
#107 | |
Drives: 2013 FRS
#108 | |
#109 | |
Fanboy
Drives: 2013 ultramarine frs
![]() Sorry, back on topic. The debate will never die because some tuners think it is mandatory and some don't. Preference is what it comes down to. I've yet to hear someone say "I hate SD but I have to do it because of x, y, or z". The ones that use it are comfortable with it or prefer it for whatever reasons.
I'm done helping those who won't help themselves.
TL;DR: ![]() -Duke |
#111 | |
And thanks bringing up another valid point about closed/open loop tuning. Why could you not run closed loop fuel control 100% of the time with Speed Density. I am sure with EcuTeK RaceROM you could. With EcuTeK RaceROM a tuner can even use stock injectors to horsepower levels I am sure other systems will not be able to obtain due to fact they do not have EcuTeK RaceROM. So now one can save a little money for other performance minded parts. On top of that a lot of EcuTeK tuners use the RaceROM custom mapping features heavily especially on forced induction vehicles. Most of our customers (75%) running FI usually request at least one of the features: FlexFuel, Traction Control, Boost Control, Switchable Maps... Of course there are naturally aspirated vehicles which can run with other tuning systems, but I believe EcuTeK is making more on a naturally aspirated vehicle than anything else out there. And they have the option of switching between maps on the fly if they like. There is just more cool features and abilities to come with EcuTeK. Where other systems just imitate, EcuTeK innovates. Cheers, William Knose |
#112 |
Drives: 2013 FRS
This debate condensed into an analogy:
Statement 1: it's ok to drive with no air pressure in your tire. BMWs and Mercedes can do it. Counterpoint: that's not a valid comparison because those cars have run-flat tires. The FRS/BRZ does not. So attempting to do so is not ideal. Statement 2: it seems that you are saying anything that you don't recommend isn't ideal. The point that luxurious cars can drive around with no air pressure still stands. Counterpoint 2: [speechless] Last edited by Shiv@Openflash; 01-26-2014 at 10:47 PM. |
| Tags |
| #fanboysthread, oftsupportgroup, unichip ftw |
| ECUTek question | ATSAaron | Engine, Exhaust, Transmission | 12 | 04-03-2014 07:37 PM |
| Ecutek's 86 | jpit | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 10 | 07-12-2013 01:35 PM |
| I need help on which ecutek I should get, stg 1 or 2 | Frsexxxy | Engine, Exhaust, Transmission | 22 | 03-29-2013 11:45 PM |
| Which should I get ecutek stg 1 or stg 2? | Frsexxxy | Engine, Exhaust, Transmission | 5 | 03-21-2013 02:10 PM |
| ECUTEK????? | 20valvewynn83 | Engine, Exhaust, Transmission | 4 | 10-03-2012 10:34 PM |
