Old 01-18-2014, 08:01 PM   #939
cjsporl1996
Drives: WRB BRZ, Monte Carlo SS
When should I expect the new 1.50 maps? I know you said you weren't finished yet I was just wondering.
cjsporl1996 is offline   Reply With Quote
Old 01-18-2014, 08:16 PM   #940
Sargy
Long Distance Driver
Sargy's Avatar
I noticed that as well but to be honest I have personally not seen anyone with all bolt ons and E85 via OFT post a dyno plot.
I would like too see that.
I was sad when I refreshed the DL page just now and no 1.5. Darn I wanted to play with it this weekend. Lol
Sent from Spaceball 1
I actually have one with a video not posted yet. I will get to it sooner or later
Sargy is offline   Reply With Quote
Old 01-20-2014, 02:15 AM   #941
2point0
2point0's Avatar
Drives: '13 BRZ Ltd WRB
@shiv@vishnu, are you able to comment on this question or is there someone else I should check with? I just don't want to go to buy the header later on only to find out that my OFT dollars have expired.
Originally Posted by 2point0 View Post
@Rombinhood@OpenFlash or @shiv@vishnu: Is there any expiration on OFT Dollars? I would like to buy the tablet soon and use the OFT Dollars towards a header at some point, just not sure how long it'll be.
2013 BRZ Limited - SOLD
2008 Forester XT Sports
1967 Mustang Coupe - 289 V8
2point0 is offline   Reply With Quote
Old 01-20-2014, 02:33 AM   #942
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Unless otherwise stated, there is no expiration on when you can cash in on your earned OFT dollars. But if you have any questions, please email the sales dept at sales@vishnutuning.com
Shiv@Openflash is offline   Reply With Quote
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
2point0 (01-20-2014)
Old 01-20-2014, 08:52 AM   #943
Yobiwan
Yobiwan's Avatar
Drives: Toyota 86 Turbo, Lexus NX300H
Originally Posted by solidONE View Post
Need logging capability for other parameters like IAT, fine knock, etc.
Here's mine on a post 1.42b stg 1 test rom. Computer is dialing back IAM at low load low RPM conditions.
http://www.datazap.me/u/solidone/1-1...2&zoom=318-634
http://www.datazap.me/u/solidone/1-1...2&zoom=292-739
IAM 0.46?
I think that situation is not normal.
bad fuel or something ? . OFT stage 1 map is for 91 (AKI) fuel.
Yobiwan is online now   Reply With Quote
Old 01-21-2014, 03:03 AM   #944
86-tundra
Troll Hunter
86-tundra's Avatar
Drives: fr-s, tundra
hi all
Did my first data log with the 1.42 OTS stage 1 tune
http://datazap.me/u/trevorovert/93-r...42-ots-stage-1
AFR looks to be running a little rich. I'm getting low 11.25 under WOT. Is this something I should be concerned about? Still new to tuning,
86-tundra is offline   Reply With Quote
Old 01-21-2014, 11:55 AM   #945
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
Originally Posted by trevorovert View Post
hi all
That is normal under WOT conditions.
Luckrider is offline   Reply With Quote
The Following User Says Thank You to Luckrider For This Useful Post:
86-tundra (01-21-2014)
Old 01-21-2014, 12:26 PM   #946
AdrianG
Generally Well Liked
Drives: '08 STi Hatch, '11 Outback 3.6R
hi all
@Luckrider is right, this is normal. It's nothing to be concerned with, if anything the tune is too safe, you can make more power by pulling back a bit of that fuel and raising the AFR a bit, but running rich like that just means the cylinder will stay cooler and you'll be less likely to get detonation.
AdrianG is offline   Reply With Quote
The Following User Says Thank You to AdrianG For This Useful Post:
Old 01-21-2014, 01:10 PM   #947
86-tundra
Troll Hunter
86-tundra's Avatar
You guys are the best, thanks for the insight!
Old 01-21-2014, 11:44 PM   #948
Yobiwan
Yobiwan's Avatar
hi all
your LTFR under WOT is too high
I think it's not healthy condition.
when everything is ok, LTFT under WOT should be closed to 0 .
The Following User Says Thank You to Yobiwan For This Useful Post:
86-tundra (01-22-2014)
Old 01-22-2014, 02:11 AM   #949
86-tundra
Troll Hunter
86-tundra's Avatar
Yes, you're right.. hm.. That is concerning
Just read a quote from shiv
At full throttle, long-term fuel trims should be well within +/- 4%. Immediately after the flash, it will be 0%. But then it will slowly adapt over time. As long as you are running the stock airbox, it shouldn't move around much. If you are an aftermarket intake and see big fuel trims, this map may not be suitable for you
Good thing I kept my OEM stock airbox
Old 01-22-2014, 02:23 AM   #950
Shiv@Openflash
Drives: 2013 FRS
Definitely run the stock airbox if you have it. Also, any reason you aren't running the new v1.5 maps? Is your ROM type not supported yet?
Old 01-22-2014, 02:32 AM   #951
FRS_Jack
Duel Canister 2X the Fun
FRS_Jack's Avatar
Drives: 2013 scion frs
When is Stage 2 1.5 gunna drop for automatic FR-S?
Performance: Vishnu Tune, HKS Catback Exhaust, Revworks UEL Header, Perrin CAI/Inlet Hose, Cusco Front Strut Bar + MCB, Cusco Catch Can
Interior: Blox Titanium Shift Knob, Customer Name Badge
Exterior: Black-out Headlights, Redout Tail-light, 8K DDM HIDs, BlueBatMobile Foglight Overlays, Toyota Badged, 5 Axis Spoiler, 30%/70% tint
FRS_Jack is offline   Reply With Quote
Old 01-22-2014, 02:40 AM   #952
86-tundra
Troll Hunter
86-tundra's Avatar
Nope, just haven't gotten to it yet will look into it tomorrow when I install the stock airbox. Gonna fab up the modified snorkel as well..
Quick question for ya tho shiv -
I broke this rivet on my stock airbox. The high lighted box is basically destroyed
I'm planning to just cover it up, but should I have any reason to believe the lack of that extra box there would drastically change readings?
cat overtemp
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 07:35 PM
OpenFlash Tablet Stg 2 Tune (Dyno Progress) Rombinhood@OpenFlash Software Tuning 26 10-24-2013 02:19 PM
FBM Tuning fixed my issue, FA20 and Visconti didn't work as well whitefrs Forced Induction 253 08-19-2013 01:39 PM
