Old 01-13-2014, 03:26 AM   #197
LT
LT's Avatar
Drives: Raven FRS
Originally Posted by GROOV3 View Post
figured I would share mine as these threads are a huge help
18x9.5 +38
235/40/18 all around
just lowered on sportline springs (1.2-4" drop)
about 3-4mm clearance on the inside of the front wheel between spring and wheel but no rubbing front or back at all.
Thanks for sharing! I have the same springs and this fitment is perfect if it doesn't rub like you said.
Looks really good.
LT is offline   Reply With Quote
Old 01-19-2014, 08:50 PM   #198
AVodka14
AVodka14's Avatar
Drives: 2013 Raven FRS MT
Can anyone confirm 265 tires in rear and 255 in front? If so, what suspension set up are you using?
AVodka14 is offline   Reply With Quote
Old 01-19-2014, 10:59 PM   #199
xDanger_208x
xDanger_208x's Avatar
Drives:
Originally Posted by OAKOS Automotive View Post
I must say these look fantastic on the WRB!
Currently the Gunmetal RPF1's come in:
17x9 +35 and +45
Bryce
OAKOS Automotive
I'm leaning towards bronze for my WRB car, but gunmetal is tempting.
xDanger_208x is offline   Reply With Quote
Old 01-20-2014, 02:59 PM   #200
OAKOS Automotive
OAKOS Automotive's Avatar
Drives: '13 Limited BRZ, Satin White Pearl
Send a message via AIM to OAKOS Automotive
We have them in Bronze too
Bryce
OAKOS Automotive is offline   Reply With Quote
Old 01-20-2014, 03:09 PM   #201
xDanger_208x
Drives:
Bryce
Oh I know. We've been exchanging emails about them ;-)
The Following User Says Thank You to xDanger_208x For This Useful Post:
OAKOS Automotive (01-20-2014)
Old 01-20-2014, 04:32 PM   #202
OAKOS Automotive
oh
Bryce
The Following User Says Thank You to OAKOS Automotive For This Useful Post:
xDanger_208x (01-20-2014)
Old 01-21-2014, 05:00 PM   #203
Nightwing
Drives: scion frs
18x9.5 +38
did you do anything to the the front fenders? camber bolts? I plan on getting 245/40/18 18x9.5+45 also on sportlines.
Nightwing is offline   Reply With Quote
Old 01-24-2014, 09:20 PM   #204
JS + BRZ
Drives: 2010 MS3
How's the ride and handling with this set up? Especially with 255/35/18 all around.
Old 02-01-2014, 05:35 PM   #205
jflogerzi
jflogerzi's Avatar
Originally Posted by SliverBrz View Post
I have 255/35/18 all around, same set up except with swifts, no rubbing anywhere.
However i will be getting coilovers soon.
Also have camber bolts and front is about -1.4
I think any bigger and front spring perch will rub tire
Are these black correct?
Old 02-01-2014, 08:36 PM   #206
GROOV3
Drives: GTS
nope,
wheels went on when car wasn't lowered had about 3mm gap to strut and wheels poked out quite a lot
lowered the car with the springs and the wheels have moved in a little and sit much nicer in the guard with about 2mm gap to the strut
havnt bottomed out on anything and guards havnt rubbed at all
only complaint is that the springs are very firm, and shocks aren't matched well and car has a fair bit of rebound which I would like to fix
GROOV3 is offline   Reply With Quote
The Following User Says Thank You to GROOV3 For This Useful Post:
LT (02-06-2014)
Old 02-16-2014, 09:59 AM   #207
yomny
yomny's Avatar
Drives: 2013 FRS Whiteout
Love these wheels but always wondered if they'd perform well in track conditions. Its amazing a 9.5" +38 fits in the front without issues. I'm planning on running coilovers with these. These will fit without rubbing front and rear with tires smaller that 255 squared? Thanks a lot for your confirmations.
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
yomny is offline   Reply With Quote
Old 02-16-2014, 11:52 AM   #208
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
Correct guys 18x9.5 +38 fits just fine.
You can run 255s or 245s sqaure with no issues.
We run 265s but also add a bit of extra camber in for our track set up. Still no issues.
Look at how SEXY this combo is! Can get them in SBC or Black like pictured below and have the same stance.
FT-86 SpeedFactory is offline   Reply With Quote
The Following 3 Users Say Thank You to FT-86 SpeedFactory For This Useful Post:
fx35s (02-17-2014), Hicklinc (02-18-2018), yomny (02-16-2014)
Old 02-16-2014, 08:34 PM   #209
edsbreezy
edsbreezy's Avatar
Drives: 2014 Subaru BRZ Premium - Red
are you running spacers in the front to clear the big brakes?
edsbreezy is offline   Reply With Quote
Old 02-16-2014, 10:18 PM   #210
FT-86 SpeedFactory
No it clears just fine as well.
ft-86 speedfactory
Wheel Directory: Enkei RPF1 17x9.0 +35 D1cker Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 801 06-18-2024 07:31 AM
Wheel Directory: Enkei Raijin 18x8.5 +45 / 18x9.5 +45 GuerillaRacing Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 221 08-01-2019 11:30 AM
Enkei RPF1 18x9.5 5x100 38mm Offset Black Wheel - Exclusive Tony Angelo Edition Wheel Infamous Performance Wheels and Tires 122 02-13-2014 12:34 PM
WHITE Enkei NT03+M 18x9.5 / Enkei RPF1 17x9 Touge Factory Wheels and Tires 2 02-05-2013 05:53 PM
F/S Enkei RPF1 5x114.3 18x9 +35 18X9.5 +38 with track tires SsmoothyMonster Wheels and Tires 17 09-24-2012 02:52 AM
