Old 01-02-2014, 05:01 PM   #1
Young_makaveli
Young_makaveli's Avatar
Drives: 2013 frs
Frs temperature gauge question
Hi guys it's me again
Got a small question
So today I went to go pick up my girlfriend from work and my car is warmed up, the gauge is reading just a bit under the normal
So I park the car and let it idle so it can warm up more while I wait for my girl to come out
But then I notice the Guage gets lower ( first line after the c) instead of warmer
Is this normal?
As soon as my gf came out, I went to drive the car and let it warm up to normal temperature.
Now I'm inside the car and the reading stays at normal.
And now going lower
Thanks guys
Sent from my SM-N900W8 using Tapatalk
Young_makaveli is offline   Reply With Quote
Old 01-02-2014, 05:40 PM   #2
Xinshadow
Drives: 2013 Scion FR-S Ultramarine
Is this normal?
And now going lower
Thanks guys
Totally normal. Mine does the same thing, particularly when it's below freezing outside. The reason is because the engine really isn't at normal operating temp unless it's under load (IE when your driving) so the temp can drop back down a bit when it's just idling.
Factory temp gauges are terribly inaccurate anyways, so it's nothing to worry about.
Current mods: OFT Stage 2 (w/93 oct), OFH, Perrin Resonated catback, DSS Aluminum Driveshaft, Perrin drop-in filter, Avo silicone inlet, Mishimoto catch can, Grimmspeed MCB, Perrin crank pulley, Nameless overpipe/downpipe combo, DBA slotted rotors, Ferrodo brake pads, goodrich SS brake lines, DOT5 synthetic brake fluid.
Xinshadow is offline   Reply With Quote
The Following 2 Users Say Thank You to Xinshadow For This Useful Post:
humfrz (01-03-2014), Young_makaveli (01-02-2014)
Old 01-02-2014, 05:42 PM   #3
Young_makaveli
Drives: 2013 frs
Ah ok thanks A lot for the explanation man
Appreciate it, glad that it's normal
Old 01-03-2014, 02:19 AM   #4
DANG, @Young_makaveli ...... you're ah gonna drive yourself crazy if you keep noticing all those little things ....
Your car will normally "throw you a code" if it's ah ailing ....
I suggest you pay more attention to your girlfriend .... she is more fragile than your car.....
onefitz (01-03-2014), Young_makaveli (01-03-2014)
Old 01-03-2014, 02:48 AM   #5
Apoc
Apoc's Avatar
Drives: Raven FR-S 6M
I noticed my gas gauge goes down when I drive. Is this normal too?
“The World is Flat”
[||•]=(86)=[•||]
Apoc is offline   Reply With Quote
The Following User Says Thank You to Apoc For This Useful Post:
wparsons (01-03-2014)
Old 01-03-2014, 03:08 AM   #6
Young_makaveli
Drives: 2013 frs
I notice you are being sarcastic
Is that normal too?
Old 01-03-2014, 09:30 AM   #7
Apoc
Apoc's Avatar
Is that normal too?
Sadly yes. Sometimes it's the only fun I have.
“The World is Flat”
[||•]=(86)=[•||]
The Following 2 Users Say Thank You to Apoc For This Useful Post:
ftc~brz (01-03-2014), Young_makaveli (01-03-2014)
Old 01-03-2014, 04:56 PM   #8
Young_makaveli
Drives: 2013 frs
Lol all good
Old 01-03-2014, 06:08 PM   #9
toeout
Thermostat should keep the temp in the normal range after the initial warm up. If it's cold outside it regulates the amount of coolant that's being circulated through radiator. So unless it's so cold outside that the engine can't get up to the working temperature with fully closed thermostat, it seems that the thermostat is not working correctly.
With the car being so new though, that seems very unlikely, so I'm not sure what it could be.
toeout is offline   Reply With Quote
Old 01-03-2014, 06:11 PM   #10
Young_makaveli
Drives: 2013 frs
Well I did not let the car warm up all the way and it was very cold yesterday (-27 degrees Celsius )
But after I drove for a bit and let the car warm up,it didn't do the problem again
Old 01-03-2014, 06:23 PM   #11
toeout
Christ. That is cold
The Following User Says Thank You to toeout For This Useful Post:
Old 01-03-2014, 06:25 PM   #12
Young_makaveli
Drives: 2013 frs
[quote=toeout;1428154]
(-27 degrees Celsius ) [\ QUOTE]
That's Canada for you lol
What temperature do you put A/C on? FRiSson New England 23 06-13-2016 09:55 AM
P3 Gauge Question jjkerr626 Software Tuning 1 01-01-2014 02:41 AM
FA20CLUB FR-S/BRZ Gauge Integration- Install other sensors question mtimney Electronics | Audio | NAV | Infotainment 2 07-24-2013 04:27 PM
FS: AEM 30-4402 Oil/Transmission/Water Temperature Digital Display Gauge. Sportsguy83 Engine, Exhaust, Bolt-Ons 4 03-25-2013 11:37 AM
Temperature Gauge a dummy gauge? bambbrose BRZ First-Gen (2012+) — General Topics 40 08-19-2012 05:29 PM
