#43 | |
Drives: UK GT86
Where were you measuring the IATs from?
.: Stealth 86 :.
#44 |
Drives: 4-Runner Sport - 13' BRZ SportTech
Thanks for all of the info. I ended up ordering the Stage 1 Ceramic Coated setup from a local shop yesterday. I appreciate the vendors that got back to me with pricing etc, but ultimately the exchange rate and duty was killing it.
In your opinion, is an air/oil separator necessary? And a BOV? |
#45 | |
Ridge Racerrrrrrrrr
BOV - not "needed" but it helps. If you plan to stick around base boost and everything else it will not be a huge issue. I picked one up because I know I will be playing with my PSI down the road
#46 |
That Guy
Drives: 2013 asphalt FRS MT
Requisite Canadian apology; sorry for disagreeing... I'd say the air/oil separator is required. Not a vent to atmosphere catch can, that's idiotic. But a simple aos on both PVC lines if boosted, or just the line going to the intake plenum if NA and doing lots of wot.
| The Following User Says Thank You to Calum For This Useful Post: | CSG Mike (12-31-2013) |
#47 | |
i would argue that it's idiotic to go to all the trouble of installing a catch can then just plumb the junk back into the intake tract, but who am i to argue... |
| The Following User Says Thank You to jamesm For This Useful Post: | King Tut (01-02-2014) |
#48 | |
That Guy
The positive crankcase ventilation system exists for a purpose, to remove blowby gasses from the crankcase and maintain a vacuum so as to increase ring sealing. When modifying the system to better suit a boosted engine the goal should be to make the system better without removing it's main function. There are a few way to accomplish the main purposes of the PCV system: The best way would be a vacuum pump as they work at all times and under all engine conditions. The discharge can be routed to the intake if you're concerned about the environment, or to atmosphere if you don't care. The down side is they are expensive. An engine based vacuum system is cheap and reliable, but only works at partial throttle or below, when the intake plenum is under vacuum, or if the intake to the forced induction compressor is pulling sufficient vacuum. These allow the blowby gases, including unburnt fuel, to be burnt in the engine which is better for the environment, but often route oil vapor and even liquid droplets back into the engines intake. Another way is with an exhaust venturi, but these only work when the engine is at wide open throttle, are horrible for the environment, are illegal in most places, and will destroy a catalytic converter if it's downstream of the venturi. So, most people stick with the engine based vacuum system, but why on earth would you just completely disable the system in an effort to modify it for boosted use. Why not maintain the system, but upgrade it for boosted use. A decent air/oil separator will allow the engine to maintain a vacuum in the crankcase but will remove any liquids from the air stream. You'll have to drain the aos, but that's a small price to pay for not having to change your oil every couple hundred miles. Or worse, letting your oil go, getting contaminated with exhaust gases so that it turns acidic & eats away at the bearings, all the while getting diluted with fuel so that the oil losses viscosity. |
| The Following 6 Users Say Thank You to Calum For This Useful Post: | CSG Mike (12-31-2013), diss7 (12-31-2013), Hanni_0176 (02-26-2014), Ralph Spoilsport (12-31-2013), SirBrass (02-26-2014), SkAsphalt (12-31-2013) |
#49 | |
the only issues i think i've ever seen on boosted cars were either from someone having nothing at all or a catch can that wasn't catching everything. the only way to guarantee there is no oil in your intake is to not give it a path to get there. not having vacuum in the crankcase isn't ideal, but it's better than pumping some amount of junk back through your turbo plumbing. i've never actually heard of or seen a real person have issues with crankcase pressure with a full vta setup, period. it's a theoretical argument, with no real material impact. the only thing that *does* have a material impact is how effective the extraction mechanism is, which in the case of most catch cans isn't very great. vta is 100% effective at keeping shit out of your intake, and that's kinda the whole point. i'll change my mind when i see someone actually have a material issue arise from using a vta setup. until then i'll keep my shiny clean intercooler pipes. |
#50 | |
Ridge Racerrrrrrrrr
| The Following User Says Thank You to SkAsphalt For This Useful Post: | Calum (12-31-2013) |
#51 |
That's some good info. Opinions on the Cusco separator type catch can? Personally I think it looks better than the rest of the ones out there and it's in the same ballpark for pricing
I decided to also get the AVO 50/50 BOV and a AEM UEGO Failsafe boost/AFR gauge. For the UEGO, I'm thinking of just having a bung welded onto the stock front pipe. |
| The Following User Says Thank You to protpibe For This Useful Post: | SkAsphalt (12-31-2013) |
#52 | |
Drives: Slowly
I don't know if there is any benefit, but they are Perrin agents and wanted to use it. Scaled nicely and produced a solid result with E85 and mild boost. I'm a fan of the stock airbox, but saw no issue with the Perrin. |
| The Following User Says Thank You to coyote For This Useful Post: | SkAsphalt (01-01-2014) |
#53 | |
That Guy
http://www.jegs.com/i/JEGS+Performan...52205/10002/-1 Or this one that includes hoses. http://www.jegs.com/i/Steeda/957/555-3710/10002/-1 They're cheap and easy to maintain, but you will have to come up with your own mounts. Edit, there even cheaper on Summitracing right now. http://www.summitracing.com/int/part...3710/overview/ Last edited by Calum; 01-01-2014 at 07:17 PM. |
#54 |
Those look to be the same thing you can get at lowes in the air compressor aisle for like $15. Lots of people use those.
#55 | |
That Guy
They are, but if you use one for an air compressor you need to seal the drain valve as they are made or work under pressure and not vacuum. The fittings, and short length of hose, wont be enough to offset the price of a $15 separator from Lowes, though. |
#56 |
Drives: xA
Some have mentioned spool up and other good points to look at. Best spool doesn't necessary mean best transient response and best low end power. A well designed kit will have excellent volumetric efficiency even below the boost curve. PTUNING kit is a great example of this. Utilizing a GT3076r but still making more power as soon as the pedal is depressed, and this is compared to other top kits out there with smaller turbos. It is nice to have an out of the box kit capable of 500whp
PTUNING ; Tuned for Competition
| The Following User Says Thank You to Blown_xa For This Useful Post: | Sportsguy83 (01-01-2014) |
| XXR's? Maybe not right the choice... | dem00n | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 9 | 12-20-2013 02:32 AM |
| Rim choice | Karl07 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 07-19-2013 07:31 PM |
| What is your first mod choice? | genometuning | Scion FR-S / Toyota 86 GT86 General Forum | 43 | 08-31-2012 12:53 PM |
