#19545 |
AZ FRS 86
@AZFRS86
#19546 |
2012 car of the year
Drives: Frontengine Reardrive-Sportcar
I saw a Dark Grey Metallic BRZ at Arbys on Val Vista / Baseline so I left a Spotted card. Then I saw a Hot Lava FRS on my way home down Val Vista. 86s everywhere
Sent from my phone
#19547 |
I have this intake mod for sale if anyone is interested. 3 inch tube, deletes sound generator. Comes with non oiled air filter. Easy to install.
Sent from my phone
#19548 |
Heres pics of the intake mod
Sent from my phone
#19549 | |
Drives: SWP BRZ 6MT
^ Me with @Nelsmar's tune. Seriously, it's awesome. And it makes me think that every other tuner who's worked on JDL headers has been phoning it in. After seeing the capabilities of the ECUtek platform, it's definitely the best tuning solution around. And if I want an OFT style device for managing ROMs and logging, I can get on of these: [ame="http://www.amazon.com/Dell-Venue-Pro-Tablet-Windows/dp/B00FEE7B1I/"]Amazon.com: Dell Venue 8 Pro 32 GB Tablet (Windows 8.1): Computers & Accessories[/ame] and load ECUtek on it. |
#19550 |
Lol yes! Home brew oft! Haha uber curious how fast that device flashes! And after working with ecutek the custom map shit is awesome can't wait to get that nailed on your car. Lyn is thinking about buying an frs this week :x the ill have another test car and can throw my flex fuel sensor in her car to finish tweaking every part of that adjustment map on yours.
I ended up testing out giving Brent a flex fuel map with the map switch to select ethanol content basically. Then if he were to ever switch in a sensor it would flip over to regular flex fuel. Since he isn't allowed e85 or a flex sensor in his race class it was kind of an "in the middle" approach. And now the map wil directly copy / paste to my car . I'm jelly his actually has been starting... Looks like when my car was tuned it never had a cold crank map created based off ethanol sensor. Fail. -.-
When I grow up, I wanna be God. My flickr - Canibeat Local magazine scout Old Setup: Vortech Supercharged 360WHP/262WTQ @ 11.5psi My build thread - WTF happened to nelsmar's car thread |
#19551 | |
It's the Mad Cow
So I have a question, how much of that map for Ninjin was based off the OFT available E85 maps?
Remember ECUTek cost is what 650 for a single setup now that you can tune where as Openflash is 495 and I obviously have been able to get them cheaper. Nelsmar knows I don't mind it but each has a different market. The OFT is also fully tuneable by the end user using Tuner Pro or Rom Raider (I have to say after trying both Rom Raider is my choice personally) allowing you to do most anything you could wanting directly for your vehicle and its modifications, provided you know how. However ECUTek (650) + Tablet (250) is 900 vs less than 500. So the question becomes are the few features that ECUTek has worth 400 vs the OFT which has added most everything in a matter of a few months that people have requested and continues to? Also the Pro vs Race also has its limits so to get full feature use from ECUTek you need the Race version which is another 300. I have no doubt the OFT will continue to advance as it already has, so for me paying more for a program that may be slightly nicer is ludicrous esp. when compared to HP Tuners Pro which tunes 5 vehicles and allows signal input and is without doubt one of the best known and setup tuning programs all for 650.... compared to ECUTek which is 650 for 1 vehicle and tuning more than one vehicle with it is another story as is some of the advanced features everyone likes. (Want to tune more with HP Tuners it is 49.99 a credit for Ford, GM or Dodge multiple platform support and multivehicle support even with the non-pro version) I personally dislike ECUTek for that reason alone. I work with other platforms and ECUTek by far takes advantage of its customer base with the rates it charges vs the product it provides. Quote:
05 GTO 408 Stroker \ 13 FRS 210 Twin Screw Supercharger on E85 \ 14 F-150 5.0L Last edited by Cross; 12-24-2013 at 12:02 PM. |
#19552 |
I can type details or show ya in person later. Literally nearly nothing. My first e85 map I did the same thing shiv did with injector scaling etc. My new e85 map is actually flex fuel. It does not touch anything that oft uses. It actually has a table for ethanol content and a fuel modification table specifically altering the final output fuel quantity before the Ecu checks the do to port ratio for actual injection cycle. This way the Ecu still functions normally and you don't have to "hack" a bunch of tables to pretend your using smaller injectors than you are. As may tables refrence eachother this is more ideal. Also data logging is farrow advanced and for higher power speed density is quite desired. I personally will be forced to use speed density for my engine. Which as of current is not widely supported. It will be supported eventually but I would rather use a corporately tested speed density platform first. That and ecutek has been awesome with support with me. I get lengthy emails back in minutes.
When is the next time you are in Phoenix? I can show you a comparison and you can show me what is new in the oft world. Also tuning an additional car you just buy another license. It is acceptable to share cables. So if two people want to go half it's just fine.
#19553 |
The big deal to me is making new tables which oft doesn't currently have and I realistically don't see it having for some time however I hope to be proven wrong. Not many platforms have this ability and that is a huge deal to me.
#19554 | |
It's the Mad Cow
We can grab some food and hang out then, I am always into chatting I just had to point out both sides you know I take no offense to it I told you when you messaged me its fine. But I did need to point out the gaps are not as big as has been mentioned. There are differences but its apparent they are making a lot of changes to make provide the features requested. As pointed out by @Shad0ez I set his Flat Foot Shifting and Launch Control last night via email for him. I am in no way saying ECUTek is not a great program, I believe it is I just don't like the structure and rates due to my time with other platforms and now OFT. I personally like the OFT not just because I am a Vendor for them but because of the way they treat customers and the price vs provided features. (I looked at others before choosing the Unichip then OFT when they came out) ECUTek is just to much for me to accept, I have the money but wow its almost a turn off if that was my only option and well.. I hate just leaving my car to someone else I want to mess with it even if its minor adjustments in the case of the FRS. @nelsmar will take great car of ANYONE he helps I have no doubt in that, going to him is an excellent option for local's and I highly encourage it he is a good guy. Anyone thinking about that option really should consider him he will take good care of you and his option may be exactly what you are looking for.
05 GTO 408 Stroker \ 13 FRS 210 Twin Screw Supercharger on E85 \ 14 F-150 5.0L |
#19555 | |
sent from your mom |
#19556 | |
When I'm not on my phone i can explain things in more detail or will more than happily answer questions over the phone.
#19557 |
Just as a comparison I have been using my racerom upgrade on Brent's car. He can still edit his maps. I just make sure to keep the important stuff in the maps
He can access. He still has full read / write ability. The e85 logic just isn't viewable to him. He just knows that map 4 will switch fuel quantity by a percent and that his target afr map is still correct. but the rest is still editable. Just like normal
#19558 |
Hey guys. I'm in Gilbert and will hopefully be buying an FR-S/BRZ shortly. Just curious, how much does registration cost for these cars?
| Tags |
| arizona, fr-s, mesa, phoenix, scion, tucson, we need a subforum |
| Arizona Bill 'could' criminalize Internet Trolls | Giccin | Off-Topic Lounge [WARNING: NO POLITICS] | 18 | 12-30-2013 02:54 PM |
| Accessories page for Canadian BRZ owners | percyng | CANADA | 1 | 06-15-2012 07:27 PM |
| FR-S\BRZ owners give thumbs up to AE86 owners | Oriental Life | Scion FR-S / Toyota 86 GT86 General Forum | 19 | 06-13-2012 03:12 AM |
| Home Sweet Home, it made it today. Delivery party 5/11 though.. | MarkRacerX | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 05-14-2012 03:24 PM |
