Old 09-13-2013, 01:16 PM   #71
BRZ NA
Drives: WR blue
Originally Posted by FT-86 SpeedFactory View Post
The rotors will not touch the spoke at any time with the AP kit. We have had plenty of hard lapping days with this setup and there are no issues.
35-45 offset are just right for a 17x9 wheel on our cars, IMO.
Thx so it won't hit between the wheel and the caliper due to the heat expansion right?then from 35-45 which one will give u more clearance? (Just worried that the wheel and the caliper make contact ) by the way,how do u like it on the track w bigger wheels and tires?
BRZ NA is offline
Old 09-13-2013, 01:46 PM   #72
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
If you want to clear a bbk you have to +35 in a 17x9 to work for the rpf1. We got sets of silvers in stock.
FT-86 SpeedFactory is offline
Old 09-13-2013, 02:06 PM   #73
BRZ NA
Drives: WR blue
Best price shipped to 94066 in black though
BRZ NA is offline
Old 09-14-2013, 02:10 AM   #74
bolecailey
Drives: FRS
Originally Posted by Dezoris View Post
AP all the way. Someone had their dust boots melt down on the Wilwood kit already if I am not mistaken from track use?
I have never had dust boots on any of my Brembos on other cars not melt after a track day. As far as I know, on all brake kits and track use, the dust boots typically melt, they are rubber after all.
bolecailey is offline
Old 12-23-2013, 10:15 AM   #75
liquidsky44
liquidsky44's Avatar
Drives: AVO Turbo Subaru BRZ / Subaru WRX
Just wanted to check did anybody tried using the AP Racing CP3908 rotors meant for the Endurance kit on the Sprint kit?
liquidsky44 is offline
Old 12-23-2013, 01:44 PM   #76
CSG David
CSG David's Avatar
You will need the proper designed hat and bracket from the Endurance kit before bolting it up. The hat allows that ring to float proper and the bracket will bring the caliper outboard to accommodate the larger rotor.
CSG David is offline
The Following User Says Thank You to CSG David For This Useful Post:
liquidsky44 (12-23-2013)
Old 12-23-2013, 01:52 PM   #77
liquidsky44
So technically its possible with just the rotors and the hats I assume?
Sent from my GT-N7105 using Tapatalk
AVO Turbo|Essex AP Sprint Kit|AVO Overpipe|HKS Hi-Power Spec L Catback|Cusco Engine Mounts|Whiteline Bushings|KW Clubsport|Defi Advance ZD|AEM Wideband Failsafe Gauge|Greddy ProFec Boost Controller|Tomei 2Way LSD|AEM Water/Meth Kit|PBM Angle Kit + Kunckles|Flatwell LCA|HKS Oil Cooler|Greddy High Cap. Diff Cooler|Sard ATF Oil Cooler|CSF Radiator|
Old 12-23-2013, 02:03 PM   #78
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
You need the caliper brackets. I'm not sure that hats are actually different, depends on inside diameter of the rotor. The floating feature is built into the rotor (slotted mounting hole), the hole in the hat shouldn't be. I haven't seen an endurance kit in person (except for the caliper bracket) so I can't say for sure that they are the same but I've never seen another floating setup with slots in the hats. That doesn't mean the hats aren't different for other reasons though. For the limited research I did when I considered this you would need brackets, rotors and multiple bits of hardware/bolts. The advice from Jeff at the time was to stay with the Sprint kit, or sell it and buy the endurance kit. The cost of the parts was more than the difference in kit prices.. hell just the rotors were basically the difference in kit price if one tried to convert.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Dave-ROR is offline
Old 12-23-2013, 02:12 PM   #79
CSG David
CSG David's Avatar
Mmmm...Endurance kit.
Old 12-23-2013, 02:16 PM   #80
diss7
Drives: AE86, 2x GT86, TE27
FWIW I use the Wilwood kit, with semi slicks, for 10-15 lap sessions, and they are excellent.
Not doubting the AP kits at all. But most don't need it.
diss7 is offline
Old 12-23-2013, 03:17 PM   #81
Nhil
Drives: 2013 Scion FRS
4 Piston or 6 Piston kit?
Nhil is offline
Old 12-23-2013, 09:25 PM   #82
diss7
6
diss7 is offline
Old 12-24-2013, 10:42 PM   #83
Testdriver777
Drives: Toyota 86
Hi there, I'm in the market to get a BBK for my ZN6, I have a couple of clarification points though that you may enlighten me with:
1. What's the major difference of the AP Racing BBK kit specifically Sprint vs. Endurance? Which is best for my application? More of street and occasional track like once every quarter.
2. Can I upgrade just the front brakes?
Thank you very much in advance.
Anthony from Manila, Philippines
Testdriver777 is offline
Old 12-26-2013, 12:21 PM   #84
G-Man
G-Man's Avatar
Drives: 1980 corvette, 2014 Subaru BRZ
Very bottom of the page, The sprint and endurance AP Racing kits are front only.
http://www.essexparts.com/shop/compl...86-bundle.html
G-Man is offline
Stillen Brakes jdzumwalt Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 01-16-2013 12:57 AM
KW Coilovers, Brembo Brakes, Cusco and more! at Vivid Racing vividracing Brakes, Suspension, Chassis 5 10-15-2012 07:23 PM
help on Wilwood brakes brackets Turbo Den Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 10-01-2012 09:14 PM
OEM Brakes? marinjim Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 08-20-2012 11:26 PM
GT brakes jello AUSTRALIA 2 06-10-2012 10:10 AM
