Old 09-27-2013, 07:01 PM   #29
SurfAndSand
8SiX
Drives: FRS 10series
Originally Posted by Chris@Phastek View Post
I don't see why it couldn't hurt to add a brace. Just have to get one made. I don't notice any negative side effects at the moment.
Oh I see - that brace is actually part of the driveshaft, and not an independent piece that you can just bolt back on. Correct?
SurfAndSand is offline   Reply With Quote
Old 09-27-2013, 07:04 PM   #30
PhastekSport
PhastekSport's Avatar
Send a message via AIM to PhastekSport Send a message via Yahoo to PhastekSport
I haven't looked at it in a while, but it has a collar. I think you can shave that portion off and be left with a little brace.
Thought about it as I removed it...
PhastekSport is offline   Reply With Quote
Old 09-30-2013, 08:31 PM   #31
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Curious to ask OP and others that got this...
Did you find you needed to play with rotating the back bolt position anyone to have no vibes or weird harmonics?
Mine was a straight bolt and so far nothing weird but a few I know are going through process of turning 90, then again and swear they have vibes so in curious...
Old 09-30-2013, 08:40 PM   #32
PhastekSport
Yeah no issues at all. Bolted it straight on. Victor is the OP but it is on our vehicle. He was installing his oil cooler or something while this went on.
Sent from my LG-E980 using Tapatalk 4
Old 12-21-2013, 07:20 AM   #33
Efferalgan
Drives: 2025 BRZ, ex-2012 GT86
Thanks a lot for the DYI! Just installed mine. So far everything is perfect, no increase in noise and or vibrations (although also installed Nameless FP/DP combo together with the DS which added loudness). The only concern, which mechanics pointed my attention to, is the lack of the protective cup on the carbon driveshaft. I allows dirt, liquid and chemicals from the road to contact the connection point of the DS with the gearbox, which is not good at all. They even recommended to cut the protective cup from the OEM driveshaft and weld it to the DriveshaftShop one. I declined for the time being but now thinking about protective measures for the DS... Let's see how it survives winter.
Efferalgan is offline   Reply With Quote
Old 12-21-2013, 09:05 PM   #34
Dustin
Twin Screw You
Dustin's Avatar
Drives: 2013 Supercharged Whiteout FR-S
Originally Posted by F1point4 View Post
Purpose?
Dustin is offline   Reply With Quote
Old 12-21-2013, 09:10 PM   #35
PhastekSport
Pretty sure IIRC it was to help ensure everything is balanced. Less likely to have vibration should you go back.
Sent from my SAMSUNG-SM-N900A using Tapatalk
Old 12-21-2013, 09:24 PM   #36
Dustin
Twin Screw You
Dustin's Avatar
Wish I would have known that before removing mine, lol. I guess if there is excessive vibration I would just have to unbolt the driveshaft and rotate to the next hole until everything smooths out?
Old 12-21-2013, 09:36 PM   #37
OICU812
Just a dude
OICU812's Avatar
Correct.
Old 12-28-2013, 09:27 PM   #38
Captain Insano
Nice - good idea on marking that before removal. Thanks for tip.
Captain Insano is offline   Reply With Quote
Old 03-31-2014, 06:02 AM   #39
Deepseadiver
Drives: 2013 BRZ DMG manual Limited
I just installed mine! Thanks for the DIY! Only think I was wondering is the length of the four bolts do not thread all the way past the nut. The flange on the new drive shaft is about a 1/4 thicker making the old bolts just a tad to short. I can see a few threads on the left on the nuts.
Deepseadiver is offline   Reply With Quote
Old 05-10-2014, 08:47 PM   #40
Deathreaper
Drives: 2013 Scion FRS
Installed mine yesterday. Wasn't able to fit a torque wrench in there so I used a closed wrench to tighten it as much as possible. Has anyone been able to fit a torque wrench?
Deathreaper is offline   Reply With Quote
Old 10-03-2014, 10:25 PM   #41
ProjectD
ProjectD's Avatar
Drives: '04 350Z/ 2013 LR BRZ (LM)
I thought I read somewhere that someone had to buy a completely new set of bolts due to this issue. I can't find the thread, but just out of curiosity, how much of a difference exactly? Pics?
You couldnt fit the torque wrench? I imagine that you simply rotate the it get to where you can tighten the bolts/ nuts right? Ive see ft86speedfactorys video and they made it seem like a piece of cake...granted...they also had a lift lol
ProjectD is offline   Reply With Quote
Old 01-11-2015, 09:31 AM   #42
pepe
Drives: gt86
Hello! from my ignorance of mechanical issues
a question .... OEM transmission shaft, consists of two parts and a rubber gasket ... right? why?
which is the reason why Japanese engineers (which should not be too dumb), make this piece into two parts?
pepe is offline   Reply With Quote
diy, driveshaft, driveshaft shop, dss
Driveshaft Shop Carbon Fiber Shafts Explained Driveshaft Shop Engine, Exhaust, Transmission 121 11-17-2017 12:57 PM
Driveshaft Shop Axles & Upgrades for Scion FR-S!! MVP Motorsports RobertatMVP Transmission and Driveline 39 07-11-2014 02:48 PM
Driveshaft on a DD FRS Bullnettles Engine, Exhaust, Transmission 31 10-06-2013 02:22 PM
The Driveshaft Shop Custom Axles and Shafts Sportsguy83 Engine, Exhaust, Transmission 26 01-11-2013 05:55 PM
Automatic Carbon Fiber Driveshaft? Yes! RallySport Direct Engine, Exhaust, Transmission 13 12-15-2012 01:40 AM
