| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#29 |
Drives: WRB LMTD '13
coils /springs will make it perfect. I'd get coils
#30 |
Drives: '14 S4
I have the STI springs on order... I don't really have a use for coil overs for what this car is for to justify the cost of quality ones...
2014 Audi S4 · 2010 xTerra Off-Road · 2014 Fiat 500e
| The Following User Says Thank You to KSpider For This Useful Post: | hanabie (09-17-2013) |
#31 |
Drives: '13 BRZ
looks really good! glad to see those on a non lowered car before i buy those rims :P i cant lower my car in my city
roads r just way to rough for a lowered car
#32 |
#33 |
Drives: '14 S4
I ordered a bunch of other STI parts... figured Id order the springs to stay with OEM. They only lower the car about .6 - .7" too, so it isn't that big of a drop, which I do not want.
Were you just curious or do you have a reason not to?
#34 | |
Hachiroku
Drives: 2013 Toyota GT86 Hot Lava
Nice!! Thanks for the photos!
Looks really good. Performance-wise, did it feel heavier than the stock? Made much of a diff? Planning on getting the same set up. Thanks.Quote:
#36 | |
Drives: Subaru BRZ
Hi, I was planning on this exact setup. No lowering either, just the rims & tires. Do you have any regrets or rubbing issues? Thanks! |
#37 |
You won't have any issues with that setup, especially at stock ride height.
#38 |
Drives: 2013 Subaru BRZ
There's no fittment issues at all with this setup. I'd just suggest you so symetrical because before I got my coilovers I was getting some understeer which is annoying as hell.
#39 |
Drives: 2013 Whiteout FR-S
18x8.5 in the front
Wheels are 18x8.5, tires are 225/40 pilot sports, and the setup seems to be making the occasional rubbing or clicking noise in the front... Other than that, car drives great...
Question is, will this or could this be problematic in any way long term with stock suspension? Thanks! Jonny |
#40 |
What offset are your wheels?
#42 |
Just a dude
Drives: Scion FR-S 2013
Sure you're rubbing??? Have you identified points that prove so? That size with all details you've provided should be no where near rub not even close. You got something else going on. Jack it up turn wheels both ways and look around... Go from there..
| The Following User Says Thank You to OICU812 For This Useful Post: | JonnyJames (12-22-2013) |
| Wheel Directory: Enkei RSF5 18x8.0 +45 | ericmpena | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 85 | 06-18-2022 04:07 PM |
| Wheel Directory: Enkei Raijin 18x8.5 +45 / 18x9.5 +45 | GuerillaRacing | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 221 | 08-01-2019 10:30 AM |
| Wheel Directory: Enkei RS05RR 18x8.5 +42 | dabocx | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 206 | 03-02-2018 05:23 AM |
| Wheel Directory: Enkei NT03+M 18x8.0 +35 | Tunz | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 45 | 06-16-2016 11:31 PM |
| Wheel Directory: Enkei Tenjin 18x8.5 +45/18x9.5 +45 | Sciby | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 11-10-2014 12:53 AM |
